Can't run manjaro from portable disk on a differrent pc - Error symbol grub_debug_malloc not found & Can't enter GUI
After I updated my system in my PC with Nvidia card, then it failed to boot. After struggling for one month , I decide to buy a new laptop with no Nvidia card. The system is installed in my mobile disk so I just need to plugin to my new laptop.I use live system to boot and then plugin my mobile disk and then use manjaro-chroot to remove all the modules of Nvidia, including using mhwd and pacman, checked both in CLI and GUI. Also update the system to latest using pacman -Syyu. But I find it stuck in grub. So I follow the official document of Manjaro to run the two commands:
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
grub-mkconfig -o /boot/grub/grub.cfg
but it shows grub_calloc not found.
I have no ideas and I realized my new laptop is intel cpu but I installed amd-ucode package before so I uninstalled the package then when I boot it shows grub_debug_malloc.
I already checked another similar topic in this forum(sorry I am not allowed to insert link), but I don’t have the similar situation to boot it because my bios is different and I don’t find the way to change the boot settings in bios and make it boot.
The type of my new laptop is HP Probook 450 G9.
boot into live usb of manjaro, connect to internet, and chroot:
sudo manjaro-chroot -a
post output from:
mhwd-kernel -li && mhwd -l && mhwd -li
inxi -xG
test -d /sys/firmware/efi && echo UEFI || echo BIOS
find /etc/X11/ -name "*.conf"
EDIT:
so you have manjaro installation on a portable disk, that was installed for the previous laptop that you returned, and now you have a new laptop and you want to run the manjaro installation from the old laptop on the new one?
Yes.
Sorry I am not allowed to upload image and copy the output into here(it told me there is link). So I just put the critical information here, replaced all special char to space:
manjaro chroot a
grub probe: error: cannot find a GRUB drive for dev sdb1 Check your device map
Mounting (ManjaroLinux) dev sda2
mount: mnt
mount: mnt boot efi
mount: mnt home my SSD
mount: mnt home my SSD: special device dev disk by uuid 5d8eff9b 1058 4b18 be29 1542141ad3d1 does not exist
mhwd kernel li mhwd l mhwd li
Currently running: 5 15 7 1 MANJARO (linux515)
linux510
linux515
0000:03:00 0 (0200:10ec:8168) Network controller Realtek Semiconductor Co , Ltd :
     network r8168            2016 04 20                true            PCI
0000:00:02 0 (0300:8086:46a6) Display controller Intel Corporation:
       video linux            2018 05 04                true            PCI
 video modesetting            2020 01 13                true            PCI
        video vesa            2017 03 12                true            PCI
Installed PCI configs:
inxi xG
12Graphics:
12Device 1 Intel Alder Lake P Integrated Graphics 12vendor Hewlett Packard 12driver i915 12v kernel
12arch Gen12 2 12bus ID 00:02 0
12Device 2 Chicony HP HD Camera 12type USB 12driver uvcvideo 12bus ID 3 1:2
12Display 12server X Org 12v 21 1 2 12with Xwayland 12v 22 1 2 12driver 12X 12loaded modesetting 12unloaded vesa
12gpu i915 12resolution 1920x1080~60Hz
12OpenGL 12renderer Mesa Intel Graphics (ADL GT2) 12v 4 6 Mesa 22 1 2 12direct render Yes
test d sys firmware efi echo UEFI echo BIOS
UEFI
find etc X11 name conf
etc X11 xorg conf d 00 keyboard conf
click this icon in editor: </> and put the output there…
also this from chroot: mount: “mnt home my SSD: special device dev disk by uuid 5d8eff9b 1058 4b18 be29 1542141ad3d1 does not exist”
post output from:
blkid
cat /etc/fstab
For /mnt/home/my/SSD, it is an SSD drive in my old laptop.
For /dev/nvme0n1p, it is a Windows disk in my new laptop, I already disable the boot option for it.
mount: /mnt/home/my/SSD: special device /dev/disk/by-uuid/5d8eff9b-1058-4b18-be29-1542141ad3d1 does not exist.
[manjaro /]# blkid
/dev/loop1: TYPE="squashfs"
/dev/nvme0n1p3: TYPE="BitLocker" PARTLABEL="Basic data partition" PARTUUID="9ab331d6-2d7e-43e2-b491-95427417352b"
/dev/nvme0n1p1: LABEL="SYSTEM" UUID="EA5C-D4A6" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="0e82cace-abcc-4a8c-83c0-08e699466286"
/dev/nvme0n1p4: LABEL="Windows RE Tools" BLOCK_SIZE="512" UUID="80ECD47EECD47040" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="89c9286c-9ec5-427d-a500-304aad7a0f2d"
/dev/nvme0n1p2: PARTLABEL="Microsoft reserved partition" PARTUUID="6e5aec5e-1b9b-46de-a0fe-483edeb88018"
/dev/sdb2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="92C2-BE26" BLOCK_SIZE="512" TYPE="vfat"
/dev/sdb1: BLOCK_SIZE="2048" UUID="2021-12-20-11-57-16-00" LABEL="MANJARO_XFCE_2120" TYPE="iso9660"
/dev/loop2: TYPE="squashfs"
/dev/loop0: TYPE="squashfs"
/dev/sda2: UUID="adb6b68e-9f4c-4959-bd8a-b7564d79b8be" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="3c4b651d-d0a5-401c-85cd-ab6892824ac5"
/dev/sda1: UUID="CF3B-2739" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="f4bc6f5f-e7a5-48fe-ac1d-3bed0937fdec"
/dev/loop3: TYPE="squashfs"
[manjaro /]# cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=CF3B-2739                            /boot/efi      vfat    defaults,noatime 0 2
UUID=adb6b68e-9f4c-4959-bd8a-b7564d79b8be /              ext4    defaults,noatime 0 1
tmpfs	/home/my/.cache/google-chrome/	tmpfs	noatime,nodev,nosuid,size=4G	0	0
UUID=5d8eff9b-1058-4b18-be29-1542141ad3d1  /home/my/SSD    ext4 defaults,noatime    0  0
so again reinstall grub:
and post output from these commands
[manjaro /]# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
Installation finished. No error reported.
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
done
now uninstall this:
mhwd -r pci video-modesetting
and run this:
mkinitcpio -P
post output from this command
[manjaro /]# mhwd -r pci video-modesetting
> Removing video-modesetting...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-modesetting/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
> Successfully removed video-modesetting
[manjaro /]# mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
  -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.126-1-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
loadkeys: Unable to open file: cn: No such file or directory
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
  -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
  -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: 5.15.50-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
  -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
ok, looks good, so type:
exit
then reboot and see if it helped
I also comment the last line in /etc/fstab and rerun the commands you provide me to solve another
 time-out problem and then I can go into grub and choose linux 5.10 and remove 'quiet' in grub command but the boot is stuck after
[ OK ] Reached target Sound Card
[ OK ] Finished Laptop Mode Tools
And I tried to boot again, it showed me grub_debug_malloc again.
do you have the exact same laptop as before, and the only difference is the graphics card?
They are two different laptops. The new one’s cpu is Intel i5-1240p, gpu is Intel Iris XE. The old one’s cpu is i5-10400, two gpus are Intel UHD Graphics 630 and Nvidia Geforce MX350.
i dont think you can use the old manjaro installation, that was installed on a pc with a different hardware - motherborad, etc… on the new pc with different hardware, but im not 100% sure …
Actually, the current old one is moved from an even older laptop with a different brand, intel cpu, amd gpu by the same way. So I think it is possible to move in the same way.
Is there any way I can try?
i dont know about that… so look on forum here for posts related to it, or edit this post of yours from Error symbol grub_debug_malloc not found to something like: cant run manjaro from portable disk on a differrent pc - grub_debug_malloc not found, something like that
I think I solved the grub_debug_malloc problem. I downgrade grub to 2:2.04-1 then every time I can go into grub. But now I still can’t enter GUI mode, but can use Ctrl+Alt+F3 to enter CLI mode for both linux 510 and 515. Below are the details:
For linux 5.10 the boot is stuck after(but every time it will change )
and the log file /var/log/Xorg.0.log is:
[    35.076]
X.Org X Server 1.21.1.3
[    35.076] Current Operating System: Linux my-pc 5.10.126-1-MANJARO #1 SMP PREEMPT Mon Jun 27 10:02:42 UTC 2022 x86_64
[    35.076] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=adb6b68e-9f4c-4959-bd8a-b7564d79b8be rw
[    35.076]
[    35.076] Current version of pixman: 0.40.0
[    35.076] 	Before reporting problems, check http://wiki.x.org
[    35.076] Markers: (--) probed, (**) from config file, (==) default setting,
[    35.076] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jul  6 22:39:13 2022
[    35.076] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    35.076] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    35.076] (==) No Layout section.  Using the first Screen section.
[    35.076] (==) No screen section available. Using defaults.
[    35.076] (**) |-->Screen "Default Screen Section" (0)
[    35.076] (**) |   |-->Monitor "<default monitor>"
[    35.076] (==) No monitor specified for screen "Default Screen Section".
[    35.076] (==) Automatically adding devices
[    35.076] (==) Automatically enabling devices
[    35.076] (==) Automatically adding GPU devices
[    35.076] (==) Automatically binding GPU devices
[    35.076] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    35.076] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    35.076] 	Entry deleted from font path.
[    35.076] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF,
	/usr/share/fonts/OTF,
	/usr/share/fonts/100dpi,
	/usr/share/fonts/75dpi
[    35.076] (==) ModulePath set to "/usr/lib/xorg/modules"
[    35.076] (II) The server relies on udev to provide the list of input devices.
[    35.077] (II) Module ABI versions:
[    35.077] 	X.Org ANSI C Emulation: 0.4
[    35.077] 	X.Org Video Driver: 25.2
[    35.077] 	X.Org XInput driver : 24.4
[    35.077] 	X.Org Server Extension : 10.0
[    35.077] (++) using VT number 7
[    35.077] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    35.079] (--) PCI:*(0@0:2:0) 8086:46a6:103c:8978 rev 12, Mem @ 0x6000000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[    35.079] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    35.079] (II) LoadModule: "glx"
[    35.079] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    35.081] (II) Module glx: vendor="X.Org Foundation"
[    35.081] 	compiled for 1.21.1.3, module version = 1.0.0
[    35.081] 	ABI class: X.Org Server Extension, version 10.0
[    35.081] (==) Matched modesetting as autoconfigured driver 0
[    35.081] (==) Matched fbdev as autoconfigured driver 1
[    35.081] (==) Matched vesa as autoconfigured driver 2
[    35.081] (==) Assigned the driver to the xf86ConfigLayout
[    35.081] (II) LoadModule: "modesetting"
[    35.081] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    35.081] (II) Module modesetting: vendor="X.Org Foundation"
[    35.081] 	compiled for 1.21.1.3, module version = 1.21.1
[    35.081] 	Module class: X.Org Video Driver
[    35.081] 	ABI class: X.Org Video Driver, version 25.2
[    35.081] (II) LoadModule: "fbdev"
[    35.081] (WW) Warning, couldn't open module fbdev
[    35.081] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    35.081] (II) LoadModule: "vesa"
[    35.081] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    35.082] (II) Module vesa: vendor="X.Org Foundation"
[    35.082] 	compiled for 1.21.1.3, module version = 2.5.0
[    35.082] 	Module class: X.Org Video Driver
[    35.082] 	ABI class: X.Org Video Driver, version 25.2
[    35.082] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    35.082] (II) VESA: driver for VESA chipsets: vesa
[    35.082] (EE) open /dev/dri/card0: No such file or directory
[    35.082] (WW) Falling back to old probe method for modesetting
[    35.082] vesa: Refusing to run, Framebuffer or dri device present
[    35.082] (EE) Screen 0 deleted because of no matching config section.
[    35.082] (II) UnloadModule: "modesetting"
[    35.082] (EE) Device(s) detected, but none match those in the config file.
[    35.082] (EE)
Fatal server error:
[    35.082] (EE) no screens found(EE)
[    35.082] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[    35.082] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    35.082] (EE)
[    35.085] (EE) Server terminated with error (1). Closing log file.
For linux 5.15, the boot is stuck after
[ OK ] Started Light Display Manager
[ OK ] Reached target Graphical Interface
then a whole black screen with _ in the top left corner
so this time it looks like the gpu problem.
[   558.724]
[   558.724] Current Operating System: Linux my-pc 5.15.50-1-MANJARO #1 SMP PREEMPT Sun Jun 26 07:06:30 UTC 2022 x86_64
[   558.724] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=adb6b68e-9f4c-4959-bd8a-b7564d79b8be rw
[   558.724]
[   558.724] Current version of pixman: 0.40.0
[   558.724] 	Before reporting problems, check http://wiki.x.org
[   558.724] Markers: (--) probed, (**) from config file, (==) default setting,
[   558.724] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jul  6 19:21:15 2022
[   558.724] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   558.724] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   558.724] (==) No Layout section.  Using the first Screen section.
[   558.724] (==) No screen section available. Using defaults.
[   558.724] (**) |-->Screen "Default Screen Section" (0)
[   558.724] (**) |   |-->Monitor "<default monitor>"
[   558.724] (==) No monitor specified for screen "Default Screen Section".
[   558.724] (==) Automatically adding devices
[   558.724] (==) Automatically enabling devices
[   558.724] (==) Automatically adding GPU devices
[   558.724] (==) Automatically binding GPU devices
[   558.724] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   558.724] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[   558.724] 	Entry deleted from font path.
[   558.724] (==) FontPath set to:
[   558.724] (==) ModulePath set to "/usr/lib/xorg/modules"
[   558.724] (II) The server relies on udev to provide the list of input devices.
[   558.724] (II) Module ABI versions:
[   558.724] 	X.Org ANSI C Emulation: 0.4
[   558.724] 	X.Org Video Driver: 25.2
[   558.724] 	X.Org XInput driver : 24.4
[   558.724] 	X.Org Server Extension : 10.0
[   558.725] (++) using VT number 7
[   558.725] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[   558.726] (II) xfree86: Adding drm device (/dev/dri/card0)
[   558.726] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[   558.737] (--) PCI:*(0@0:2:0) 8086:46a6:103c:8978 rev 12, Mem @ 0x6000000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[   558.737] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[   558.738] (II) LoadModule: "glx"
[   558.738] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   558.739] (II) Module glx: vendor="X.Org Foundation"
[   558.739] 	compiled for 1.21.1.3, module version = 1.0.0
[   558.739] 	ABI class: X.Org Server Extension, version 10.0
[   558.739] (==) Matched modesetting as autoconfigured driver 0
[   558.739] (==) Matched fbdev as autoconfigured driver 1
[   558.739] (==) Matched vesa as autoconfigured driver 2
[   558.739] (==) Assigned the driver to the xf86ConfigLayout
[   558.739] (II) LoadModule: "modesetting"
[   558.739] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[   558.740] (II) Module modesetting: vendor="X.Org Foundation"
[   558.740] 	compiled for 1.21.1.3, module version = 1.21.1
[   558.740] 	Module class: X.Org Video Driver
[   558.740] 	ABI class: X.Org Video Driver, version 25.2
[   558.740] (II) LoadModule: "fbdev"
[   558.740] (WW) Warning, couldn't open module fbdev
[   558.740] (EE) Failed to load module "fbdev" (module does not exist, 0)
[   558.740] (II) LoadModule: "vesa"
[   558.740] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[   558.740] (II) Module vesa: vendor="X.Org Foundation"
[   558.740] 	compiled for 1.21.1.3, module version = 2.5.0
[   558.740] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[   558.740] (II) VESA: driver for VESA chipsets: vesa
[   558.751] (II) modeset(0): using drv /dev/dri/card0
[   558.751] (II) modeset(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[   558.751] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[   558.751] (==) modeset(0): RGB weight 888
[   558.751] (==) modeset(0): Default visual is TrueColor
[   558.751] (II) Loading sub module "glamoregl"
[   558.751] (II) LoadModule: "glamoregl"
[   558.752] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[   558.756] (II) Module glamoregl: vendor="X.Org Foundation"
[   558.756] 	compiled for 1.21.1.3, module version = 1.0.1
[   558.756] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   558.779] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) Graphics (ADL GT2)
[   558.779] (II) modeset(0): glamor initialized
[   558.779] (==) modeset(0): VariableRefresh: disabled
[   558.779] (==) modeset(0): AsyncFlipSecondaries: disabled
[   558.782] (II) modeset(0): Output eDP-1 has no monitor section
[   558.782] (II) modeset(0): Output HDMI-1 has no monitor section
[   558.783] (II) modeset(0): Output DP-1 has no monitor section
[   558.784] (II) modeset(0): Output DP-2 has no monitor section
[   558.785] (II) modeset(0): Output DP-3 has no monitor section
[   558.787] (II) modeset(0): Output DP-4 has no monitor section
[   558.790] (II) modeset(0): EDID for output eDP-1
[   558.790] (II) modeset(0): Manufacturer: AUO  Model: a08b  Serial#: 0
[   558.790] (II) modeset(0): Year: 2019  Week: 0
[   558.790] (II) modeset(0): EDID Version: 1.4
[   558.790] (II) modeset(0): Digital Display Input
[   558.790] (II) modeset(0): 8 bits per channel
[   558.790] (II) modeset(0): Digital interface is DisplayPort
[   558.790] (II) modeset(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[   558.790] (II) modeset(0): Gamma: 2.20
[   558.790] (II) modeset(0): No DPMS capabilities specified
[   558.790] (II) modeset(0): Supported color encodings: RGB 4:4:4
[   558.790] (II) modeset(0): First detailed timing is preferred mode
[   558.790] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[   558.790] (II) modeset(0): Display is continuous-frequency
[   558.790] (II) modeset(0): redX: 0.566 redY: 0.339   greenX: 0.351 greenY: 0.568
[   558.790] (II) modeset(0): blueX: 0.158 blueY: 0.121   whiteX: 0.313 whiteY: 0.329
[   558.790] (II) modeset(0): Manufacturer's mask: 0
[   558.790] (II) modeset(0): Supported detailed timing:
[   558.790] (II) modeset(0): clock: 141.0 MHz   Image Size:  344 x 193 mm
[   558.790] (II) modeset(0): h_active: 1920  h_sync: 2028  h_sync_end 2076 h_blank_end 2100 h_border: 0
[   558.790] (II) modeset(0): v_active: 1080  v_sync: 1090  v_sync_end 1100 v_blanking: 1116 v_border: 0
[   558.790] (II) modeset(0): clock: 94.0 MHz   Image Size:  344 x 193 mm
[   558.790] (II) modeset(0): Unknown vendor-specific block 2
[   558.790] (II) modeset(0): EDID (in hex):
[   558.790] (II) modeset(0): 	00ffffffffffff0006af8ba000000000
[   558.790] (II) modeset(0): 	001d0104a5221378033e859156599128
[   558.790] (II) modeset(0): 	1f505400000001010101010101010101
[   558.790] (II) modeset(0): 	010101010101143780b4703824406c30
[   558.790] (II) modeset(0): 	aa0058c110000018b82480b470382440
[   558.790] (II) modeset(0): 	6c30aa0058c110000018000000000000
[   558.790] (II) modeset(0): 	00000000000000000000000000000002
[   558.790] (II) modeset(0): 	001430ff123cc80b0719c820202000bd
[   558.790] (II) modeset(0): Printing probed modes for output eDP-1
[   558.790] (II) modeset(0): Modeline "1920x1080"x60.2  141.00  1920 2028 2076 2100  1080 1090 1100 1116 -hsync -vsync (67.1 kHz eP)
[   558.790] (II) modeset(0): Modeline "1920x1080"x120.0  356.38  1920 2080 2288 2656  1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[   558.790] (II) modeset(0): Modeline "1920x1080"x119.9  266.50  1920 1944 1960 2000  1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[   558.790] (II) modeset(0): Modeline "1920x1080"x60.0  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[   558.790] (II) modeset(0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[   558.790] (II) modeset(0): Modeline "1920x1080"x40.1   94.00  1920 2028 2076 2100  1080 1090 1100 1116 -hsync -vsync (44.8 kHz e)
[   558.790] (II) modeset(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[   558.790] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[   558.790] (II) modeset(0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[   558.790] (II) modeset(0): Modeline "1600x900"x120.0  246.00  1600 1728 1900 2200  900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[   558.790] (II) modeset(0): Modeline "1600x900"x119.9  186.50  1600 1624 1640 1680  900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[   558.790] (II) modeset(0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz d)
[   558.790] (II) modeset(0): Modeline "1600x900"x59.8   97.50  1600 1648 1680 1760  900 903 908 926 +hsync -vsync (55.4 kHz d)
[   558.790] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[   558.790] (II) modeset(0): Modeline "1400x900"x60.0  103.50  1400 1480 1624 1848  900 903 913 934 -hsync +vsync (56.0 kHz d)
[   558.790] (II) modeset(0): Modeline "1400x900"x59.9   86.50  1400 1448 1480 1560  900 903 913 926 +hsync -vsync (55.4 kHz d)
[   558.790] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[   558.790] (II) modeset(0): Modeline "1440x810"x120.0  198.12  1440 1548 1704 1968  810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[   558.790] (II) modeset(0): Modeline "1440x810"x119.9  151.88  1440 1464 1480 1520  810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[   558.790] (II) modeset(0): Modeline "1368x768"x59.9   85.25  1368 1440 1576 1784  768 771 781 798 -hsync +vsync (47.8 kHz d)
[   558.790] (II) modeset(0): Modeline "1368x768"x59.9   72.25  1368 1416 1448 1528  768 771 781 790 +hsync -vsync (47.3 kHz d)
[   558.790] (II) modeset(0): Modeline "1280x800"x120.0  174.25  1280 1380 1516 1752  800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[   558.790] (II) modeset(0): Modeline "1280x800"x119.9  134.25  1280 1304 1320 1360  800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[   558.790] (II) modeset(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz d)
[   558.790] (II) modeset(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz d)
[   558.790] (II) modeset(0): Modeline "1280x720"x120.0  156.12  1280 1376 1512 1744  720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[   558.790] (II) modeset(0): Modeline "1280x720"x120.0  120.75  1280 1304 1320 1360  720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[   558.790] (II) modeset(0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz d)
[   558.790] (II) modeset(0): Modeline "1280x720"x59.7   63.75  1280 1328 1360 1440  720 723 728 741 +hsync -vsync (44.3 kHz d)
[   558.790] (II) modeset(0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[   558.790] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[   558.790] (II) modeset(0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[   558.790] (II) modeset(0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[   558.790] (II) modeset(0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[   558.790] (II) modeset(0): Modeline "1024x576"x119.9   98.50  1024 1092 1200 1376  576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[   558.790] (II) modeset(0): Modeline "1024x576"x119.9   78.38  1024 1048 1064 1104  576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[   558.790] (II) modeset(0): Modeline "1024x576"x59.9   46.50  1024 1064 1160 1296  576 579 584 599 -hsync +vsync (35.9 kHz d)
[   558.790] (II) modeset(0): Modeline "1024x576"x59.8   42.00  1024 1072 1104 1184  576 579 584 593 +hsync -vsync (35.5 kHz d)
[   558.790] (II) modeset(0): Modeline "960x600"x119.9   96.62  960 1028 1128 1296  600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[   558.790] (II) modeset(0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[   558.790] (II) modeset(0): Modeline "960x540"x119.9   86.50  960 1024 1124 1288  540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[   558.790] (II) modeset(0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[   558.790] (II) modeset(0): Modeline "960x540"x59.6   40.75  960 992 1088 1216  540 543 548 562 -hsync +vsync (33.5 kHz d)
[   558.790] (II) modeset(0): Modeline "960x540"x59.8   37.25  960 1008 1040 1120  540 543 548 556 +hsync -vsync (33.3 kHz d)
[   558.790] (II) modeset(0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[   558.790] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[   558.790] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[   558.790] (II) modeset(0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[   558.790] (II) modeset(0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[   558.790] (II) modeset(0): Modeline "864x486"x59.9   32.50  864 888 968 1072  486 489 494 506 -hsync +vsync (30.3 kHz d)
[   558.790] (II) modeset(0): Modeline "864x486"x59.6   30.50  864 912 944 1024  486 489 494 500 +hsync -vsync (29.8 kHz d)
[   558.790] (II) modeset(0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[   558.790] (II) modeset(0): Modeline "800x450"x119.9   59.12  800 848 928 1056  450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[   558.790] (II) modeset(0): Modeline "800x450"x119.6   48.75  800 824 840 880  450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[   558.790] (II) modeset(0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[   558.790] (II) modeset(0): Modeline "700x450"x119.9   51.75  700 740 812 924  450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[   558.790] (II) modeset(0): Modeline "700x450"x119.8   43.25  700 724 740 780  450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[   558.790] (II) modeset(0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[   558.790] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[   558.790] (II) modeset(0): Modeline "720x405"x59.5   22.50  720 744 808 896  405 408 413 422 -hsync +vsync (25.1 kHz d)
[   558.790] (II) modeset(0): Modeline "720x405"x59.0   21.75  720 768 800 880  405 408 413 419 +hsync -vsync (24.7 kHz d)
[   558.790] (II) modeset(0): Modeline "684x384"x119.8   42.62  684 720 788 892  384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[   558.790] (II) modeset(0): Modeline "684x384"x119.7   36.12  684 708 724 764  384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[   558.790] (II) modeset(0): Modeline "640x400"x119.8   41.75  640 676 740 840  400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[   558.790] (II) modeset(0): Modeline "640x400"x120.0   35.50  640 664 680 720  400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[   558.790] (II) modeset(0): Modeline "640x360"x119.7   37.25  640 672 736 832  360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[   558.790] (II) modeset(0): Modeline "640x360"x119.7   31.88  640 664 680 720  360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[   558.790] (II) modeset(0): Modeline "640x360"x59.8   18.00  640 664 720 800  360 363 368 376 -hsync +vsync (22.5 kHz d)
[   558.790] (II) modeset(0): Modeline "640x360"x59.3   17.75  640 688 720 800  360 363 368 374 +hsync -vsync (22.2 kHz d)
[   558.790] (II) modeset(0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[   558.790] (II) modeset(0): Modeline "512x288"x120.0   23.25  512 532 580 648  288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[   558.790] (II) modeset(0): Modeline "512x288"x119.8   21.00  512 536 552 592  288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[   558.791] (II) modeset(0): Modeline "480x270"x119.3   20.38  480 496 544 608  270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[   558.791] (II) modeset(0): Modeline "480x270"x119.6   18.62  480 504 520 560  270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[   558.791] (II) modeset(0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[   558.791] (II) modeset(0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[   558.791] (II) modeset(0): Modeline "432x243"x119.8   16.25  432 444 484 536  243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[   558.791] (II) modeset(0): Modeline "432x243"x119.1   15.25  432 456 472 512  243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[   558.791] (II) modeset(0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[   558.791] (II) modeset(0): Modeline "360x202"x119.0   11.25  360 372 404 448  202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[   558.791] (II) modeset(0): Modeline "360x202"x118.3   10.88  360 384 400 440  202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[   558.791] (II) modeset(0): Modeline "320x180"x119.7    9.00  320 332 360 400  180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[   558.791] (II) modeset(0): Modeline "320x180"x118.6    8.88  320 344 360 400  180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[   558.791] (II) modeset(0): EDID for output HDMI-1
[   558.791] (II) modeset(0): EDID for output DP-1
[   558.792] (II) modeset(0): EDID for output DP-2
[   558.794] (II) modeset(0): EDID for output DP-3
[   558.795] (II) modeset(0): EDID for output DP-4
[   558.795] (II) modeset(0): Output eDP-1 connected
[   558.795] (II) modeset(0): Output HDMI-1 disconnected
[   558.795] (II) modeset(0): Output DP-1 disconnected
[   558.795] (II) modeset(0): Output DP-2 disconnected
[   558.795] (II) modeset(0): Output DP-3 disconnected
[   558.795] (II) modeset(0): Output DP-4 disconnected
[   558.795] (II) modeset(0): Using exact sizes for initial modes
[   558.795] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[   558.795] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[   558.795] (==) modeset(0): DPI set to (96, 96)
[   558.795] (II) Loading sub module "fb"
[   558.795] (II) LoadModule: "fb"
[   558.795] (II) Module "fb" already built-in
[   558.795] (II) UnloadModule: "vesa"
[   558.795] (II) Unloading vesa
[   558.807] (==) modeset(0): Backing store enabled
[   558.807] (==) modeset(0): Silken mouse enabled
[   558.886] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[   558.886] (==) modeset(0): DPMS enabled
[   558.886] (II) modeset(0): [DRI2] Setup complete
[   558.886] (II) modeset(0): [DRI2]   DRI driver: iris
[   558.886] (II) modeset(0): [DRI2]   VDPAU driver: va_gl
[   558.887] (II) Initializing extension Generic Event Extension
[   558.887] (II) Initializing extension SHAPE
[   558.887] (II) Initializing extension MIT-SHM
[   558.887] (II) Initializing extension XInputExtension
[   558.888] (II) Initializing extension XTEST
[   558.888] (II) Initializing extension BIG-REQUESTS
[   558.888] (II) Initializing extension SYNC
[   558.888] (II) Initializing extension XKEYBOARD
[   558.889] (II) Initializing extension XC-MISC
[   558.889] (II) Initializing extension SECURITY
[   558.889] (II) Initializing extension XFIXES
[   558.889] (II) Initializing extension RENDER
[   558.889] (II) Initializing extension RANDR
[   558.889] (II) Initializing extension COMPOSITE
[   558.890] (II) Initializing extension DAMAGE
[   558.890] (II) Initializing extension MIT-SCREEN-SAVER
[   558.890] (II) Initializing extension DOUBLE-BUFFER
[   558.890] (II) Initializing extension RECORD
[   558.890] (II) Initializing extension DPMS
[   558.890] (II) Initializing extension Present
[   558.890] (II) Initializing extension DRI3
[   558.890] (II) Initializing extension X-Resource
[   558.890] (II) Initializing extension XVideo
[   558.890] (II) Initializing extension XVideo-MotionCompensation
[   558.890] (II) Initializing extension GLX
[   558.897] (II) AIGLX: Loaded and initialized iris
[   558.897] (II) GLX: Initialized DRI2 GL provider for screen 0
[   558.897] (II) Initializing extension XFree86-VidModeExtension
[   558.897] (II) Initializing extension XFree86-DGA
[   558.897] (II) Initializing extension XFree86-DRI
[   558.897] (II) Initializing extension DRI2
[   558.898] (II) modeset(0): Damage tracking initialized
[   558.898] (II) modeset(0): Setting screen physical size to 508 x 285
[   558.947] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[   558.947] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   558.947] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[   558.947] (**) Power Button: Applying InputClass "system-keyboard"
[   558.947] (II) LoadModule: "libinput"
[   558.947] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[   558.948] (II) Module libinput: vendor="X.Org Foundation"
[   558.948] 	compiled for 1.21.1.3, module version = 1.2.1
[   558.948] 	Module class: X.Org XInput Driver
[   558.948] 	ABI class: X.Org XInput driver, version 24.4
[   558.948] (II) Using input driver 'libinput' for 'Power Button'
[   558.948] (**) Power Button: always reports core events
[   558.948] (**) Option "Device" "/dev/input/event2"
[   558.949] (II) event2  - Power Button: is tagged by udev as: Keyboard
[   558.949] (II) event2  - Power Button: device is a keyboard
[   558.949] (II) event2  - Power Button: device removed
[   558.973] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[   558.973] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[   558.973] (**) Option "xkb_model" "pc105"
[   558.973] (**) Option "xkb_layout" "cn"
[   558.990] (II) event2  - Power Button: is tagged by udev as: Keyboard
[   558.990] (II) event2  - Power Button: device is a keyboard
[   558.991] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[   558.991] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[   558.991] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[   558.991] (**) Video Bus: Applying InputClass "system-keyboard"
[   558.991] (II) Using input driver 'libinput' for 'Video Bus'
[   558.991] (**) Video Bus: always reports core events
[   558.991] (**) Option "Device" "/dev/input/event5"
[   558.991] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[   558.991] (II) event5  - Video Bus: device is a keyboard
[   558.991] (II) event5  - Video Bus: device removed
[   559.039] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5/event5"
[   559.039] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[   559.039] (**) Option "xkb_model" "pc105"
[   559.039] (**) Option "xkb_layout" "cn"
[   559.041] (II) event5  - Video Bus: is tagged by udev as: Keyboard
[   559.041] (II) event5  - Video Bus: device is a keyboard
[   559.042] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[   559.042] (II) No input driver specified, ignoring this device.
[   559.042] (II) This device may have been added with another device file.
[   559.042] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[   559.042] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[   559.042] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[   559.042] (**) Sleep Button: Applying InputClass "system-keyboard"
[   559.042] (II) Using input driver 'libinput' for 'Sleep Button'
[   559.042] (**) Sleep Button: always reports core events
[   559.042] (**) Option "Device" "/dev/input/event0"
[   559.043] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[   559.043] (II) event0  - Sleep Button: device is a keyboard
[   559.043] (II) event0  - Sleep Button: device removed
[   559.086] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[   559.086] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[   559.086] (**) Option "xkb_model" "pc105"
[   559.086] (**) Option "xkb_layout" "cn"
[   559.088] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[   559.088] (II) event0  - Sleep Button: device is a keyboard
[   559.090] (II) config/udev: Adding input device HP HD Camera: HP HD Camera (/dev/input/event17)
[   559.090] (**) HP HD Camera: HP HD Camera: Applying InputClass "evdev keyboard catchall"
[   559.090] (**) HP HD Camera: HP HD Camera: Applying InputClass "libinput keyboard catchall"
[   559.090] (**) HP HD Camera: HP HD Camera: Applying InputClass "system-keyboard"
[   559.090] (II) Using input driver 'libinput' for 'HP HD Camera: HP HD Camera'
[   559.090] (**) HP HD Camera: HP HD Camera: always reports core events
[   559.090] (**) Option "Device" "/dev/input/event17"
[   559.092] (II) event17 - HP HD Camera: HP HD Camera: is tagged by udev as: Keyboard
[   559.092] (II) event17 - HP HD Camera: HP HD Camera: device is a keyboard
[   559.092] (II) event17 - HP HD Camera: HP HD Camera: device removed
[   559.139] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.0/input/input21/event17"
[   559.139] (II) XINPUT: Adding extended input device "HP HD Camera: HP HD Camera" (type: KEYBOARD, id 9)
[   559.139] (**) Option "xkb_model" "pc105"
[   559.139] (**) Option "xkb_layout" "cn"
[   559.141] (II) event17 - HP HD Camera: HP HD Camera: is tagged by udev as: Keyboard
[   559.141] (II) event17 - HP HD Camera: HP HD Camera: device is a keyboard
[   559.142] (II) config/udev: Adding input device HP HD Camera: HP IR Camera (/dev/input/event18)
[   559.142] (**) HP HD Camera: HP IR Camera: Applying InputClass "evdev keyboard catchall"
[   559.142] (**) HP HD Camera: HP IR Camera: Applying InputClass "libinput keyboard catchall"
[   559.142] (**) HP HD Camera: HP IR Camera: Applying InputClass "system-keyboard"
[   559.142] (II) Using input driver 'libinput' for 'HP HD Camera: HP IR Camera'
[   559.142] (**) HP HD Camera: HP IR Camera: always reports core events
[   559.142] (**) Option "Device" "/dev/input/event18"
[   559.143] (II) event18 - HP HD Camera: HP IR Camera: is tagged by udev as: Keyboard
[   559.143] (II) event18 - HP HD Camera: HP IR Camera: device is a keyboard
[   559.144] (II) event18 - HP HD Camera: HP IR Camera: device removed
[   559.192] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.2/input/input22/event18"
[   559.193] (II) XINPUT: Adding extended input device "HP HD Camera: HP IR Camera" (type: KEYBOARD, id 10)
[   559.193] (**) Option "xkb_model" "pc105"
[   559.193] (**) Option "xkb_layout" "cn"
[   559.195] (II) event18 - HP HD Camera: HP IR Camera: is tagged by udev as: Keyboard
[   559.195] (II) event18 - HP HD Camera: HP IR Camera: device is a keyboard
[   559.196] (II) config/udev: Adding input device USB OPTICAL MOUSE  (/dev/input/event4)
[   559.196] (**) USB OPTICAL MOUSE : Applying InputClass "evdev pointer catchall"
[   559.196] (**) USB OPTICAL MOUSE : Applying InputClass "libinput pointer catchall"
[   559.196] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE '
[   559.196] (**) USB OPTICAL MOUSE : always reports core events
[   559.196] (**) Option "Device" "/dev/input/event4"
[   559.255] (II) event4  - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[   559.255] (II) event4  - USB OPTICAL MOUSE : device is a pointer
[   559.256] (II) event4  - USB OPTICAL MOUSE : device removed
[   559.312] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-6/3-6:1.0/0003:28A0:1185.0001/input/input4/event4"
[   559.313] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE " (type: MOUSE, id 11)
[   559.313] (**) Option "AccelerationScheme" "none"
[   559.313] (**) USB OPTICAL MOUSE : (accel) selected scheme none/0
[   559.313] (**) USB OPTICAL MOUSE : (accel) acceleration factor: 2.000
[   559.313] (**) USB OPTICAL MOUSE : (accel) acceleration threshold: 4
[   559.371] (II) event4  - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[   559.372] (II) event4  - USB OPTICAL MOUSE : device is a pointer
[   559.373] (II) config/udev: Adding input device USB OPTICAL MOUSE  (/dev/input/mouse0)
[   559.373] (II) No input driver specified, ignoring this device.
[   559.373] (II) This device may have been added with another device file.
[   559.374] (II) config/udev: Adding input device ELAN076D:00 04F3:3244 Mouse (/dev/input/event8)
[   559.374] (**) ELAN076D:00 04F3:3244 Mouse: Applying InputClass "evdev pointer catchall"
[   559.374] (**) ELAN076D:00 04F3:3244 Mouse: Applying InputClass "libinput pointer catchall"
[   559.374] (II) Using input driver 'libinput' for 'ELAN076D:00 04F3:3244 Mouse'
[   559.374] (**) ELAN076D:00 04F3:3244 Mouse: always reports core events
[   559.374] (**) Option "Device" "/dev/input/event8"
[   559.375] (II) event8  - ELAN076D:00 04F3:3244 Mouse: is tagged by udev as: Mouse Pointingstick
[   559.375] (II) event8  - ELAN076D:00 04F3:3244 Mouse: device is a pointer
[   559.376] (II) event8  - ELAN076D:00 04F3:3244 Mouse: device removed
[   559.419] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN076D:00/0018:04F3:3244.0002/input/input12/event8"
[   559.419] (II) XINPUT: Adding extended input device "ELAN076D:00 04F3:3244 Mouse" (type: MOUSE, id 12)
[   559.419] (**) Option "AccelerationScheme" "none"
[   559.419] (**) ELAN076D:00 04F3:3244 Mouse: (accel) selected scheme none/0
[   559.419] (**) ELAN076D:00 04F3:3244 Mouse: (accel) acceleration factor: 2.000
[   559.419] (**) ELAN076D:00 04F3:3244 Mouse: (accel) acceleration threshold: 4
[   559.421] (II) event8  - ELAN076D:00 04F3:3244 Mouse: is tagged by udev as: Mouse Pointingstick
[   559.422] (II) event8  - ELAN076D:00 04F3:3244 Mouse: device is a pointer
[   559.424] (II) config/udev: Adding input device ELAN076D:00 04F3:3244 Mouse (/dev/input/mouse1)
[   559.424] (II) No input driver specified, ignoring this device.
[   559.424] (II) This device may have been added with another device file.
[   559.424] (II) config/udev: Adding input device ELAN076D:00 04F3:3244 Touchpad (/dev/input/event9)
[   559.424] (**) ELAN076D:00 04F3:3244 Touchpad: Applying InputClass "evdev touchpad catchall"
[   559.424] (**) ELAN076D:00 04F3:3244 Touchpad: Applying InputClass "libinput touchpad catchall"
[   559.424] (II) Using input driver 'libinput' for 'ELAN076D:00 04F3:3244 Touchpad'
[   559.424] (**) ELAN076D:00 04F3:3244 Touchpad: always reports core events
[   559.424] (**) Option "Device" "/dev/input/event9"
[   559.426] (II) event9  - ELAN076D:00 04F3:3244 Touchpad: is tagged by udev as: Touchpad
[   559.427] (II) event9  - ELAN076D:00 04F3:3244 Touchpad: device is a touchpad
[   559.427] (II) event9  - ELAN076D:00 04F3:3244 Touchpad: device removed
[   559.473] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN076D:00/0018:04F3:3244.0002/input/input14/event9"
[   559.473] (II) XINPUT: Adding extended input device "ELAN076D:00 04F3:3244 Touchpad" (type: TOUCHPAD, id 13)
[   559.476] (**) Option "AccelerationScheme" "none"
[   559.476] (**) ELAN076D:00 04F3:3244 Touchpad: (accel) selected scheme none/0
[   559.476] (**) ELAN076D:00 04F3:3244 Touchpad: (accel) acceleration factor: 2.000
[   559.476] (**) ELAN076D:00 04F3:3244 Touchpad: (accel) acceleration threshold: 4
[   559.477] (II) event9  - ELAN076D:00 04F3:3244 Touchpad: is tagged by udev as: Touchpad
[   559.479] (II) event9  - ELAN076D:00 04F3:3244 Touchpad: device is a touchpad
[   559.480] (II) config/udev: Adding input device ELAN076D:00 04F3:3244 Touchpad (/dev/input/mouse2)
[   559.480] (II) No input driver specified, ignoring this device.
[   559.480] (II) This device may have been added with another device file.
[   559.481] (II) config/udev: Adding input device sof-hda-dsp Mic (/dev/input/event12)
[   559.481] (II) No input driver specified, ignoring this device.
[   559.481] (II) This device may have been added with another device file.
[   559.481] (II) config/udev: Adding input device sof-hda-dsp Headphone (/dev/input/event13)
[   559.481] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=3 (/dev/input/event14)
[   559.482] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=4 (/dev/input/event15)
[   559.482] (II) No input driver specified, ignoring this device.
[   559.482] (II) This device may have been added with another device file.
[   559.482] (II) config/udev: Adding input device sof-hda-dsp HDMI/DP,pcm=5 (/dev/input/event16)
[   559.482] (II) config/udev: Adding input device Intel HID events (/dev/input/event6)
[   559.482] (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
[   559.482] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[   559.482] (**) Intel HID events: Applying InputClass "system-keyboard"
[   559.482] (II) Using input driver 'libinput' for 'Intel HID events'
[   559.482] (**) Intel HID events: always reports core events
[   559.482] (**) Option "Device" "/dev/input/event6"
[   559.483] (II) event6  - Intel HID events: is tagged by udev as: Keyboard
[   559.483] (II) event6  - Intel HID events: device is a keyboard
[   559.483] (II) event6  - Intel HID events: device removed
[   559.496] (**) Option "config_info" "udev:/sys/devices/platform/INTC1070:00/input/input6/event6"
[   559.496] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 14)
[   559.496] (**) Option "xkb_model" "pc105"
[   559.496] (**) Option "xkb_layout" "cn"
[   559.497] (II) event6  - Intel HID events: is tagged by udev as: Keyboard
[   559.497] (II) event6  - Intel HID events: device is a keyboard
[   559.498] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event7)
[   559.498] (**) Intel HID 5 button array: Applying InputClass "evdev keyboard catchall"
[   559.498] (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
[   559.498] (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
[   559.498] (II) Using input driver 'libinput' for 'Intel HID 5 button array'
[   559.498] (**) Intel HID 5 button array: always reports core events
[   559.498] (**) Option "Device" "/dev/input/event7"
[   559.498] (II) event7  - Intel HID 5 button array: is tagged by udev as: Keyboard
[   559.498] (II) event7  - Intel HID 5 button array: device is a keyboard
[   559.499] (II) event7  - Intel HID 5 button array: device removed
[   559.526] (**) Option "config_info" "udev:/sys/devices/platform/INTC1070:00/input/input7/event7"
[   559.526] (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 15)
[   559.526] (**) Option "xkb_model" "pc105"
[   559.526] (**) Option "xkb_layout" "cn"
[   559.527] (II) event7  - Intel HID 5 button array: is tagged by udev as: Keyboard
[   559.527] (II) event7  - Intel HID 5 button array: device is a keyboard
[   559.528] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[   559.528] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[   559.528] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[   559.528] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[   559.528] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[   559.528] (**) AT Translated Set 2 keyboard: always reports core events
[   559.528] (**) Option "Device" "/dev/input/event3"
[   559.529] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[   559.529] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[   559.530] (II) event3  - AT Translated Set 2 keyboard: device removed
[   559.549] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[   559.549] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[   559.549] (**) Option "xkb_model" "pc105"
[   559.549] (**) Option "xkb_layout" "cn"
[   559.550] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[   559.551] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[   559.552] (II) config/udev: Adding input device PC Speaker (/dev/input/event10)
[   559.552] (II) No input driver specified, ignoring this device.
[   559.552] (II) This device may have been added with another device file.
[   559.554] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event11)
[   559.554] (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[   559.554] (**) HP WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[   559.554] (**) HP WMI hotkeys: Applying InputClass "system-keyboard"
[   559.554] (II) Using input driver 'libinput' for 'HP WMI hotkeys'
[   559.554] (**) HP WMI hotkeys: always reports core events
[   559.554] (**) Option "Device" "/dev/input/event11"
[   559.555] (II) event11 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[   559.555] (II) event11 - HP WMI hotkeys: device is a keyboard
[   559.555] (II) event11 - HP WMI hotkeys: device removed
[   559.602] (**) Option "config_info" "udev:/sys/devices/virtual/input/input15/event11"
[   559.603] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 17)
[   559.603] (**) Option "xkb_model" "pc105"
[   559.603] (**) Option "xkb_layout" "cn"
[   559.604] (II) event11 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[   559.604] (II) event11 - HP WMI hotkeys: device is a keyboard
[   559.724] (II) event2  - Power Button: device removed
[   559.749] (II) event5  - Video Bus: device removed
[   559.809] (II) event0  - Sleep Button: device removed
[   559.846] (II) event17 - HP HD Camera: HP HD Camera: device removed
[   559.899] (II) event18 - HP HD Camera: HP IR Camera: device removed
[   559.952] (II) event4  - USB OPTICAL MOUSE : device removed
[   560.006] (II) event8  - ELAN076D:00 04F3:3244 Mouse: device removed
[   560.059] (II) event9  - ELAN076D:00 04F3:3244 Touchpad: device removed
[   560.112] (II) event6  - Intel HID events: device removed
[   560.136] (II) event7  - Intel HID 5 button array: device removed
[   560.166] (II) event3  - AT Translated Set 2 keyboard: device removed
[   560.189] (II) event11 - HP WMI hotkeys: device removed
[   560.268] (II) UnloadModule: "libinput"
[   560.269] (II) UnloadModule: "libinput"
[   560.270] (II) UnloadModule: "libinput"
[   560.355] (II) Server terminated successfully (0). Closing log file.
provide output again from:
mhwd -li
[manjaro /]# mhwd -li
           video-linux            2018.05.04                true            PCI
[manjaro /]# find /etc/X11/ -name "*.conf"
/etc/X11/xorg.conf.d/00-keyboard.conf
so reinstall the drivers:
sudo mhwd -r pci video-linux
sudo mhwd -a pci free 0300
