I’ve installed Java through pacman to run one program. Now I don’t need it anymore, but removing it results in:
pacman -Q | grep jre
jre-openjdk 18.0.1.1.u2-1
jre-openjdk-headless 18.0.1.1.u2-1
sudo pacman -Rs jre-openjdk-headless
checking dependencies...
:: removing jre-openjdk-headless breaks dependency 'jre18-openjdk-headless=18.0.1.1.u2-1' required by jre-openjdk
:: removing jre-openjdk breaks dependency 'jre18-openjdk=18.0.1.1.u2-1' required by jdk-openjdk
Hi @fuavel8,
Have you tries removing it with pamac
instead of pacman
pamac remove jre-openjdk jre-openjdk-headless
Tip:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
I tried, but it says that target not found. Anyways, I decided to keep java for now. Thank You!
When I installed jre-openjdk, the following were installed
- extra/java-runtime-common
- extra/jre-openjdk-headless
- extra/libnet
- extra/jre-openjdk
I removed jre-openjdk and the above were removed.
===> pactree -r jre-openjdk-headless
└─jre-openjdk
===> pacman -Rs jre-openjdk
system
Closed
5
