I have canon ts5320 and the right drivers are installed and i tried to print other types of documents odt docx and it prints fine but when i try to print pdf it only gives me the option to print to file.
If I understand correctly, you want to print a document as a pdf from libreoffice.
This might be the solution:
- add the package cups-pdf
- create a CUPS-PDF printer
When completed you should see a “Virtual_PDF_Printer” or whatever you called it, in the output of the command lpstat -p -d
and any Print Dialog’s Printer dropdown list.
Some doc:
NOTE: There is also File -Export as-Export as PDF…
A question was asked at libreoffice, “what is the difference between print and export”: Export or print to pdf from writer? - English - Ask LibreOffice
it works thank you very much
