Hi there, this is my first time over on this forum so please bear with me if I end up accidentally not complying to any rule.
With that said, last night, after rebooting my laptop, I couldn’t get it to boot normally again (it kept putting me in some recovery mode [a feature of systemd? anyway…]). Apparently I wasn’t able to boot normally because, when trying to mount /dev/sda13, an error was occurrying, which said something along the lines of:
mount: /patch: can't read superblock on /dev/sda13.
dmesg(1) may have more information after failed mount system call.
After removing /patch from my /etc/fstab, I was able to boot normally, but couldn’t get back to mounting the /dev/sda13 partition. I, then, ran dmesg to get more info, but couldn’t really understand what it was trying to tell me. Here’s what I got from it: dmesg output on superblock issue - Pastebin.com
Then, I tried following a few guides, which the forum won’t let me link here for others to see, on how to supposedly solve this issue, but none of them worked.
Lastly I used gsmartcontrol (a GUI around smartctl) to try and see if my issue was being caused by a hardware failure, but, again, I couldn’t understand all the technical mumbo jumbo that this tool generated. I ran this command:
'smartctl' --health --info --get=all --capabilities --attributes --format=brief --log=xerror,50,error --log=xselftest,50,selftest --log=selective --log=directory --log=scttemp --log=scterc --log=devstat --log=sataphy '/dev/sda'
And got this output: smartctl output on superblock issue - Pastebin.com
Ultimately I want to know how to fix this issue so that I can, again, be able to mount /dev/sda13 (I mean, assuming there hasn’t been an unrecoverable hardware failure)
I don’t know if this is of importance, but the other partitions on this same HDD seem to be working fine and my kernel is 5.10.133-1-MANJARO (I guess I’ll be updating it while this post waits for replies).
