I can send .txt files, images - no problem.
It just says “Error occurred while sending File.md”. Very informative…
Tried doing it in terminal with blueman-sendto
, but it just opens the GUI with the same result. I hoped that in the terminal it would display some sort of error log, or that it has an error log option etc. - nope.
Tried renaming it so there are no spaces in file name - that ain’t it either.
On the Android device - tried sending a markdown file to the PC
but I don’t get an option to send it over bluetooth when I click share etc.
But I can do it just fine with other files.
Googled " .md files android bluetooth" - nothing.
I’m stumped O.o
I could send them in .txt format and then rename them on the phone every time, but that seems like a clunky solution…
Thoughts?
(am linux noob, but not a complete one)
EDIT: Also I can’t send .zim files either. Something is definitely up with the file extensions, some sort of filtering or something.
