hello guys
actually i cannot open the flash drive and it gives me an error
Incomplete multi-sector transfer: magic: 0x58444e49 size: 4096 usa_ofs: 40 usa_count: 5 data: 45533 usn: 45532: Input/output error
Corrupt index block signature: vcn 0 inode 5
Failed to open $Secure: No such file or directory
Failed to mount '/dev/sdc1': No such file or directory
a hardware defect ? can you check this possibility first while using the flash-drive on a different hardware ?
is the drive connected direct or through an hub ?
please give more details.
tfsprogs-ntfs3 2022.10.3-3 AUR
NTFS filesystem utilities without NTFS-3G driver.
For system with kernel >= 5.15
libntfs-3g 2016.2.22-1 AUR
NTFS filesystem library and development headers.
Does not include FUSE driver or utilities.
ntfs-3g-wimlib-patched 2017.3.23-1 AUR
NTFS filesystem driver and utilities - with patch
from
https://wimlib.net/forums/viewtopic.php?f=1&t=4&p=
93#p596 applied
ntfs-3g-system-compression-git 1.0.r14.f27f924-1 AUR
NTFS-3G plugin for reading "system compressed"
files
ntfs-3g-system-compression 1.0-1 AUR
files
ntfs-3g-onedrive-bin 1.2.0-1 AUR
NTFS-3G plugin for reading OneDrive directories
created by Windows 10
ntfs-3g [Installed] 2022.10.3-1 extra
no actually for the first time that i used the flash on the manjaro it was good and i copied a video on it but the next time that i wanted to open the flash i see this error
did you used the option to unmount the drive before you released it ? my suspicion is that you just ejected the flash and the drive wasn’t finished completely. in this case the data is corrupted.
If you are going to reformat it, exFat is something you might want to look into. Supports big files and has better support integration than ntfs on linux.
