Can't mount partitions or manjaro-chroot
Hey,
I upgraded some packages form my manjaro linux and when I restarted the computer, I couldn’t even get to the boot maneger. I have a dual boot windows-manjaro and when I power up the computer it shows a black screen. I can only get to windows pressing F11 and I can’t boot to manjaro.
So, what I did was to boot from a usb and then follow the posts on the forum. Here is some stuff I tried (not in a particular order):
[manjaro manjaro]# manjaro-chroot -a
==> Detected systems:
→ 0) ManjaroLinux
==> Select system to mount [0-0] :
0
==> ERROR: You can’t mount 0!
[manjaro manjaro]# mount /dev/nvme0n1p1 /mnt/boot/efi
mount: /mnt/boot/efi: mount point does not exist.
I have three partitions: home(nvme0n1p5), root(nvme0n1p6), boot(nvme0n1p1).
[manjaro manjaro]# mount -t proc proc /mnt/proc
mount: /mnt/proc: mount point does not exist.
[manjaro manjaro]# mount -t sysfs sys /mnt/sys
mount: /mnt/sys: mount point does not exist.
Right after booting, whithout trying to mount anything the partitions look like this:
[manjaro@manjaro ~]$ lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
loop0
squash 4.0 0 100% /run/miso/
loop1
loop2
loop3
sda
├─sda1
└─sda2
ntfs HDD 469E80F39E80DCB5
sdb iso966 Jolie MANJARO_XFCE_2003
│ 2020-06-06-07-11-25-00
├─sdb1
│ iso966 Jolie MANJARO_XFCE_2003
│ 2020-06-06-07-11-25-00 0 100% /run/miso/
└─sdb2
vfat FAT12 MISO_EFI
08E4-9928
nvme0n1
├─nvme0n1p1
│ vfat FAT32 AA77-6E69
├─nvme0n1p2
├─nvme0n1p3
│ ntfs SSD DE8278BD82789BA9
├─nvme0n1p4
│ ntfs 3EEE8ADFEE8A8EB9
├─nvme0n1p5
│ ext4 1.0 10bcb584-536c-44d6-ba4b-0baa1df83b89
└─nvme0n1p6
ext4 1.0 e423d3fb-b55f-4256-94c9-af8e510007ab
Is there any way to solve this and to boot into my OS again?
Thank you!
retry with 1
The only option I have is manjaro - 0.
retry with 1 anyway … instead of 0
it’s a wierd bug
first system is listed as 0
but can only be selected by putting 1 …
I don’t know if it’s old and now fixed - but incrementing the choice by 1 … should work
… worst case: it still doesn’t work - just as now …
so: try it :wink:
With the “manual” method, you first have to mount the partition with your / filesystem on it
to /mnt
then there will be the /mnt/proc directory
to mount the proc filesystem to
… and the others …
which isn’t/aren’t there if you didn’t mount the partition with the / filesystem first …
it seems you missed a step …
I suspect it is.
I think his ISO is old…oudated. Maybe.
I heard/read it is fixed - it came from different behaviours between UEFI and MBR booted systems - AFAIK
… it’s probably an older ISO that he is using, with the bug still present
Eactly
(I’ve personally never seen that message, but I do have only the one OS, which is Manjaro, on my computer. Much to the dismay of my wife.)
I once found Manjaro appealing - I now am back to Arch (via ArchLabs installer)
… although pure Arch is actually really simple to install - just the basic config takes too much time for my taste
… Manjaro is still cool :wink:
I might give Arch a go. Someday. But not now. I’m extremely happy with Manjaro. It makes it so easy to learn and still have a blazingly fast system! And it’s easy to stsy up to date. In fact, it actually takes effort not to!
Manjaro is the perfect balance between easy and powerful!
… that’s not what I found … :sunglasses:
what I found - for me - is:
due to the delayed updates
and the sometimes self made changes
(separate repositories …)
problems will arise
and be unfixable
until some … later time
or fixable by … switching branches … or something …
of course there is a way, always -
but not easy or even accessible to a casual user
… Arch has never given me much of any problem
… while Manjaro … relatively constantly does
unfortunately …
I’ll be converting my fathers laptop from Manjaro - which has worked quite well for the last at least two or three years - to …
Mint
… it’s just much less hassle to keep it working …
I know what to do - and how
but my father doesn’t …
Yeah.
I love Manjaro, personally. It’s the first Linux I’ve felt comfortable enough with to wipe Windows.
But, honestly? As long as you’re somewhere in the Linux world, you"re OK in my books!
Sorry for answering late, I’ve been very busy. So, I tried with the “manjaro-chroot -a” then selecting one. It worked!! I did this exactly this after booting into the usb:
[manjaro@manjaro ~]$ su
→ 0) ManjaroLinux
1
==> Mounting (ManjaroLinux) [/dev/nvme0n1p5]
→ mount: [/mnt]
→ mount: [/mnt/boot/efi]
→ mount: [/mnt/home]
[manjaro /]# pacman -Syyuu
warning: config file /etc/pacman.conf, line 100: directive ‘“n[sublime-text]nServer’ in section ‘multilib’ not recognized.
core 165.7 KiB 1467 KiB/s 00:00 [######################] 100%
extra 2000.9 KiB 12.5 MiB/s 00:00 [######################] 100%
community 6.6 MiB 41.0 MiB/s 00:00 [######################] 100%
multilib 181.1 KiB 0.00 B/s 00:00 [######################] 100%
sublime-text 1827.0 B 0.00 B/s 00:00 [######################] 100%
sublime-text.sig 542.0 B 0.00 B/s 00:00 [######################] 100%
:: Starting full system upgrade…
there is nothing to do
[manjaro /]# update-grub
Generating grub configuration file …
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.9-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.9-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.8-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.8-x86_64.img
Found initrd fallback image: /boot/initramfs-5.8-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.7-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.7-x86_64.img
Found initrd fallback image: /boot/initramfs-5.7-x86_64-fallback.img
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Adding boot menu entry for UEFI Firmware Settings …
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
[manjaro /]# exit
exit
→ umount: [/mnt/home]
→ umount: [/mnt/boot/efi]
→ umount: [/mnt]
[manjaro manjaro]# exit
exit
After this I restart the PC and nothing happened. I couldn’t boot manjaro. Any ideas on what should I do or why did this happen?
Thank you!
retry with sync mirrors before
sudo manjaro-chroot -a ( type 1 if only one line 0 appears )
pacman-mirrors -c all
pacman -Syyu
mkinitcpio -P
update-grub
exit ( end chroot )
I did what you said and I could do everything except for
mkinitcpio -P
When I executed this command I got this errors:
==> ERROR: ‘/lib/modules/5.7.19-2-MANJARO’ is not a valid kernel module directory
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: ‘fallback’
→ -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64-fallback.img -S autodetect
==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: ‘default’
→ -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64.img
==> ERROR: ‘/lib/modules/5.8.18-1-MANJARO’ is not a valid kernel module directory
==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: ‘fallback’
→ -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64-fallback.img -S autodetect
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: ‘default’
→ -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
==> ERROR: ‘/lib/modules/5.9.16-1-MANJARO’ is not a valid kernel module directory
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: ‘fallback’
→ -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
I still can’t boot.
see this topic
version linux57 , 58 , 59 are EOL ( no more support )
can you provide
ls /etc/mkinitcpio.d/*.preset
mhwd-kernel -li
exit
Here:
→ 0) ManjaroLinux
1
→ mount: [/mnt]
[manjaro /]# ls /etc/mkinitcpio.d/*.preset
/etc/mkinitcpio.d/linux510.preset /etc/mkinitcpio.d/linux58.preset
/etc/mkinitcpio.d/linux57.preset /etc/mkinitcpio.d/linux59.preset
[manjaro /]# mhwd-kernel -li
Currently running: 5.6.15-1-MANJARO (linux56)
* linux510
* linux59
[manjaro /]# exit
exit
→ umount: [/mnt]
[manjaro manjaro]#
mhwd-kernel -li
rm /etc/mkinitcpio.d/linux57.preset
rm /etc/mkinitcpio.d/linux58.preset
mhwd-kernel -r linux59
mhwd-kernel -i linux511
pacman -S linux510-headers linux511-headers
mkinitcpio -P
update-grub
exit
reboot and press Esc to get Grub > advanced select your kernel ( 510 or 511)
I love you!! Thanks so much, that worked!
Before all this, when I turned on the computer I got to the boot manegment where I could chose between windows and manjaro. Now if I want to enter windows I have to press f11 and chose windows and if I want to boot manjaro, I have to press escape and then chose the correct kernel.
How can I make it so I can boot like before? Like having the option of windows and manjaro at the manjaro boot options.
Thanks so much again, I thought I would have to delete the entire OS and install it again.
there is a recent change in option grub ,
os-prober is desactivated for work on securities with secureboot & windows
see this Grub2 | Secure Boot Bypass and other issues - Update highly recommended
