WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (7.1.9-1-MANJARO) or it failed to
load. Please recompile the kernel module and install it by
sudo /sbin/vboxconfig
You will not be able to start VMs until this problem is fixed.
/usr/lib/virtualbox/VirtualBox: symbol lookup error: /usr/lib/libQt6Help.so.6: undefined symbol: _ZN14QObjectPrivateC2E16QtPrivate_6_11_2, version Qt_6_PRIVATE_API
Further thoughts: if you are using e.g. mhwd-kernel -i linux72 this should pull in the headers for VirtualBox, etc. for you. This doesn’t happen if installing a Kernel via pacman directly; you have to tag on the modules to the command yourself (or add them afterwards).
