Hey,
I’m running the latest version of Manjaro ARM i3 on a Raspberry Pi3 (Raspberry Pi 4 I3 20.10). I can’t for the love of me get the screen to rotate. I recently switched from Manjaro Wayland to this version because of Synergy support.
What I tried:
- Using
xrandrto rotate the screen.xrandronly sees a “Default” screen and when I try to rotate it I get the error:$ xrandr --output default --rotate inverted xrandr: output default cannot use rotation "inverted" reflection "none" - Using
arandrto rotate the screen. This will show my desktop in the GUI tool but the options to Rotate are greyed out - Using the Raspberry PI config file at
/boot/config.txtto set the rotation. This does also not work.
I’m running the Stock version with no extra software. Any tips on how to get the screen to rotate?
