So I just update my system, after probably a couple of months of not using it. I noticed that pacui can’t search for an AUR package anymore. Is there a way to enable it again?
I forgot to say I have yay installed, mb installed ![]()
You are asking a question that belongs in a Support category. Your post has therefore been moved to a dedicated topic in an appropriate category.
Note that if you wish others to help with your issue, you are expected to provide more detail to help them offer useful suggestions.
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
inxi manual)Command output should be presented as pre-formatted text in accordance with forum guidelines. ![]()
--color=0 to the long-form command, or…inxi -zv8c0Your privacy is respected
Note: Grave accent (or, backtick) characters are used. ![]()
code here.For multi-line command output:
What is a Quark?
Hi @Chronos ,
I cannot reproduce your issue.
Package Manager UI
| 1 Update System 2 Maintain System |
| 3 Install Packages 4 Remove Packages |
| 5 Dependency Tree 6 Reverse Dependency Tree |
| 7 List Package Files 8 Search Package Files |
9 Roll Back System Z Fix Pacman Errors
Y Edit Config Files X List Packages by Size
| W Force Update AUR |
Press number or (marked) letter H Help 0 Quit
3
downloading AUR package info (which can take a while) ...
####################################################################################################################################################### 100.0%
downloaded AUR package info
Sync Explicit (1): forum-scout-qt-0.6.6-1
:: forum-scout-qt is in IgnorePkg/IgnoreGroup. Install anyway? [Y/n]
resolving dependencies...
:: forum-scout-qt-0.6.6-1 and forum-scout-0.6.6-1 are in conflict. Remove forum-scout? [y/N] y
Packages (2) forum-scout-0.6.6-1 [removal] forum-scout-qt-0.6.6-1
Total Installed Size: 0,10 MiB
Net Upgrade Size: -0,01 MiB
(1/1) checking keys in keyring [--------------------------------------------------------] 100%
(1/1) checking package integrity [--------------------------------------------------------] 100%
(1/1) loading package files [--------------------------------------------------------] 100%
(1/1) checking for file conflicts [--------------------------------------------------------] 100%
(2/2) checking available disk space [--------------------------------------------------------] 100%
(1/1) Scanning packages for security issues...
(1/1) removing forum-scout [--------------------------------------------------------] 100%
(1/1) installing forum-scout-qt [--------------------------------------------------------] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Updating the desktop file MIME type cache...
The culprit could be not running an update for some month’s.
For arch based rolling disro’s this is not a good practise
From reading Pacui Codeberg readme…
By default, Pacman is used for package management. If you want to enable the use of the AUR, PacUI needs at least one of these AUR helpers:
My guess would be that the problem is local to your machine – no wider issue seems to exist, and this makes finding a solution difficult; one can only make vague guesses.
For what it’s worth, I note that pacui hasn’t changed since July 22 – the same version (1:r1352.b7cc7d0-1) is in all branches:
mbn info pacui -q
Branch : unstable
Version : 1:r1352.b7cc7d0-1
Repository : extra
Build Date : Wed 22 Jul 2026 00:41:38
Packager : Mark Wagie <mark@manjaro.org>
Branch : testing
Repository : extra
Branch : stable
Repository : extra
You haven’t specified which “AUR helper” you have installed or the respective commands used that apparently are failing – nor have you provided outputs of any failed commands – there isn’t much to go on, at this time.
This indicates that you might use another AUR helper than yay or pamac-cli, which are in the Manjaro repos and therefore updated with the normal update. All other AUR helper must be updated from AUR, then pacUI should work normal again.
Pacui has been updated on unstable branch
Branch compare for Manjaro – pacui
stable :1:r1352.b7cc7d0-1
testing :1:r1352.b7cc7d0-1
unstable :1:r1365.9204e8b-1
[pkg-upd] 1:r1365.9204e8b-1 (76c5b926) · Commits · Packages / extra / pacui ·…
PKGBUILD includes optional dependencies pamac-cli and yay only for AUR support
PKGBUILD · master · Packages / extra / pacui · GitLab
pkgname=pacui pkgver=r1365.9204e8b pkgrel=1 epoch=1 pkgdesc="Bash script providing advanced Pacman and AUR helper functionality in a simple UI" arch=('any') url="https://codeberg.org/excalibur1234/pacui" license=('GPL-3.0-or-later') depends=( 'expac' 'fzf' 'less' 'pacman-contrib' 'pacman-mirrors' 'sudo' ) optdepends=( 'downgrade: Hidden downgrade option' 'flatpak: Flatpak update support' 'fwupd: Firmware update support' 'jq: JSON file filtering and AUR package formatting' 'pamac-cli: Option for AUR support' 'snapd: Snap update support' 'yay: Option for AUR support' )
I suggest the following for convenience:
1. Install topgrade (a script designed to assist updating your system) and yay (an “AUR helper” applcation):
sudo pacman -S topgrade yay
2. Run topgrade:
topgrade
This simple command will run a typical system update using pacman and run yay to upgrade or rebuild any applications sourced via the AUR.
Using topgrade will give you time to learn the correct pamac and yay commands separately, while in the meantime ensuring no mistakes are made.
Hopefully, you will find this a useful addition.
Note: Still waiting for the requested system information, as well as a clear indication of why you “Can’t search for AUR package”:
I tried searching for an aur package and it does not show it
pacui
However, it shows when I just use the standalone yay
> yay google-chrome
7 aur/chromedriver-beta 152.0.7977.8-1 (+3 0.00) [7h36m]
Standalone server that implements the W3C WebDriver standard (for google-chrome-beta)
6 aur/metamask-google-chrome 12.18.1-1 (+1 0.00) [428d16h] (Out-of-date: 2026-01-25)
Browser extension that enables browsing Ethereum blockchain enabled websites
5 aur/google-chrome-canary 153.0.7980.2-1 (+7 0.05) [6h45m]
The popular web browser by Google (Canary Channel)
4 aur/chromedriver 151.0.7922.71-1 (+52 0.16) [19h35m]
Standalone server that implements the W3C WebDriver standard (for google-chrome)
3 aur/google-chrome-beta 152.0.7977.8-1 (+359 0.43) [10h38m]
The popular web browser by Google (Beta Channel)
2 aur/google-chrome-dev 152.0.7967.2-1 (+652 0.38) [2d17h]
The popular web browser by Google (Dev Channel)
1 aur/google-chrome 151.0.7922.71-1 (+2364 14.98) [10h34m]
The popular web browser by Google (Stable Channel)
==> Packages to install (eg: 1 2 3, 1-3 or ^4)
I am on unstable with the pacui update from a few hours ago (yay as helper):
Edit: Update your mirrors - from pacman-mirrors manpage
To create a mirrorlist using all default use
pacman-mirrors -f
The mirrorlist generation process can be refined through arguments and arguments with options, for example
pacman-mirrors --country Denmark --timeout 5
IMPORTANT
After all operations ALWAYS syncronize and update your system with
sudo pacman -Syyu
Does the search work on pamac?
Maybe pacui is using the wrong backend. Pamac has it’s own cache that has to be refreshed, yay uses aur directly.
I’m sure you must be familiar with the expression “use the right tool for the job” – the right tool, in this case, likely being pamac-cli or other “AUR helper”.
Example using pamac-cli:
pamac search --aur google-chrome
This returns all versions of google-chome-* available via the AUR.
Note that the open-source chromium is available from the official Manjaro repositories; basically the same browser but untouched by Google:
sudo pacman -S chromium
Of possible interest:
pacman – Not used for AUR.yay – An AUR “helper” application.Yes it does
> pamac search google-chrome
chromedriver-beta 152.0.7977.8-1 AUR
chromedriver 151.0.7922.71-1 AUR
metamask-google-chrome 12.18.1-1 AUR
google-chrome-dev 152.0.7967.2-1 AUR
google-chrome-canary 153.0.7980.2-1 AUR
google-chrome-beta 152.0.7977.8-1 AUR
google-chrome 151.0.7922.71-1 AUR
A few of thoughts:
pacui from?fzf was recently updated and pacui depends on it - did it break pacui?pacui has more than one search mode.$PACUI_AUR_HELPER environment variable set to anything?pacui so you’d do well to try the new version as @pwx suggested but refer to point 1. before considering this.
