Hello everyone! I’m trying to run UVRizom AppImage on Manjaro, but getting an error related to OpenGL when trying to run the application. Any help is appreciated. Please consider that I have little knowledge about linux; I tried to install mesa-utils cause I saw in the internet people saying this could be related, but no success.
pacman -Ss mesa utils ✔
extra/mesa-utils 9.0.0-2 [installed]
Essential Mesa utilities
multilib/lib32-mesa-utils 8.5.0-1 [installed]
Essential Mesa utilities (32-bit)
I also tried to follow all the instructions related to the Linux Installation of RizomUV, but still no success.
First of all, I gave all the necessary permissons for the appimage to be executed using the command sudo chmod u+x RizomUV.2022.1.57.gfabcfb8.master.2022-09-29.AppImage
When I try to right click and run the application a dialog appear with the message: “OpenGL Fatal Error. No OpenGL attribs available.” If I click OK, this dialog box appear:
This is what terminal shows if I try to run the appimage through the terminal:
'/home/denielton/Downloads/RizomUV/RizomUV.2022.1.57.gfabcfb8.master.2022-09-29.AppImage'
23:15:26: Debug: No accel key found, accel string ignored.
23:15:26: Debug: Unrecognized accel key 'OPTIMIZE_PAINT', accel string ignored.
/usr/lib/gvfs/libgvfscommon.so: undefined symbol: g_task_set_static_name
Failed to load module: /usr/lib/gio/modules/libgvfsdbus.so
Gtk-Message: Failed to load module "canberra-gtk-module"
(rizomuv:67036): GdkPixbuf-WARNING **: Cannot open pixbuf loader module file '/usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders.cache': No such file or directory
This likely means that your installation is broken.
Try running the command
gdk-pixbuf-query-loaders > /usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders.cache
to make things work again for the time being.
Fontconfig warning: line 5: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/10-hinting-slight.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/10-sub-pixel-rgb.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/10-yes-antialias.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/11-lcdfilter-default.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/20-unhint-small-vera.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/30-metric-aliases.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/40-nonlatin.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/45-generic.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/45-latin.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/48-spacing.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/49-sansserif.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/51-local.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/60-generic.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/60-latin.conf", line 4: unknown element "description"
Fontconfig warning: "/etc/fonts/conf.d/65-nonlatin.conf", line 4: unknown element "description"
23:15:26: Debug: "Right" must use modifiers to be used as a keyboard accelerator with GTK
23:15:26: Debug: "Left" must use modifiers to be used as a keyboard accelerator with GTK
23:15:26: Debug: "Up" must use modifiers to be used as a keyboard accelerator with GTK
23:15:26: Debug: "Down" must use modifiers to be used as a keyboard accelerator with GTK
../src/unix/glx11.cpp(626): assert ""Assert failure"" failed in InitVisual(): Failed to get a XVisualInfo for the requested attributes.
** (rizomuv:67036): WARNING **: atk-bridge: get_device_events_reply: unknown signature
zsh: trace trap (core dumped)
Tried to run using sudo:
Failed to load module: /usr/lib/gio/modules/libgioremote-volume-monitor.so
(rizomuv:68238): GdkPixbuf-WARNING **: Cannot open pixbuf loader module file '/usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders.cache': No such file or directory
(rizomuv:68238): GLib-GIO-ERROR **: No GSettings schemas are installed on the system
zsh: trace trap sudo
inxi -Fxz
inxi -Fxz ✔
Kernel: 6.1.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
Desktop: GNOME v: 43.5 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-GAMING/BR v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2006
date: 11/13/2019
Info: 6-core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ rev: 2
cache: L1: 576 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 2442 high: 3792 min/max: 1550/3400 boost: enabled cores:
1: 3774 2: 1516 3: 1517 4: 2528 5: 1517 6: 3790 7: 3792 8: 1517 9: 1517
10: 2527 11: 1517 12: 3792 bogomips: 81469
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel arch: GCN-4 bus-ID: 08:00.0
temp: 51.0 C
Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1 driver: X:
loaded: amdgpu unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu
resolution: 1920x1080~74Hz
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon RX 570 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.1.26-1-MANJARO) direct-render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 08:00.1
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3
Device-3: FIFINE Microphones K670 Microphone
driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 3-3:2
API: ALSA v: k6.1.26-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.70 status: active
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 447.13 GiB used: 207.31 GiB (46.4%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-1: / size: 438.75 GiB used: 207.31 GiB (47.3%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-1: swap-1 type: file size: 16.29 GiB used: 0 KiB (0.0%) file: /swapfile1
System Temperatures: cpu: 53.6 C mobo: N/A gpu: amdgpu temp: 51.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1098
Processes: 340 Uptime: 5h 44m Memory: available: 15.55 GiB
used: 5.27 GiB (33.9%) Init: systemd Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1313 Shell: Zsh v: 5.9 inxi: 3.3.27
