Can't resize partition
I’m using kde partition manager to extend my manjaro partition after shredding the one with Ubuntu but I get this error.
Grow partition ‘/dev/nvme0n1p8’ from 91,49 GiB to 231,16 GiB
Job: Set geometry of partition ‘/dev/nvme0n1p8’: Start sector: 458.043.392, length: 484.775.936
Command: sfdisk --force /dev/nvme0n1 -N 8
Set geometry of partition ‘/dev/nvme0n1p8’: Start sector: 458.043.392, length: 484.775.936: Success
Job: Resize file system on partition ‘/dev/nvme0n1p8’ to 484.775.936 sectors
Resizing file system from 191.873.024 to 484.775.936 sectors.
Command: resize2fs /dev/nvme0n1p8 484775936s
Resize file system on partition ‘/dev/nvme0n1p8’ to 484.775.936 sectors: Error
Resize/move failed: Could not resize the file system on partition ‘/dev/nvme0n1p8’
Job: Set geometry of partition ‘/dev/nvme0n1p8’: Start sector: 458.043.392, length: 191.873.024
Set geometry of partition ‘/dev/nvme0n1p8’: Start sector: 458.043.392, length: 191.873.024: Success
Resizing/moving partition ‘/dev/nvme0n1p8’ failed.
Grow partition ‘/dev/nvme0n1p8’ from 91,49 GiB to 231,16 GiB: Error
You’re not doing this from within the installed system, are you? :thinking:
Yes I’m doing it from the partition I’m using now (manjaro one).
Is it not correct?
No, it’s not. You should be doing it from the live USB/DVD.
Done, thank u.
