I resized a partition through KDE Partition Manager (380GB → 350GB). The disk only had 270GB used according to KDE PM, but the resize failed, and now that partition won’t mount. It’s my main data drive, and I’m worried I may have lost data.
My system is dual-booted Manjaro + Windows 7. I haven’t tried booting the windows OS to see if the drive is fine there; I’m scared that might break something further. What should I do? How can I recover my data?
inxi --admin --verbosity=7 --filter --width:
Summary
Kernel: 5.15.94-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=5cca366c-3f6c-47f2-8665-504baa926be5 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: M5A97 R2.0 v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 2201
date: 12/10/2013
Device-1: sony_controller_battery_04:76:6e:1f:01:99 model: N/A serial: N/A
charge: N/A status: N/A
RAM: total: 7.66 GiB used: 3.08 GiB (40.2%)
Info: model: AMD FX-8350 bits: 64 type: MT MCP arch: Piledriver level: v2
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
Topology: cpus: 1x cores: 8 smt: enabled cache: L1: 384 KiB
desc: d-8x16 KiB; i-4x64 KiB L2: 8 MiB desc: 4x2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1417 high: 1475 min/max: 1400/4000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1449 2: 1475
3: 1403 4: 1404 5: 1404 6: 1398 7: 1404 8: 1403 bogomips: 64237
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
hw_pstate ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean
vme vmmcall wdt xop xsave
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: eVga.com. driver: nvidia
v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1380 class-ID: 0300
Device-2: Logitech HD Webcam C910 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 10-2:2 chip-ID: 046d:0821 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.8
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1242 s-dpi: 94 s-size: 1038x335mm (40.87x13.19")
s-diag: 1091mm (42.94")
Monitor-1: DVI-I-1 pos: primary,bottom-r res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
Monitor-2: HDMI-0 pos: top-left res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce GTX 750
Ti/PCIe/SSE2 direct-render: Yes
Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 10-2:2 bus-ID: 00:14.2 chip-ID: 046d:0821 chip-ID: 1002:4383
class-ID: 0e02 serial: <filter> class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: eVga.com. driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc
class-ID: 0403
Device-3: Logitech HD Webcam C910 type: USB driver: snd-usb-audio,uvcvideo
Device-4: Shure MV5 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 5-1:2 chip-ID: 14ed:1000 class-ID: 0300
Sound API: ALSA v: k5.15.94-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
vendor: ASUSTeK P8 series driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 577.55 GiB used: 165.59 GiB (28.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: BB6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 40WD
scheme: MBR
Optical-1: /dev/sr0 vendor: ASUS model: DRW-24B1ST i rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 87.89 GiB size: 85.95 GiB (97.80%) used: 68.87 GiB (80.1%)
fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 5cca366c-3f6c-47f2-8665-504baa926be5
ID-2: /run/media/pancelor/6EF3AF59591C039D raw-size: 103.89 GiB
size: 103.89 GiB (100.00%) used: 96.72 GiB (93.1%) fs: ntfs dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: 6EF3AF59591C039D
ID-1: /dev/sda2 maj-min: 8:2 size: 1 KiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/sdb1 maj-min: 8:17 size: 348.57 GiB fs: ntfs label: data
uuid: 462C821B2C8205E1
Hub-1: 1-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Hub-2: 2-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Hub-3: 3-0:1 info: Full speed or root hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-4: 4-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Device-1: 4-1:2 info: Logitech G402 Gaming Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 046d:c07e class-ID: 0300 serial: <filter>
Device-2: 4-2:3 info: Razer USA BlackWidow Tournament Edition Stealth
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1532:011c class-ID: 0300
Hub-5: 5-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
Device-1: 5-1:2 info: Shure MV5 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 14ed:1000 class-ID: 0300
Hub-6: 6-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 7-0:1 info: Full speed or root hub ports: 4 rev: 1.1 speed: 12 Mb/s
Hub-8: 8-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 8-2:2 info: Sony Batoh Device / PlayStation 3 Controller
type: HID driver: sony,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 054c:0268 class-ID: 0300
Hub-9: 9-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-10: 10-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 10-2:2 info: Logitech HD Webcam C910 type: Audio,Video
power: 500mA chip-ID: 046d:0821 class-ID: 0e02 serial: <filter>
Hub-11: 11-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 17.6 C mobo: N/A gpu: nvidia temp: 22 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 42%
Processes: 233 Uptime: 45m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1457
pm: pacman pkgs: 1433 libs: 370 tools: pamac pm: flatpak pkgs: 9 pm: snap
pkgs: 15 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.25
Full story:
I’ve been having some system instability (sometimes my system freezes and I have to hold the power button to shut it down) so I decided to add more swap space to see if it would help. I did these steps in order:
- I opened KDE Partition Manager and unmounted /dev/sdb1 (my NTFS data partition)
- I removed my existing 1GB swapfile:
2a.sudo swapoff -a
2b. I removed the line with my swapfile from /etc/fstab
2c.swapon -a
2d.swapon -s– no output
2e.free -h– shows 0 swap space - I set up a job in KDE Partition Manager to shrink my data partition by 30,000MiB, and create a 11,000MiB linuxswap partition at the start of the resulting free space.
- I “applied” the job and it errored:
KDE Partition Manager: SMART Status Report
Date: 2023-03-21 12:30 A.M.
Program version: 22.12.2
Backend: pmsfdiskbackendplugin (1)
KDE Frameworks version: 5.102.0
Machine: Linux pancelor-manjaro 5.15.94-1-MANJARO #1 SMP PREEMPT Tue Feb 14 19:45:58 UTC 2023 x86_64
Shrink partition ‘/dev/sdb1’ from 377.87 GiB to 348.57 GiB
Job: Check file system on partition ‘/dev/sdb1’
Command: ntfsresize --no-progress-bar --info --force --verbose /dev/sdb1
Check file system on partition ‘/dev/sdb1’: Success
Job: Resize file system on partition ‘/dev/sdb1’ to 731,006,976 sectors
The file system on partition ‘/dev/sdb1’ already has the requested length of 731,006,976 sectors.
Resize file system on partition ‘/dev/sdb1’ to 731,006,976 sectors: Success
Job: Set geometry of partition ‘/dev/sdb1’: Start sector: 2,048, length: 731,006,976
Command: sfdisk --force /dev/sdb -N 1
Set geometry of partition ‘/dev/sdb1’: Start sector: 2,048, length: 731,006,976: Success
Check file system on partition ‘/dev/sdb1’: Error
Checking partition ‘/dev/sdb1’ after resize/move failed.
Shrink partition ‘/dev/sdb1’ from 377.87 GiB to 348.57 GiB: Error
- The data drive won’t mount anymore; I restarted my computer and tried to access my files through Dolphin, but it errored: “An error occurred while accessing ‘data’, the system responded: The requested operation has failed: Error mounting /dev/sdb1 at /run/media/pancelor/data: Unknown error when mounting /dev/sdb1”.
- My data drive used to auto-mount on boot, and I forget how I set that up exactly. My past notes say I “used fstab”. I think I may have accidentally removed an extra line from /etc/fstab during step 2b above? I tried to add it back in, assuming I had accidentally removed it:
Summary
(I’ve hidden the rest of this behind a details dropdown because I expect it won’t be too relevant, but I’ve included it for completeness)
- I looked into Fstab - Manjaro
7a. usedsudo blkidto find my data partition (/dev/sdb1: LABEL="data" BLOCK_SIZE="512" UUID="462C821B2C8205E1" TYPE="ntfs" PARTUUID="1a1f3123-01")
7b. I added this line to my /etc/fstab:UUID=462C821B2C8205E1 /run/media/pancelor/462C821B2C8205E1/ ntfs noauto,x-systemd.automount,x-systemd.device-timeout=10,rw,inherit,permissions,streams_interface=windows,windows_names,compression,norecover,hide_dot_files,hide_hid_files,big_writes 0 2
7c. It still won’t mount when I click on the partition in Dolphin: “An error occurred while accessing ‘data’, the system responded: The requested operation has failed: Error creating directory `/run/media/pancelor/462C821B2C8205E1/’ to be used for mounting /dev/sdb1: Not a directory”.
7d. I tried changing the fstab line to say “/run/media/pancelor/data” instead of “/run/media/pancelor/462C821B2C8205E1/”, but Dolphin still can’t mount it: ““An error occurred while accessing ‘data’, the system responded: The requested operation has failed: Error mounting system-managed device /dev/sdb1: Unknown error when mounting /run/media/pancelor/data”” - I opened KDE Partition Manager, right-clicked on /dev/sdb1/ and tried the “check and repair partition” job; it failed:
Date: 2023-03-21 1:16 A.M.
Check and repair partition ‘/dev/sdb1’ (348.57 GiB, ntfs)
Check and repair partition ‘/dev/sdb1’ (348.57 GiB, ntfs): Error
What should I do? Should I boot into windows and check if everything’s fine from that side?
