Command prime-run
working very well with all my apps, but darktable doesn’t, i think there is a issue is openCL, but i’m not sure. There is a log from terminal:
[New LWP 9043]
[New LWP 9044]
[New LWP 9045]
[New LWP 9046]
[New LWP 9047]
[New LWP 9048]
[New LWP 9049]
[New LWP 9050]
[New LWP 9051]
[New LWP 9052]
[New LWP 9053]
[New LWP 9054]
[New LWP 9055]
[New LWP 9056]
[New LWP 9057]
[New LWP 9059]
[New LWP 9060]
[New LWP 9061]
[New LWP 9062]
[New LWP 9063]
[New LWP 9064]
[New LWP 9065]
[New LWP 9066]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
0x00007fc041837eef in wait4 () from /usr/lib/libc.so.6
warning: Currently logging to /tmp/darktable_bt_HZHFS0.txt. Turn the logging off and on to make the new setting effective.
#0 0x00007fc041837eef in wait4 () at /usr/lib/libc.so.6
#1 0x00007fc041a62b22 in () at /usr/lib/libdarktable.so
#2 0x00007fc0417a86a0 in <signal handler called> () at /usr/lib/libc.so.6
#3 0x00007fbfe1631217 in () at /usr/lib/libigc.so.1
#4 0x00007fbfe1632a2a in () at /usr/lib/libigc.so.1
#5 0x00007fbfe15d2c00 in () at /usr/lib/libigc.so.1
#6 0x00007fbfe15d2e5b in () at /usr/lib/libigc.so.1
#7 0x00007fbfe14bdc10 in () at /usr/lib/libigc.so.1
#8 0x00007fbfe15533e8 in () at /usr/lib/libigc.so.1
#9 0x00007fbfe13e2934 in () at /usr/lib/libigc.so.1
#10 0x00007fbfe143614f in () at /usr/lib/libigc.so.1
#11 0x00007fbfe37005d8 in llvm::FPPassManager::runOnFunction(llvm::Function&) () at /usr/lib/libLLVM-10.so
#12 0x00007fbfe3701bdd in llvm::FPPassManager::runOnModule(llvm::Module&) () at /usr/lib/libLLVM-10.so
#13 0x00007fbfe3701f70 in llvm::legacy::PassManagerImpl::run(llvm::Module&) () at /usr/lib/libLLVM-10.so
#14 0x00007fbfe127edd4 in () at /usr/lib/libigc.so.1
#15 0x00007fbfe1258061 in () at /usr/lib/libigc.so.1
#16 0x00007fbfe113d994 in () at /usr/lib/libigc.so.1
#17 0x00007fbfe11f0bba in () at /usr/lib/libigc.so.1
#18 0x00007fc0285392ea in () at /usr/lib/intel-opencl/libigdrcl.so
#19 0x00007fc02833cd50 in () at /usr/lib/intel-opencl/libigdrcl.so
#20 0x00007fc0282d4a02 in () at /usr/lib/intel-opencl/libigdrcl.so
#21 0x00007fc041a47e48 in dt_opencl_build_program () at /usr/lib/libdarktable.so
#22 0x00007fc041a492b3 in () at /usr/lib/libdarktable.so
#23 0x00007fc041a4d0c0 in dt_opencl_init () at /usr/lib/libdarktable.so
#24 0x00007fc0419c91ed in dt_init () at /usr/lib/libdarktable.so
#25 0x000055d29298b037 in ()
#26 0x00007fc041793152 in __libc_start_main () at /usr/lib/libc.so.6
#27 0x000055d29298b08e in ()
Id Target Id Frame
* 1 Thread 0x7fc03ace6140 (LWP 9042) "darktable" 0x00007fc041837eef in wait4 () from /usr/lib/libc.so.6
2 Thread 0x7fc03a774640 (LWP 9043) "gmain" 0x00007fc04186046f in poll () from /usr/lib/libc.so.6
3 Thread 0x7fc039f73640 (LWP 9044) "pool" 0x00007fc041865d5d in syscall () from /usr/lib/libc.so.6
4 Thread 0x7fc039772640 (LWP 9045) "gdbus" 0x00007fc04186046f in poll () from /usr/lib/libc.so.6
5 Thread 0x7fc038cbd640 (LWP 9046) "worker 0" 0x00007fc0417586a2 in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
6 Thread 0x7fc02bfff640 (LWP 9047) "worker 1" 0x00007fc0417586a2 in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
7 Thread 0x7fc02b7fe640 (LWP 9048) "worker 2" 0x00007fc0417586a2 in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
8 Thread 0x7fc02affd640 (LWP 9049) "worker 3" 0x00007fc0417586a2 in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
9 Thread 0x7fc02a7fc640 (LWP 9050) "worker 4" 0x00007fc0417586a2 in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
10 Thread 0x7fc029ffb640 (LWP 9051) "worker 5" 0x00007fc0417586a2 in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
11 Thread 0x7fc0297fa640 (LWP 9052) "worker 6" 0x00007fc0417586a2 in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
12 Thread 0x7fc028ff9640 (LWP 9053) "worker 7" 0x00007fc0417586a2 in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
13 Thread 0x7fc00bfff640 (LWP 9054) "kicker" 0x00007fc041832c51 in clock_nanosleep@GLIBC_2.2.5 () from /usr/lib/libc.so.6
14 Thread 0x7fc00b7fe640 (LWP 9055) "worker res 0" 0x00007fc0417586a2 in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
15 Thread 0x7fc00affd640 (LWP 9056) "worker res 1" 0x00007fc0417586a2 in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
16 Thread 0x7fc00a7fc640 (LWP 9057) "worker res 2" 0x00007fc0417586a2 in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
17 Thread 0x7fc008b3a640 (LWP 9059) "darktable" 0x00007fc0417586a2 in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
18 Thread 0x7fbfed6ab640 (LWP 9060) "cuda-EvtHandlr" 0x00007fc04186046f in poll () from /usr/lib/libc.so.6
19 Thread 0x7fbfeceaa640 (LWP 9061) "darktable" 0x00007fc0417589c8 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
20 Thread 0x7fbfe0ff4640 (LWP 9062) "darktable" 0x00007fc04175b014 in do_futex_wait.constprop () from /usr/lib/libpthread.so.0
21 Thread 0x7fbfcd0d1640 (LWP 9063) "darktable" 0x00007fc04175b014 in do_futex_wait.constprop () from /usr/lib/libpthread.so.0
22 Thread 0x7fbfcc8d0640 (LWP 9064) "darktable" 0x00007fc04175b014 in do_futex_wait.constprop () from /usr/lib/libpthread.so.0
23 Thread 0x7fbfc3fff640 (LWP 9065) "darktable" 0x00007fc04175b014 in do_futex_wait.constprop () from /usr/lib/libpthread.so.0
24 Thread 0x7fbfc37fe640 (LWP 9066) "darktable" 0x00007fc04175b014 in do_futex_wait.constprop () from /usr/lib/libpthread.so.0
Thread 24 (Thread 0x7fbfc37fe640 (LWP 9066)):
#0 0x00007fc04175b014 in do_futex_wait.constprop () at /usr/lib/libpthread.so.0
#1 0x00007fc04175b118 in __new_sem_wait_slow.constprop.0 () at /usr/lib/libpthread.so.0
#2 0x00007fbff9edbbf7 in () at /usr/lib/libnvidia-opencl.so.1
#3 0x00007fbff9d8a546 in () at /usr/lib/libnvidia-opencl.so.1
#4 0x00007fbff9ede5a8 in () at /usr/lib/libnvidia-opencl.so.1
#5 0x00007fc0417523e9 in start_thread () at /usr/lib/libpthread.so.0
#6 0x00007fc04186b293 in clone () at /usr/lib/libc.so.6
Thread 23 (Thread 0x7fbfc3fff640 (LWP 9065)):
Thread 22 (Thread 0x7fbfcc8d0640 (LWP 9064)):
Thread 21 (Thread 0x7fbfcd0d1640 (LWP 9063)):
Thread 20 (Thread 0x7fbfe0ff4640 (LWP 9062)):
Thread 19 (Thread 0x7fbfeceaa640 (LWP 9061)):
#0 0x00007fc0417589c8 in pthread_cond_timedwait@@GLIBC_2.3.2 () at /usr/lib/libpthread.so.0
#1 0x00007fbff9edf6b7 in () at /usr/lib/libnvidia-opencl.so.1
#2 0x00007fbff9e789e7 in () at /usr/lib/libnvidia-opencl.so.1
#3 0x00007fbff9ede5a8 in () at /usr/lib/libnvidia-opencl.so.1
#4 0x00007fc0417523e9 in start_thread () at /usr/lib/libpthread.so.0
#5 0x00007fc04186b293 in clone () at /usr/lib/libc.so.6
Thread 18 (Thread 0x7fbfed6ab640 (LWP 9060)):
#0 0x00007fc04186046f in poll () at /usr/lib/libc.so.6
#1 0x00007fbff9edb4ab in () at /usr/lib/libnvidia-opencl.so.1
#2 0x00007fbff9f9ba1a in () at /usr/lib/libnvidia-opencl.so.1
Thread 17 (Thread 0x7fc008b3a640 (LWP 9059)):
#0 0x00007fc0417586a2 in pthread_cond_wait@@GLIBC_2.3.2 () at /usr/lib/libpthread.so.0
#1 0x00007fc03ee91c11 in __gthread_cond_wait (__mutex=<optimized out>, __cond=<optimized out>) at /build/gcc/src/gcc-build/x86_64-pc-linux-gnu/libstdc++-v3/include/x86_64-pc-linux-gnu/bits/gthr-default.h:865
__e = <optimized out>
#2 std::condition_variable::wait(std::unique_lock<std::mutex>&) (this=<optimized out>, __lock=...) at /build/gcc/src/gcc/libstdc++-v3/src/c++11/condition_variable.cc:53
#3 0x00007fc0285ec20e in () at /usr/lib/intel-opencl/libigdrcl.so
Thread 16 (Thread 0x7fc00a7fc640 (LWP 9057)):
#1 0x00007fc041a7334e in () at /usr/lib/libdarktable.so
#2 0x00007fc0417523e9 in start_thread () at /usr/lib/libpthread.so.0
#3 0x00007fc04186b293 in clone () at /usr/lib/libc.so.6
Thread 15 (Thread 0x7fc00affd640 (LWP 9056)):
Thread 14 (Thread 0x7fc00b7fe640 (LWP 9055)):
Thread 13 (Thread 0x7fc00bfff640 (LWP 9054)):
#0 0x00007fc041832c51 in clock_nanosleep@GLIBC_2.2.5 () at /usr/lib/libc.so.6
#1 0x00007fc041838137 in nanosleep () at /usr/lib/libc.so.6
#2 0x00007fc04183806e in sleep () at /usr/lib/libc.so.6
#3 0x00007fc041a72efb in () at /usr/lib/libdarktable.so
Thread 12 (Thread 0x7fc028ff9640 (LWP 9053)):
#1 0x00007fc041a74689 in () at /usr/lib/libdarktable.so
Thread 11 (Thread 0x7fc0297fa640 (LWP 9052)):
Thread 10 (Thread 0x7fc029ffb640 (LWP 9051)):
Thread 9 (Thread 0x7fc02a7fc640 (LWP 9050)):
Thread 8 (Thread 0x7fc02affd640 (LWP 9049)):
Thread 7 (Thread 0x7fc02b7fe640 (LWP 9048)):
Thread 6 (Thread 0x7fc02bfff640 (LWP 9047)):
Thread 5 (Thread 0x7fc038cbd640 (LWP 9046)):
Thread 4 (Thread 0x7fc039772640 (LWP 9045)):
#1 0x00007fc041536188 in () at /usr/lib/libglib-2.0.so.0
#2 0x00007fc0414e4163 in g_main_loop_run () at /usr/lib/libglib-2.0.so.0
#3 0x00007fc040961fe8 in () at /usr/lib/libgio-2.0.so.0
#4 0x00007fc041511a91 in () at /usr/lib/libglib-2.0.so.0
Thread 3 (Thread 0x7fc039f73640 (LWP 9044)):
#0 0x00007fc041865d5d in syscall () at /usr/lib/libc.so.6
#1 0x00007fc0415320cb in g_cond_wait_until () at /usr/lib/libglib-2.0.so.0
#2 0x00007fc0414b4833 in () at /usr/lib/libglib-2.0.so.0
#3 0x00007fc0414b49c4 in g_async_queue_timeout_pop () at /usr/lib/libglib-2.0.so.0
#4 0x00007fc0415146ba in () at /usr/lib/libglib-2.0.so.0
#5 0x00007fc041511a91 in () at /usr/lib/libglib-2.0.so.0
#6 0x00007fc0417523e9 in start_thread () at /usr/lib/libpthread.so.0
#7 0x00007fc04186b293 in clone () at /usr/lib/libc.so.6
Thread 2 (Thread 0x7fc03a774640 (LWP 9043)):
#2 0x00007fc0414e3421 in g_main_context_iteration () at /usr/lib/libglib-2.0.so.0
#3 0x00007fc0414e3472 in () at /usr/lib/libglib-2.0.so.0
Thread 1 (Thread 0x7fc03ace6140 (LWP 9042)):
[Inferior 1 (process 9042) detached]
backtrace written to /tmp/darktable_bt_HZHFS0.txt
/usr/bin/prime-run: řádek 2: 9042 Neoprávněný přístup do paměti (SIGSEGV) (core dumped [obraz paměti uložen]) __NV_PRIME_RENDER_OFFLOAD=1 __VK_LAYER_NV_optimus=NVIDIA_only __GLX_VENDOR_LIBRARY_NAME=nvidia "$@"
