I am unable to set my resolution higher than 1024x768.
I have a 17 inch Monitor which supports resolution upto 1280x1024 and my CPU is a i5 2nd gen ( No GPU ).
I know that resolution can be manually created via xrandr but that’s not an ideal solution. I have to do the script every restart which I find annoying.
This will only work for the currently logged in userafter login. It isn’t global. For global, you’d need to create a systemd unit, which while I don’t think is too hard, I’ve just never done it. See here for more:
