Hi! I am daily-driving a Manjaro KDE installation and every time I rebooted it was swapping to audio over HDMI and I was being have to change it to speakers every time. Then I found a solution;
Edit this file and remove the # before the line related to audio over HDMI: /etc/udev/rules.d/90-mhwd-prime-powermanagement.rules
This worked all good until one hour ago because I wanted to connect my laptop to my TV to watch some series. I just edited the file, put back the #, tried optimus-manager to both boot with hybrid/NVIDIA and rebooted a few times. What I have achieved was HDA NVidia audio device appearing in audio tab in settings but only profile being available is “Off”. I can not turn it on. Any help would be appreciated.
inxi -Fazy
Kernel: 5.15.46-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=284cc2b3-3025-4c18-a849-562f0e475482 rw rootflags=subvol=@
apparmor=1 security=apparmor
resume=UUID=a9234c51-8fab-446c-a377-e151a7e1a028 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: MONSTER product: ABRA A7 V12.2 v: N/A
Mobo: MONSTER model: ABRA A7 V12.2 serial: <superuser required>
UEFI: INSYDE v: 1.07.11TFB1 date: 11/06/2020
ID-1: BAT0 charge: 11.9 Wh (33.4%) condition: 35.6/40.1 Wh (88.6%)
volts: 13.8 min: 14.6 model: Notebook BAT type: Li-ion serial: <filter>
status: discharging
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 2 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 829 high: 900 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 890 2: 900 3: 843 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 40009
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: CLEVO/KAPOK
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: CLEVO/KAPOK
driver: nouveau v: kernel alternate: nvidia_drm,nvidia non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
ports: active: none empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:1f95
class-ID: 0300
Device-3: Chicony USB2.0 Camera type: USB driver: uvcvideo bus-ID: 1-8:2
chip-ID: 04f2:b685 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x08be built: 2019 res: 1920x1080
hz: 120 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.1
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.15.46-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: no
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: CLEVO/KAPOK driver: r8168 v: 8.049.02-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 0c:00.1
IF: enp12s0f1 state: down mac: <filter>
bus-ID: 1-14:3 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 715.41 GiB used: 362.18 GiB (50.6%)
model: MZVLB512HBJQ-00000 size: 476.94 GiB block-size: physical: 512 B
rev: EXF7201Q temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 MTFDDAV256TBN
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: A020 scheme: GPT
ID-1: / raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
used: 187.76 GiB (40.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
ID-4: /var/log raw-size: 467.84 GiB size: 467.84 GiB (100.00%)
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 46.0 C pch: 50.0 C mobo: N/A gpu: nouveau
temp: 38.0 C
Processes: 330 Uptime: 19m wakeups: 1 Memory: 15.33 GiB
used: 2.87 GiB (18.8%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1375
lib: 366 flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.17
~/Desktop history | grep "inxi" ✔ 4s
425 inxi -Fazy\n
~/Desktop inxi -Fazy ✔
ID-1: BAT0 charge: 11.7 Wh (32.9%) condition: 35.6/40.1 Wh (88.6%)
status: discharging
Speed (MHz): avg: 818 high: 898 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 799 3: 800 4: 800
5: 800 6: 800 7: 848 8: 898 bogomips: 40009
class-ID: 0300
class-ID: 0300
direct render: Yes
System Temperatures: cpu: 45.0 C pch: 46.0 C mobo: N/A gpu: nouveau
temp: 38.0 C
used: 2.89 GiB (18.8%) Init: systemd v: 251 default: graphical
