Hi there,
I am on a laptop with Manjaro i3wm.
When I connect it to a external monitor, I can not configure my display settings using pre-installed xfce4-settings-manager but to change in arandr or xrandr.
This is painful for arandr does not support changing refresh rate or scaling.
Any one with any ideas?
||||||||| |||| charles@ThinkPad-S2
|||| |||| OS: Manjaro Linux x86_64
|||| |||| |||| Host: ThinkPad S2 Gen 6a
|||| |||| |||| Kernel: 6.1.69-1-MANJARO
|||| |||| |||| Uptime: 1 hour, 43 mins
|||| |||| |||| Packages: 1581 (pacman)
Resolution: 1920x1080 @ 60.05Hz, 2560x1600 @ 60.00Hz
WM: i3
Shell: fish 3.6.4
Terminal: alacritty
CPU: AMD Ryzen 5 PRO 5650U with Radeon Graphics (12) @ 2.300GHz
GPU: AMD ATI Radeon Vega Series / Radeon Vega Mobile Series
Memory: 2873MiB / 14810MiB
And Here is the output of inxi --admin --verbosity=7 --filter --width :
Kernel: 6.1.69-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=b3449a8f-c72d-4b0c-b8cd-23a73ff03025 rw nowatchdog loglevel=3
resume=UUID=2c2afe6c-2805-4a56-9208-93f394d4ea96 apparmor=1
Desktop: i3 v: 4.23 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: 21AFA008CD v: ThinkPad S2 Gen 6a
Mobo: LENOVO model: 21AFA008CD serial: <superuser required> UEFI: LENOVO
v: R1QET34W (1.20 ) date: 03/01/2022
ID-1: BAT0 charge: 42.5 Wh (100.0%) condition: 42.5/46.0 Wh (92.5%)
volts: 17.2 min: 15.4 model: Sunwoda LNV-5B10W13935 type: Li-poly
serial: <filter> status: full cycles: 89
System RAM: total: 16 GiB note: est. available: 14.46 GiB
used: 3.11 GiB (21.5%)
Info: model: AMD Ryzen 5 PRO 5650U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1885 high: 2863 min/max: 1600/4288 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1914 2: 1914
3: 1600 4: 1608 5: 1440 6: 1600 7: 1641 8: 2301 9: 1748 10: 1600 11: 2393
12: 2863 bogomips: 55125
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: DP-1,eDP-1
empty: DP-2,HDMI-A-1 bus-ID: 07:00.0 chip-ID: 1002:1638 class-ID: 0300
temp: 52.0 C
Device-2: Chicony ThinkPad T490 Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 04f2:b681
Display: x11 server: X.Org v: 21.1.10 compositor: Picom v: git-b700a
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1600 s-dpi: 96 s-size: 1185x423mm (46.65x16.65")
s-diag: 1258mm (49.54")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: right model: TYPE-C
serial: <filter> built: 2023 res: 2560x1600 hz: 60 dpi: 184 gamma: 1.2
size: 354x199mm (13.94x7.83") diag: 406mm (16") ratio: 16:9 modes:
max: 2560x1600 min: 640x480
Monitor-2: eDP-1 mapped: eDP pos: primary,left model: AU Optronics 0x222d
built: 2018 res: 1920x1080 hz: 60 dpi: 166 gamma: 1.2
size: 293x165mm (11.54x6.5") diag: 336mm (13.2") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.49 6.1.69-1-MANJARO) device-ID: 1002:1638 memory: 1000 MiB
unified: no
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.69-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
vendor: Lenovo driver: r8168 v: 8.052.01-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp3s0f0 state: down mac: <filter>
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 06:00.0 chip-ID: 10ec:8852 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
IF-ID-1: utun state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 0bda:4852
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 596.18 GiB used: 233.09 GiB (39.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HBJQ-000L7
lanes: 4 tech: SSD serial: <filter> fw-rev: 5M2QEXF7 temp: 32.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: SSD size: 119.24 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 tech: SSD serial: <filter> scheme: MBR
ID-1: / raw-size: 100.14 GiB size: 98.01 GiB (97.87%) used: 37.39 GiB (38.2%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: b3449a8f-c72d-4b0c-b8cd-23a73ff03025
used: 29.1 MiB (30.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: AC55-0E56
ID-3: /home/<filter>/OneDrive raw-size: N/A size: 5 GiB
used: -18014398503609956 (-343597383568.0%) fs: fuse.rclone remote: OneDrive:
ID-4: /run/media/charles/Data raw-size: 206.38 GiB
size: 206.38 GiB (100.00%) used: 125.14 GiB (60.6%) fs: ntfs
dev: /dev/nvme0n1p5 maj-min: 259:5 label: Data uuid: F8740B0D740ACE76
ID-5: /run/media/charles/Windows raw-size: 150.09 GiB
size: 150.09 GiB (100.00%) used: 70.53 GiB (47.0%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: Windows uuid: 02C8566EC8565FC9
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%) priority: 1
dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 2c2afe6c-2805-4a56-9208-93f394d4ea96
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 687 MiB fs: ntfs label: N/A
uuid: 86E8EADEE8EACC0D
ID-3: /dev/sda1 maj-min: 8:1 size: 119.21 GiB fs: exfat label: Ventoy
uuid: 1C35-B65D
ID-4: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 1E1C-88C8
Device-1: 1-3:2 info: Chicony ThinkPad T490 Webcam type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b681 class-ID: 0e02 serial: <filter>
Device-2: 1-4:3 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-1: 2-2:2 info: Lenovo 128GB thinkplus type: mass storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 chip-ID: 17ef:3899 class-ID: 0806
serial: <filter>
Device-1: 3-2:5 info: Logitech Logi Bolt Receiver type: keyboard,mouse,HID
lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c548 class-ID: 0300
Device-2: 3-3:2 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Hub-4: 3-4:3 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 3-4.3:4 info: Raydium Touch System type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 96mA
chip-ID: 2386:4338 class-ID: 0300
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 64.0 C mobo: N/A gpu: amdgpu temp: 53.0 C
Fan Speeds (rpm): fan-1: 3542
Processes: 297 Uptime: 1h 40m wakeups: 0 Init: systemd v: 254
Packages: pm: pacman pkgs: 1581 libs: 439 tools: pamac,yay Shell: fish
v: 3.6.4 running-in: alacritty inxi: 3.3.31
Willing to provide any information if needed.
