I’d like to install windows 10 instead of Manjaro Gnome, but first of all I need to resize partition and give some space to windows.
I go to Gparted - ext4 - resize. But it shows that minimum partition size equals maximum partition size. So, It doesn’t allow me to change the size.
Is your participation mounted? You Pretty sure you can’t resize a partition you are using. You’d need to boot from a live USB to rezise it if it’s the partition your using
Do you just have the one partition? I’d boot from a live USB and then use gparted to resize /create a new partition for Windows. There are far more clever people on here than me though
I mean if I get windows on bootable drive, will it resize partition automatically? When I installed Manjaro I just choosed an option and it deleted windows. I’m asking will windows delete manjaro during installation?
What do you want exactly? If you want to dual boot, then you have to resize partition to make room for another one. If you want to switch back to Windows and delete anything to do with manjaro, then just plug in windows iso and install windows.
Then you didn’t format the drive before installing windows. You can still do it with live iso (I think gparted can resize ntfs partitions…).
Do you want to remove manjaro completely? Just format the disk and install windows. If you want to install Windows and then reinstall manjaro /dual boot manjaro installer will give you the option. Not 100% certain what you are trying to do
