Can't run docker containers and docker-desktop
Hello community, i am in need of your help in installing docker and docker-desktop in ManjaroLinux. My distro version is 22.1.0.
I have tried installing docker using pacman and starting the docker service using
systemctl start docker
systemctl enable docker
But I am not able to run any containers. With error
docker: Error response from daemon: failed to create shim task: OCI runtime create failed: unable to retrieve OCI runtime error
Docker-desktop: I try to install it using the links provided in the docker - docs
But when I run the application, it is stuck in an endless loop in the “docker engine starting”… screen.
Please find my system details below -
  Kernel: 6.1.23-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=62f9cd88-112d-4f2d-a85e-e1abdb40ac47 rw nouveau.modeset=0 quiet
    apparmor=1 security=apparmor
    resume=UUID=99fc02aa-c61b-4ee8-9764-5958d39454f6 udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 3.60
    date: 04/22/2020
  RAM: total: 31.3 GiB used: 3.66 GiB (11.7%)
  Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
    desc: 2x16 MiB
  Speed (MHz): avg: 2484 high: 4193 min/max: 2200/4409 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3596 2: 2200
    3: 2200 4: 4193 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2101
    12: 2326 bogomips: 91244
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Micro-Star MSI
    driver: nvidia v: 470.182.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-03) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 26:00.0 chip-ID: 10de:2182 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
    s-diag: 693mm (27.28")
  Monitor-1: DP-2 res: 1920x1080 hz: 60 dpi: 82
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 470.182.03 renderer: NVIDIA GeForce GTX 1660
    Ti/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 26:00.1 chip-ID: 10de:1aeb class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.1.23-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-2: PipeWire v: 0.3.68 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: pulseaudio-jack
    type: module tools: pacat,pactl
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: br-1f56cb436e76 state: down mac: <filter>
  IF-ID-2: br-6e76af770562 state: down mac: <filter>
  IF-ID-3: docker0 state: down mac: <filter>
  Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
    all]
  Local Storage: total: 2.11 TiB used: 78.12 GiB (3.6%)
    model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
    rev: 233010WD temp: 43.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST31000528AS
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: CC38 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500DM002-1BD142
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: KC44 scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD3200AAJS-00L7A0 size: 298.09 GiB block-size: physical: 512 B
    logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 3E01
    scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH22NS50 rev: TN03
    dev-links: cdrom
  ID-1: / raw-size: 263.36 GiB size: 258.17 GiB (98.03%)
    used: 78.12 GiB (30.3%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
    uuid: 62f9cd88-112d-4f2d-a85e-e1abdb40ac47
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: NO_LABEL
    uuid: D49C-6B25
  ID-1: swap-1 type: partition size: 34.43 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sdc3 maj-min: 8:35 label: swap
    uuid: 99fc02aa-c61b-4ee8-9764-5958d39454f6
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: BE73-9F0C
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 255.34 GiB fs: ntfs
    label: Windows uuid: 5E40771B4076F95B
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 673 MiB fs: ntfs label: N/A
    uuid: 768ED1088ED0C1B3
  ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 209.15 GiB fs: ntfs
    label: Data-SSD-I uuid: 44DC4C6CDC4C5A76
  ID-6: /dev/nvme0n1p6 maj-min: 259:6 size: 508 MiB fs: ntfs label: N/A
    uuid: 2840B61A40B5EEA6
  ID-7: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs
    label: FreeAgent Drive uuid: 52181CD9181CBE43
  ID-8: /dev/sdb1 maj-min: 8:17 size: 300 GiB fs: ntfs label: Ext-500G-I
    uuid: 7CE4762EE475EB32
  ID-9: /dev/sdb2 maj-min: 8:18 size: 165.76 GiB fs: ntfs label: Ext-500G-II
    uuid: CCA85591A8557B42
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 1-2:2 info: Microdia Redragon Mitra RGB Keyboard
    type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 400mA chip-ID: 0c45:5004 class-ID: 0301
  Device-2: 1-7:3 info: Logitech Unifying Receiver type: Keyboard,Mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 98mA chip-ID: 046d:c534 class-ID: 0301
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 72.5 C mobo: N/A
  Processes: 294 Uptime: 1h 13m wakeups: 0 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: 1679 pm: pacman pkgs: 1655 libs: 403 tools: pamac,yay pm: flatpak
  pkgs: 0 pm: snap pkgs: 24 Shell: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.26
Output of docker info :
Client:
 Context:    default
 Debug Mode: false
Server:
 Containers: 0
  Running: 0
  Paused: 0
  Stopped: 0
 Images: 2
 Server Version: 23.0.3
 Storage Driver: overlay2
  Backing Filesystem: extfs
  Supports d_type: true
  Using metacopy: true
  Native Overlay Diff: false
  userxattr: false
 Logging Driver: json-file
 Cgroup Driver: systemd
 Cgroup Version: 2
 Plugins:
  Volume: local
  Network: bridge host ipvlan macvlan null overlay
  Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog
 Swarm: inactive
 Runtimes: io.containerd.runc.v2 runc
 Default Runtime: runc
 Init Binary: docker-init
 containerd version: 1fbd70374134b891f97ce19c70b6e50c7b9f4e0d.m
 runc version: N/A
 init version: de40ad0
 Security Options:
  apparmor
  seccomp
   Profile: builtin
  cgroupns
 Kernel Version: 6.1.23-1-MANJARO
 OSType: linux
 Architecture: x86_64
 CPUs: 12
 Total Memory: 31.3GiB
 Docker Root Dir: /var/lib/docker
 Debug Mode: false
 Registry: https://index.docker.io/v1/
 Experimental: false
 Insecure Registries:
  127.0.0.0/8
 Live Restore Enabled: false
Is it because of the "“runc version: N/A” above?
Any help in getting this to work is much appreciated.
Hi,
To get docker working i use these commands
sudo pacman -S --noconfirm docker docker-compose
sudo systemctl start docker.service;sudo systemctl enable docker.service
sudo usermod -aG docker $USER
after that make your docker-compose.yml
finally
sudo docker-compose up -d
Hope it works for you, i dont use docker-desktop so can’t help with that.
thanks for your response. I had tried these steps but could not get it to work.
however, I removed the installation and deleted the directories for docker. after installing and starting/enabling the service I restarted my system. don’t know if the restart was the issue but it started working magically.
I appreciate your suggestion though. have a good day.
thank you for your inputs… However, I had tried updating subuid and subgui, but could not get it to work.
Will check if there is any other alternative, as you rightly said, its difficult to get it to work properly.
