XTC0r
1 July 2021 14:25
1
Hello,
after upgrading my Manjaro last week I can’t login to any desktop manager. The login screen appears but it it doesn’t accept mit login credentials or at least I’m always thrown back to the login screen. But they are correct. No keyboard layout issue.
I tried several desktop managers (LXDM, light DM, SDDM). Switching to tty I can login.
I’m thankful for any ideas and happy to provide additional information.
I tried to enable and disable systemd-homed service. But the result is the same.
Journal begins at Sun 2020-04-12 18:21:05 CEST, ends at Mon 2021-06-28 15:49:28 CEST. –
Jun 28 15:33:10 xtc-manjaro systemd[1]: Started LXDE Display Manager.
Jun 28 15:33:21 xtc-manjaro lxdm-session[1361]: pam_systemd_home(lxdm:account): Not a user managed by systemd-homed: No home for user basti known
Jun 28 15:33:21 xtc-manjaro lxdm-session[1361]: pam_unix(lxdm:session): session opened for user basti(uid=1000) by (uid=0)
Jun 28 15:33:22 xtc-manjaro lxdm-session[1361]: pam_env(lxdm:session): deprecated reading of user environment enabled
Jun 28 15:33:22 xtc-manjaro lxdm-session[1361]: pam_unix(lxdm:session): session closed for user basti
Jun 28 15:33:27 xtc-manjaro lxdm-session[1408]: pam_systemd_home(lxdm:account): Not a user managed by systemd-homed: No home for user basti known
Jun 28 15:33:27 xtc-manjaro lxdm-session[1408]: pam_unix(lxdm:session): session opened for user basti(uid=1000) by (uid=0)
Jun 28 15:33:27 xtc-manjaro lxdm-session[1408]: pam_env(lxdm:session): deprecated reading of user environment enabled
Jun 28 15:33:27 xtc-manjaro lxdm-session[1408]: pam_unix(lxdm:session): session closed for user basti
Jun 28 15:42:42 xtc-manjaro lxdm-session[1546]: pam_systemd_home(lxdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jun 28 15:42:42 xtc-manjaro lxdm-session[1546]: pam_unix(lxdm:session): session opened for user basti(uid=1000) by (uid=0)
Jun 28 15:42:42 xtc-manjaro lxdm-session[1546]: pam_env(lxdm:session): deprecated reading of user environment enabled
Jun 28 15:42:42 xtc-manjaro lxdm-session[1546]: pam_unix(lxdm:session): session closed for user basti
Jun 28 15:42:47 xtc-manjaro lxdm-session[1575]: pam_systemd_home(lxdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jun 28 15:42:47 xtc-manjaro lxdm-session[1575]: pam_unix(lxdm:session): session opened for user basti(uid=1000) by (uid=0)
Jun 28 15:42:47 xtc-manjaro lxdm-session[1575]: pam_env(lxdm:session): deprecated reading of user environment enabled
Jun 28 15:42:47 xtc-manjaro lxdm-session[1575]: pam_unix(lxdm:session): session closed for user basti
Jun 28 15:43:28 xtc-manjaro systemd[1]: Stopping LXDE Display Manager…
Jun 28 15:43:29 xtc-manjaro systemd[1]: lxdm.service: Deactivated successfully.
Jun 28 15:43:29 xtc-manjaro systemd[1]: Stopped LXDE Display Manager.
Jun 28 15:43:29 xtc-manjaro systemd[1]: lxdm.service: Consumed 10.280s CPU time.
– Boot 9121569af91243bba4d3c1f916325778 –
Jun 28 15:44:31 xtc-manjaro systemd[1]: Started LXDE Display Manager.
Jun 28 15:45:48 xtc-manjaro lxdm-session[1406]: pam_systemd_home(lxdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jun 28 15:45:48 xtc-manjaro lxdm-session[1406]: pam_unix(lxdm:session): session opened for user basti(uid=1000) by (uid=0)
Jun 28 15:45:48 xtc-manjaro lxdm-session[1406]: pam_env(lxdm:session): deprecated reading of user environment enabled
Jun 28 15:45:48 xtc-manjaro lxdm-session[1406]: pam_unix(lxdm:session): session closed for user basti
Jun 28 15:49:27 xtc-manjaro lxdm-session[1450]: pam_systemd_home(lxdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jun 28 15:49:27 xtc-manjaro lxdm-session[1450]: pam_unix(lxdm:session): session opened for user basti(uid=1000) by (uid=0)
Jun 28 15:49:27 xtc-manjaro lxdm-session[1450]: pam_env(lxdm:session): deprecated reading of user environment enabled
Jun 28 15:49:27 xtc-manjaro lxdm-session[1450]: pam_unix(lxdm:session): session closed for user basti
I had the same issue once. I had to reinstall :’(
Do you recall creating any symlinks, performing any sudo stuff or modifying any environment variable before this occurred? Also, posting some more details about your system will be helpful. You could run inxi -Fxxxzm in a terminal and paste the output here.
XTC0r
2 July 2021 12:12
3
Thanks for taking the time to reply to my post!
The only thing I can remember were issues updating alsa-lib. If I recall correctly I had some custome alsa-lib installed to make AC3 (or was it PCM?) work on manjaro with my 5.1 system. After I deinstalled it the update went through.
Here is the output of inxi -Fxxxzm
System: Kernel: 5.4.124-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Console: tty 3 DM: LXDM Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING EDGE WIFI (MS-7C37) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 1.C2 date: 09/29/2020
Memory: RAM: total: 31.35 GiB used: 892.9 MiB (2.8%)
CPU: Info: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 rev: 0 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 115232
Speed: 2147 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 2147 2: 2133 3: 2508 4: 2140 5: 1859
6: 2794 7: 1861 8: 1867 9: 2734 10: 2122 11: 1863 12: 2798 13: 1863 14: 1866 15: 2133 16: 2139
Graphics: Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Micro-Star MSI driver: nvidia v: 465.31 bus-ID: 2d:00.0
chip-ID: 10de:1e84 class-ID: 0300
Display: server: X. org 1.20.11 driver: loaded: nvidia tty: 200x75
Message: Advanced graphics data unavailable in console. Try -G --display
Audio: Device-1: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 2d:00.1
chip-ID: 10de:10f8 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Tdlasunnic Sharkoon Gaming DAC Pro S type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 7-3.1:4
chip-ID: be57:020e class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.4.124-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 14.2 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI X570-A PRO driver: r8168
v: 8.048.03-NAPI port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel port: d000 bus-ID: 29:00.0
chip-ID: 8086:24fb class-ID: 0280
IF: wlp41s0 state: up mac: <filter>
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:4 chip-ID: 8087:0aa7
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: not found rfk-block: hardware: no software: yes
address: see --recommends
Drives: Local Storage: total: 10.01 TiB used: 7.01 TiB (70.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 2B2QEXE7 scheme: GPT
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 rotation: SSD
ID-3: /dev/sda vendor: Samsung model: SSD 850 EVO 1TB size: 931.51 GiB speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 2B6Q scheme: GPT
ID-4: /dev/sdb vendor: Western Digital model: WD80EFAX-68KNBN0 size: 7.28 TiB speed: 6.0 Gb/s rotation: 5400 rpm
serial: <filter> rev: 0A81 scheme: GPT
Partition: ID-1: / size: 915.7 GiB used: 604.58 GiB (66.0%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 199.8 MiB used: 62.3 MiB (31.2%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 4.47 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda5
Sensors: System Temperatures: cpu: 48.8 C mobo: 0 C
Info: Processes: 277 Uptime: 1m wakeups: 0 Init: systemd v: 248 Compilers: gcc: 11.1.0 clang: 12.0.0 Packages:
pacman: 1040 Shell: Bash (login) v: 5.1.8 running-in: tty 3 inxi: 3.3.04
XTC0r
5 July 2021 17:57
4
Has anybody some suggestions how I can fix this?
XTC0r:
Check /var/log/pacman.log what actually got deinstalled when you initiated that action.
Perhaps that action removed more than just that one package.
XTC0r
5 July 2021 20:06
6
thanks for the hint. For whatever reason a lot of stuff was removed when I did the upgrade
[2021-06-28T13:27:47+0200] [PAMAC] synchronizing package lists
[2021-06-28T13:28:09+0200] [PAMAC] synchronizing package lists
[2021-06-28T13:28:17+0200] [PAMAC] synchronizing package lists
[2021-06-28T13:29:25+0200] [PAMAC] synchronizing package lists
[2021-06-28T13:32:13+0200] [PAMAC] synchronizing package lists
[2021-06-28T13:32:20+0200] [ALPM] running 'firefox-pre.hook'...
[2021-06-28T13:32:20+0200] [ALPM] transaction started
[2021-06-28T13:32:20+0200] [ALPM] upgraded alsa-card-profiles (1:0.3.24-1 -> 1:0.3.30-1)
[2021-06-28T13:32:20+0200] [ALPM] upgraded alsa-ucm-conf (1.2.4-2 -> 1.2.5-1)
[2021-06-28T13:32:20+0200] [ALPM] upgraded alsa-utils (1.2.4-2 -> 1.2.5-3)
[2021-06-28T13:32:20+0200] [ALPM] upgraded systemd-libs (248.3-2 -> 248.3-3)
[2021-06-28T13:32:21+0200] [ALPM] upgraded systemd (248.3-2 -> 248.3-3)
[2021-06-28T13:32:21+0200] [ALPM] upgraded firefox (89.0-1 -> 89.0.2-0.1)
[2021-06-28T13:32:21+0200] [ALPM] upgraded firefox-i18n-de (89.0-1 -> 89.0.2-1)
[2021-06-28T13:32:21+0200] [ALPM] upgraded firefox-i18n-en-us (89.0-1 -> 89.0.2-1)
[2021-06-28T13:32:21+0200] [ALPM] upgraded lib32-at-spi2-core (2.40.0-1 -> 2.40.2-1)
[2021-06-28T13:32:21+0200] [ALPM] upgraded lib32-colord (1.4.5-2 -> 1.4.5-3)
[2021-06-28T13:32:22+0200] [ALPM] upgraded matcha-gtk-theme (20210602-0.1 -> 20210624-0.1)
[2021-06-28T13:32:22+0200] [ALPM] upgraded sabnzbd (3.3.0-1 -> 3.3.1-1)
[2021-06-28T13:32:22+0200] [ALPM] upgraded systemd-sysvcompat (248.3-2 -> 248.3-3)
[2021-06-28T13:32:22+0200] [ALPM] upgraded vivaldi (4.0.2312.27-2 -> 4.0.2312.33-1)
[2021-06-28T13:32:22+0200] [ALPM] upgraded vivaldi-ffmpeg-codecs (91.0.4472.101-1 -> 91.0.4472.114-1)
[2021-06-28T13:32:22+0200] [ALPM] transaction completed
[2021-06-28T13:32:22+0200] [ALPM] running '20-systemd-sysusers.hook'...
[2021-06-28T13:32:22+0200] [ALPM] running '30-systemd-catalog.hook'...
[2021-06-28T13:32:22+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-06-28T13:32:23+0200] [ALPM] running '30-systemd-hwdb.hook'...
[2021-06-28T13:32:23+0200] [ALPM] running '30-systemd-sysctl.hook'...
[2021-06-28T13:32:23+0200] [ALPM] running '30-systemd-tmpfiles.hook'...
[2021-06-28T13:32:23+0200] [ALPM] running '30-systemd-udev-reload.hook'...
[2021-06-28T13:32:23+0200] [ALPM] running '30-systemd-update.hook'...
[2021-06-28T13:32:23+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2021-06-28T13:32:23+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'default'
[2021-06-28T13:32:23+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64.img
[2021-06-28T13:32:23+0200] [ALPM-SCRIPTLET] ==> Starting build: 4.19.193-1-MANJARO
[2021-06-28T13:32:23+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-06-28T13:32:23+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-06-28T13:32:23+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-06-28T13:32:23+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-28T13:32:23+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-06-28T13:32:25+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-28T13:32:25+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-06-28T13:32:25+0200] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2021-06-28T13:32:25+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-28T13:32:25+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-06-28T13:32:25+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64.img
[2021-06-28T13:32:26+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-06-28T13:32:26+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'fallback'
[2021-06-28T13:32:26+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64-fallback.img -S autodetect
[2021-06-28T13:32:26+0200] [ALPM-SCRIPTLET] ==> Starting build: 4.19.193-1-MANJARO
[2021-06-28T13:32:26+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-06-28T13:32:27+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-06-28T13:32:27+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-28T13:32:27+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-06-28T13:32:30+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-28T13:32:31+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-06-28T13:32:31+0200] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2021-06-28T13:32:31+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-28T13:32:33+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-06-28T13:32:33+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64-fallback.img
[2021-06-28T13:32:37+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-06-28T13:32:37+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux49.preset: 'default'
[2021-06-28T13:32:37+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.9-x86_64.img
[2021-06-28T13:32:37+0200] [ALPM-SCRIPTLET] ==> Starting build: 4.9.271-1-MANJARO
[2021-06-28T13:32:37+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-06-28T13:32:37+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-06-28T13:32:37+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-06-28T13:32:37+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-28T13:32:37+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-06-28T13:32:39+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-28T13:32:40+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-06-28T13:32:40+0200] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2021-06-28T13:32:40+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-28T13:32:40+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-06-28T13:32:40+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.9-x86_64.img
[2021-06-28T13:32:41+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-06-28T13:32:41+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux49.preset: 'fallback'
[2021-06-28T13:32:41+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.9-x86_64-fallback.img -S autodetect
[2021-06-28T13:32:41+0200] [ALPM-SCRIPTLET] ==> Starting build: 4.9.271-1-MANJARO
[2021-06-28T13:32:41+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-06-28T13:32:41+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-06-28T13:32:41+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-28T13:32:41+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-06-28T13:32:43+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-28T13:32:44+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-06-28T13:32:44+0200] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2021-06-28T13:32:44+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-28T13:32:44+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-06-28T13:32:44+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.9-x86_64-fallback.img
[2021-06-28T13:32:47+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-06-28T13:32:47+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
[2021-06-28T13:32:47+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
[2021-06-28T13:32:47+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.10.42-1-MANJARO
[2021-06-28T13:32:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-06-28T13:32:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-06-28T13:32:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-06-28T13:32:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-28T13:32:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-06-28T13:32:49+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-28T13:32:49+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-06-28T13:32:49+0200] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2021-06-28T13:32:49+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-28T13:32:49+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-06-28T13:32:49+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
[2021-06-28T13:32:50+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-06-28T13:32:50+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
[2021-06-28T13:32:50+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
[2021-06-28T13:32:50+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.10.42-1-MANJARO
[2021-06-28T13:32:50+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-06-28T13:32:51+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-06-28T13:32:51+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-28T13:32:51+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-06-28T13:32:54+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-28T13:32:55+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-06-28T13:32:55+0200] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2021-06-28T13:32:55+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-28T13:32:57+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-06-28T13:32:57+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-06-28T13:33:00+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-06-28T13:33:00+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
[2021-06-28T13:33:00+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
[2021-06-28T13:33:01+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.4.124-1-MANJARO
[2021-06-28T13:33:01+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-06-28T13:33:01+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-06-28T13:33:01+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-06-28T13:33:01+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-28T13:33:01+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-06-28T13:33:02+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-28T13:33:03+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-06-28T13:33:03+0200] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2021-06-28T13:33:03+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-28T13:33:03+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-06-28T13:33:03+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
[2021-06-28T13:33:04+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-06-28T13:33:04+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
[2021-06-28T13:33:04+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
[2021-06-28T13:33:04+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.4.124-1-MANJARO
[2021-06-28T13:33:04+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-06-28T13:33:04+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-06-28T13:33:04+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-28T13:33:04+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-06-28T13:33:08+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-28T13:33:09+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-06-28T13:33:09+0200] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2021-06-28T13:33:09+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-28T13:33:11+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-06-28T13:33:11+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
[2021-06-28T13:33:14+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-06-28T13:33:14+0200] [ALPM] running 'dbus-reload.hook'...
[2021-06-28T13:33:14+0200] [ALPM] running 'firefox-post.hook'...
[2021-06-28T13:33:14+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-06-28T13:33:15+0200] [ALPM] running 'update-desktop-database.hook'...
[2021-06-28T13:33:25+0200] [ALPM] transaction started
[2021-06-28T13:33:25+0200] [ALPM] upgraded libinput-multiplier (1.16.4-1 -> 1.18.0-1)
[2021-06-28T13:33:25+0200] [ALPM] transaction completed
[2021-06-28T13:33:25+0200] [ALPM] running '30-systemd-udev-reload.hook'...
[2021-06-28T13:33:25+0200] [ALPM] running '30-systemd-update.hook'...
[2021-06-28T13:36:10+0200] [PAMAC] synchronizing package lists
[2021-06-28T13:37:21+0200] [PAMAC] synchronizing package lists
[2021-06-28T13:37:37+0200] [PAMAC] synchronizing package lists
[2021-06-28T13:38:17+0200] [PAMAC] synchronizing package lists
[2021-06-28T13:39:35+0200] [PACMAN] Running 'pacman -Syuu alsa-lib'
[2021-06-28T13:39:35+0200] [PACMAN] synchronizing package lists
[2021-06-28T13:39:42+0200] [PACMAN] starting full system upgrade
[2021-06-28T13:40:49+0200] [ALPM] running 'texinfo-remove.hook'...
[2021-06-28T13:40:49+0200] [ALPM] transaction started
[2021-06-28T13:40:49+0200] [ALPM] removed xfce4-smartbookmark-plugin (0.5.2-1)
[2021-06-28T13:40:50+0200] [ALPM] removed xfce4-mpc-plugin (0.5.2-2)
[2021-06-28T13:40:50+0200] [ALPM] removed lib32-fluidsynth (2.1.8-1)
[2021-06-28T13:40:50+0200] [ALPM] removed yelp (40.2-1)
[2021-06-28T13:40:50+0200] [ALPM] removed remmina (1:1.4.18-1)
[2021-06-28T13:40:50+0200] [ALPM] removed lib32-gtk3 (3.24.29-1)
[2021-06-28T13:40:50+0200] [ALPM] removed lib32-json-glib (1.6.2-1)
[2021-06-28T13:40:50+0200] [ALPM] removed keditbookmarks (21.04.1-1)
[2021-06-28T13:40:50+0200] [ALPM] removed lib32-portaudio (1:19.7.0-1)
[2021-06-28T13:40:50+0200] [ALPM] removed gvfs-nfs (1.48.1-1)
[2021-06-28T13:40:50+0200] [ALPM] removed lib32-libepoxy (1.5.8-1)
[2021-06-28T13:40:50+0200] [ALPM] removed smtube (20.6.0-1)
[2021-06-28T13:40:50+0200] [ALPM] removed steam-manjaro (1.0.0.70-1)
[2021-06-28T13:40:50+0200] [ALPM] removed cheese (3.38.0-1)
[2021-06-28T13:40:50+0200] [ALPM] removed clutter-gst (3.0.27-3)
[2021-06-28T13:40:50+0200] [ALPM] removed kio-extras (21.04.1-2)
[2021-06-28T13:40:50+0200] [ALPM] removed kdsoap-ws-discovery-client (git20200927-1)
[2021-06-28T13:40:50+0200] [ALPM] removed kdsoap (1.10.0-1)
[2021-06-28T13:40:50+0200] [ALPM] removed xfdesktop-gtk3 (2019.08.15-1)
[2021-06-28T13:40:50+0200] [ALPM] removed gvfs-smb (1.48.1-1)
[2021-06-28T13:40:50+0200] [ALPM] removed xfce4-xkb-plugin (0.8.2-1)
[2021-06-28T13:40:50+0200] [ALPM] removed kio-gdrive (21.04.1-1)
[2021-06-28T13:40:50+0200] [ALPM] removed kaccounts-providers (21.04.1-1)
[2021-06-28T13:40:50+0200] [ALPM] removed xfce4-dict (0.8.4-1)
[2021-06-28T13:40:50+0200] [ALPM] removed qmplay2-git (21.06.07.r1.ga47371ac-1)
[2021-06-28T13:40:50+0200] [ALPM] removed lib32-libinstpatch (1.1.6-1)
[2021-06-28T13:40:50+0200] [ALPM] removed xfwm4-gtk3 (2019.08.15-1)
[2021-06-28T13:40:50+0200] [ALPM] removed tilix (1.9.4-3)
[2021-06-28T13:40:50+0200] [ALPM] removed xfce4-panel-gtk3 (2019.08.15-1)
[2021-06-28T13:40:50+0200] [ALPM] removed kicad (5.1.10-1)
[2021-06-28T13:40:50+0200] [ALPM] removed vivaldi (4.0.2312.33-1)
[2021-06-28T13:40:50+0200] [ALPM] removed xfce4-battery-plugin (1.1.4-1)
[2021-06-28T13:40:50+0200] [ALPM] removed menulibre (2.2.1-3)
[2021-06-28T13:40:50+0200] [ALPM] removed gnome-system-monitor (40.1-1)
[2021-06-28T13:40:50+0200] [ALPM] removed lib32-libcanberra (0.30+2+gc0620e4-4)
[2021-06-28T13:40:50+0200] [ALPM] removed xfce4-terminal (0.8.10-2)
[2021-06-28T13:40:50+0200] [ALPM] removed libmpd (11.8.17-5)
[2021-06-28T13:40:50+0200] [ALPM] removed xfce4-verve-plugin (2.0.1-1)
[2021-06-28T13:40:50+0200] [ALPM] removed grilo-plugins (1:0.3.13-2)
[2021-06-28T13:40:50+0200] [ALPM] removed libgdata (0.18.1-1)
[2021-06-28T13:40:50+0200] [ALPM] removed gnome-online-accounts (3.40.0-1)
[2021-06-28T13:40:50+0200] [ALPM] removed gmime3 (3.2.7-1)
[2021-06-28T13:40:50+0200] [ALPM] removed xfce4-notes-plugin (1.9.0-1)
[2021-06-28T13:40:50+0200] [ALPM] removed gom (0.4-3)
[2021-06-28T13:40:51+0200] [ALPM] removed gparted (1.3.0-4)
[2021-06-28T13:40:51+0200] [ALPM] removed xfburn (0.6.2-1)
[2021-06-28T13:40:52+0200] [ALPM] removed atom (1.57.0-1)
[2021-06-28T13:40:52+0200] [ALPM] removed ripgrep (12.1.1-1)
[2021-06-28T13:40:52+0200] [ALPM] removed freerdp (2:2.3.2-1)
[2021-06-28T13:40:52+0200] [ALPM] removed sublime-text (4107-1)
[2021-06-28T13:40:53+0200] [ALPM] removed apm (2.6.1-4)
[2021-06-28T13:40:53+0200] [ALPM] removed meld (3.20.3-1)
[2021-06-28T13:40:53+0200] [ALPM] removed gtksourceview3 (3.24.11+28+g73e57b57-1)
[2021-06-28T13:40:53+0200] [ALPM] removed libisofs (1.5.4-1)
[2021-06-28T13:40:53+0200] [ALPM] removed firefox-i18n-en-us (89.0.2-1)
[2021-06-28T13:40:53+0200] [ALPM] removed plank (0.11.89-3)
[2021-06-28T13:40:53+0200] [ALPM] removed gnome-menus (3.36.0-1)
[2021-06-28T13:40:53+0200] [ALPM] removed flatpak (1.11.1-2)
[2021-06-28T13:40:53+0200] [ALPM] removed xdg-desktop-portal (1.8.1-1)
[2021-06-28T13:40:53+0200] [ALPM] removed ostree (2021.2-1)
[2021-06-28T13:40:53+0200] [ALPM] removed lib32-libltdl (2.4.6+42+gb88cebd5-1)
[2021-06-28T13:40:53+0200] [ALPM] removed lib32-libxcomposite (0.4.5-1)
[2021-06-28T13:40:53+0200] [ALPM] removed thunar-media-tags-plugin (0.3.0-2)
[2021-06-28T13:40:53+0200] [ALPM] removed libburn (1.5.4-1)
[2021-06-28T13:40:53+0200] [ALPM] removed xfce4-settings-gtk3 (2019.08.15-1)
[2021-06-28T13:40:53+0200] [ALPM] removed microsoft-office-web-jak (1:2.1.1-2)
[2021-06-28T13:40:53+0200] [ALPM] removed filezilla (3.54.1-2)
[2021-06-28T13:40:53+0200] [ALPM] removed libfilezilla (0.28.0-2)
[2021-06-28T13:40:53+0200] [ALPM] removed xfce4-appfinder-gtk3 (2019.08.15-1)
[2021-06-28T13:40:53+0200] [ALPM] removed xfce4-mount-plugin (1.1.5-1)
[2021-06-28T13:40:53+0200] [ALPM] removed geoclue (2.5.7-3)
[2021-06-28T13:40:53+0200] [ALPM] removed krusader (2.7.2-4)
[2021-06-28T13:40:53+0200] [ALPM] removed xfce4-genmon-plugin (4.1.1-1)
[2021-06-28T13:40:53+0200] [ALPM] removed lib32-libpulse (14.2-2)
[2021-06-28T13:40:53+0200] [ALPM] removed lib32-libsndfile (1.0.31-1)
[2021-06-28T13:40:53+0200] [ALPM] removed lib32-flac (1.3.3-1)
[2021-06-28T13:40:53+0200] [ALPM] removed lib32-libvorbis (1.3.7-1)
[2021-06-28T13:40:53+0200] [ALPM] removed lib32-opus (1.3.1-1)
[2021-06-28T13:40:53+0200] [ALPM] removed system-config-printer (1.5.15-1)
[2021-06-28T13:40:53+0200] [ALPM] removed python-pycurl (7.43.0.6-4)
[2021-06-28T13:40:53+0200] [ALPM] removed vlc (3.0.14-1)
[2021-06-28T13:40:53+0200] [ALPM] removed libupnp (1.14.7-1)
[2021-06-28T13:40:53+0200] [ALPM] removed libmatroska (1.6.3-1)
[2021-06-28T13:40:53+0200] [ALPM] removed libtar (1.2.20-5)
[2021-06-28T13:40:53+0200] [ALPM] removed libdvbpsi (1:1.3.3-2)
[2021-06-28T13:40:53+0200] [ALPM] removed kaccounts-integration (21.04.1-1)
[2021-06-28T13:40:53+0200] [ALPM] removed kcmutils (5.82.0-1)
[2021-06-28T13:40:54+0200] [ALPM] removed kdeclarative (5.82.0-1)
[2021-06-28T13:40:54+0200] [ALPM] removed signon-kwallet-extension (21.04.1-1)
[2021-06-28T13:40:54+0200] [ALPM] removed libgssglue (0.4-4)
[2021-06-28T13:40:54+0200] [ALPM] removed game-devices-udev (0.13-1)
[2021-06-28T13:40:54+0200] [ALPM-SCRIPTLET] You need to reboot your system now
[2021-06-28T13:40:54+0200] [ALPM] removed xfce4-sensors-plugin (1.3.95-1)
[2021-06-28T13:40:54+0200] [ALPM] removed smplayer-themes (1:20.11.0-1)
[2021-06-28T13:40:54+0200] [ALPM] removed kpackage (5.82.0-1)
[2021-06-28T13:40:54+0200] [ALPM] removed xfce4-fsguard-plugin (1.1.2-1)
[2021-06-28T13:40:54+0200] [ALPM] removed xfce4-volumed-pulse (0.2.3-1)
[2021-06-28T13:40:54+0200] [ALPM] removed xfce4-notifyd-gtk3 (2019.08.15-1)
[2021-06-28T13:40:54+0200] [ALPM] removed xine-ui (0.99.12-2)
[2021-06-28T13:40:54+0200] [ALPM] removed phonon-qt5-gstreamer (4.10.0-2)
[2021-06-28T13:40:54+0200] [ALPM] removed phonon-qt5 (4.11.1-2)
[2021-06-28T13:40:54+0200] [ALPM] removed conky-manager (2.4-4)
[2021-06-28T13:40:54+0200] [ALPM] removed lib32-nss (3.66-1)
[2021-06-28T13:40:54+0200] [ALPM] removed lib32-nspr (4.31-1)
[2021-06-28T13:40:54+0200] [ALPM] removed libgee (0.20.4-1)
[2021-06-28T13:40:54+0200] [ALPM] removed libebml (1.4.2-1)
[2021-06-28T13:40:54+0200] [ALPM] removed lib32-libxkbcommon (1.3.0-1)
[2021-06-28T13:40:54+0200] [ALPM] removed catfish (4.16.0-4)
[2021-06-28T13:40:54+0200] [ALPM] removed python-nautilus (1.2.3-5)
[2021-06-28T13:40:54+0200] [ALPM] removed nautilus (40.2-1)
[2021-06-28T13:40:54+0200] [ALPM] removed gnome-autoar (0.3.3-1)
[2021-06-28T13:40:54+0200] [ALPM] removed tracker3-miners (3.1.1-2)
[2021-06-28T13:40:54+0200] [ALPM] removed gupnp-dlna (0.10.5+4+gc947eed-2)
[2021-06-28T13:40:54+0200] [ALPM] removed libgrss (0.7.0+16+g971c421-3)
[2021-06-28T13:40:54+0200] [ALPM] removed libnautilus-extension (40.2-1)
[2021-06-28T13:40:54+0200] [ALPM] removed gufw (21.04.0-1)
[2021-06-28T13:40:54+0200] [ALPM] warning: /etc/ufw/user6.rules saved as /etc/ufw/user6.rules.pacsave
[2021-06-28T13:40:54+0200] [ALPM] warning: /etc/ufw/user.rules saved as /etc/ufw/user.rules.pacsave
[2021-06-28T13:40:54+0200] [ALPM] warning: /etc/ufw/ufw.conf saved as /etc/ufw/ufw.conf.pacsave
[2021-06-28T13:40:54+0200] [ALPM] removed ufw (0.36-5)
[2021-06-28T13:40:54+0200] [ALPM] removed opencascade (7.5.0-3)
[2021-06-28T13:40:54+0200] [ALPM] removed freeimage (3.18.0-9)
[2021-06-28T13:40:54+0200] [ALPM] removed jxrlib (0.2.1-3)
[2021-06-28T13:40:54+0200] [ALPM] removed gl2ps (1.4.2-2)
[2021-06-28T13:40:54+0200] [ALPM] removed vtk (8.2.0-19)
[2021-06-28T13:40:54+0200] [ALPM] removed lib32-rest (0.8.1-3)
[2021-06-28T13:40:54+0200] [ALPM] removed xfce4-netload-plugin (1.4.0-1)
[2021-06-28T13:40:54+0200] [ALPM] removed file-roller (3.40.0-1)
[2021-06-28T13:40:54+0200] [ALPM] removed manjaro-hello (0.6.6-5)
[2021-06-28T13:40:54+0200] [ALPM] removed exo-gtk3 (2019.08.15-1)
[2021-06-28T13:40:54+0200] [ALPM] removed gnome-terminal (3.40.2-1)
[2021-06-28T13:40:54+0200] [ALPM] removed ngspice (34-2)
[2021-06-28T13:40:54+0200] [ALPM] removed libkgapi (21.04.1-1)
[2021-06-28T13:40:54+0200] [ALPM] removed kcontacts (1:5.82.0-1)
[2021-06-28T13:40:54+0200] [ALPM] removed xfce4-clipman-plugin (1.6.2-1)
[2021-06-28T13:40:54+0200] [ALPM] removed geocode-glib (3.26.2-1)
[2021-06-28T13:40:54+0200] [ALPM] removed hexchat (2.14.3-8)
[2021-06-28T13:40:54+0200] [ALPM] removed xfce4-screenshooter (1.9.9-2)
[2021-06-28T13:40:55+0200] [ALPM] removed engrampa (1.24.2-1)
[2021-06-28T13:40:55+0200] [ALPM] removed ark (21.04.1-1)
[2021-06-28T13:40:55+0200] [ALPM] removed libzip (1.7.3-2)
[2021-06-28T13:40:55+0200] [ALPM] removed kpty (5.82.0-1)
[2021-06-28T13:40:55+0200] [ALPM] removed rhythmbox (3.4.4-4)
[2021-06-28T13:40:55+0200] [ALPM] removed grilo (0.3.13-1)
[2021-06-28T13:40:55+0200] [ALPM] removed totem-pl-parser (3.26.5-1)
[2021-06-28T13:40:55+0200] [ALPM] removed libquvi (0.9.4-6)
[2021-06-28T13:40:55+0200] [ALPM] removed libquvi-scripts (0.9.20131130-5)
[2021-06-28T13:40:55+0200] [ALPM] removed lua52-bitop (1.0.2-9)
[2021-06-28T13:40:55+0200] [ALPM] removed liboauth (1.0.3+14+g186fb14-2)
[2021-06-28T13:40:55+0200] [ALPM] removed libpeas (1.30.0-1)
[2021-06-28T13:40:55+0200] [ALPM] removed libutempter (1.2.1-1)
[2021-06-28T13:40:55+0200] [ALPM] removed smplayer-skins (1:20.11.0-1)
[2021-06-28T13:40:55+0200] [ALPM] removed garcon-gtk3 (2019.08.15-1)
[2021-06-28T13:40:55+0200] [ALPM] removed python-wxpython (1:4.0.7.2-1)
[2021-06-28T13:40:55+0200] [ALPM] removed orage (4.12.1-5)
[2021-06-28T13:40:55+0200] [ALPM] removed gvfs-gphoto2 (1.48.1-1)
[2021-06-28T13:40:55+0200] [ALPM] removed lib32-at-spi2-atk (2.38.0-1)
[2021-06-28T13:40:55+0200] [ALPM] removed lib32-at-spi2-core (2.40.2-1)
[2021-06-28T13:40:55+0200] [ALPM] removed libavresample (4.3.1-1)
[2021-06-28T13:40:55+0200] [ALPM] removed xfce4-diskperf-plugin (2.6.3-1)
[2021-06-28T13:40:55+0200] [ALPM] removed xine-lib (1.2.11-5)
[2021-06-28T13:40:55+0200] [ALPM] removed lib32-libogg (1.3.5-1)
[2021-06-28T13:40:55+0200] [ALPM] removed xfce4-weather-plugin (0.11.0-1)
[2021-06-28T13:40:55+0200] [ALPM] removed veracrypt (1.24.update7-1)
[2021-06-28T13:40:55+0200] [ALPM] removed wxgtk3 (3.0.5.1-2)
[2021-06-28T13:40:55+0200] [ALPM] removed wxgtk-common (3.0.5.1-2)
[2021-06-28T13:40:55+0200] [ALPM] removed electron9 (9.4.4-1)
[2021-06-28T13:40:55+0200] [ALPM] removed firefox-i18n-de (89.0.2-1)
[2021-06-28T13:40:55+0200] [ALPM] removed firefox (89.0.2-0.1)
[2021-06-28T13:40:55+0200] [ALPM] removed mailcap (2.1.53-1)
[2021-06-28T13:40:55+0200] [ALPM] removed xfce4-wavelan-plugin (0.6.2-1)
[2021-06-28T13:40:55+0200] [ALPM] removed xfce4-power-manager-gtk3 (2019.08.15-1)
[2021-06-28T13:40:55+0200] [ALPM] removed xfce4-power-manager (4.16.0-3)
[2021-06-28T13:40:55+0200] [ALPM] removed xfce4-notifyd (0.6.2-2)
[2021-06-28T13:40:55+0200] [ALPM] removed lib32-libxss (1.2.3-1)
[2021-06-28T13:40:55+0200] [ALPM] removed nemo (4.8.6-1)
[2021-06-28T13:40:55+0200] [ALPM] removed exempi (2.5.2-1)
[2021-06-28T13:40:55+0200] [ALPM] removed cinnamon-desktop (4.8.1-1)
[2021-06-28T13:40:55+0200] [ALPM] removed deepin-system-monitor (5.8.6-1)
[2021-06-28T13:40:55+0200] [ALPM] removed deepin-qt5integration (5.1.12-1)
[2021-06-28T13:40:55+0200] [ALPM] removed deepin-qt5platform-plugins (5.0.23-2)
[2021-06-28T13:40:55+0200] [ALPM] removed dtkwm (2.0.12-10)
[2021-06-28T13:40:55+0200] [ALPM] removed xfce4-appfinder (4.16.1-2)
[2021-06-28T13:40:55+0200] [ALPM] removed lib32-tdb (1.4.3-1)
[2021-06-28T13:40:55+0200] [ALPM] removed xfwm4 (4.16.1-2)
[2021-06-28T13:40:55+0200] [ALPM] removed lib32-librsvg (2:2.50.7-1)
[2021-06-28T13:40:55+0200] [ALPM] removed lib32-gdk-pixbuf2 (2.42.6-1)
[2021-06-28T13:40:55+0200] [ALPM] removed smplayer (21.1.0-1)
[2021-06-28T13:40:55+0200] [ALPM] removed mpv (1:0.33.1-2)
[2021-06-28T13:40:55+0200] [ALPM] removed libplacebo (3.120.3-1)
[2021-06-28T13:40:55+0200] [ALPM] removed mujs (1.1.2-1)
[2021-06-28T13:40:55+0200] [ALPM] removed uchardet (0.0.7-1)
[2021-06-28T13:40:55+0200] [ALPM] removed rubberband (1.9.2-1)
[2021-06-28T13:40:55+0200] [ALPM] removed qt5-script (5.15.2-1)
[2021-06-28T13:40:55+0200] [ALPM] removed lua52-socket (20200329-1)
[2021-06-28T13:40:55+0200] [ALPM] removed electron6 (6.1.12-5)
[2021-06-28T13:40:55+0200] [ALPM] removed ffmpegthumbnailer (2.2.2-2)
[2021-06-28T13:40:55+0200] [ALPM] removed baobab (40.0-1)
[2021-06-28T13:40:55+0200] [ALPM] removed libhandy (1.2.2-1)
[2021-06-28T13:40:55+0200] [ALPM] removed lib32-libsoup (2.72.0-1)
[2021-06-28T13:40:55+0200] [ALPM] removed lib32-brotli (1.0.9-1)
[2021-06-28T13:40:55+0200] [ALPM] removed lib32-sqlite (3.35.5-1)
[2021-06-28T13:40:55+0200] [ALPM] removed lib32-glib-networking (2.68.1-1)
[2021-06-28T13:40:55+0200] [ALPM] removed lib32-jack (0.125.0-3)
[2021-06-28T13:40:55+0200] [ALPM] removed lib32-db (5.3.28-4)
[2021-06-28T13:40:55+0200] [ALPM] removed xfce4-cpugraph-plugin (1.2.3-1)
[2021-06-28T13:40:55+0200] [ALPM] removed lib32-alsa-plugins (1.2.5-1)
[2021-06-28T13:40:55+0200] [ALPM] removed krename (5.0.1-2)
[2021-06-28T13:40:55+0200] [ALPM] removed kjs (5.82.0-1)
[2021-06-28T13:40:55+0200] [ALPM] removed xfdesktop (4.16.0-2)
[2021-06-28T13:40:55+0200] [ALPM] removed pidgin (2.14.5-1)
[2021-06-28T13:40:55+0200] [ALPM] removed libpurple (2.14.5-1)
[2021-06-28T13:40:55+0200] [ALPM] removed libgadu (1.12.2-13)
[2021-06-28T13:40:55+0200] [ALPM] removed farstream (0.2.9-2)
[2021-06-28T13:40:55+0200] [ALPM] removed gtkspell (2.0.16-8)
[2021-06-28T13:40:55+0200] [ALPM] removed libgphoto2 (2.5.27-1)
[2021-06-28T13:40:55+0200] [ALPM] removed python-jade-application-kit (3.5.6-3)
[2021-06-28T13:40:56+0200] [ALPM] removed pyside2 (5.15.2-3)
[2021-06-28T13:40:56+0200] [ALPM] removed python-shiboken2 (5.15.2-8)
[2021-06-28T13:40:56+0200] [ALPM] removed python-pyqt5-webengine (5.15.4-1)
[2021-06-28T13:40:56+0200] [ALPM] removed gtkd (3.9.0-12)
[2021-06-28T13:40:56+0200] [ALPM] removed light-locker (1.9.0-4)
[2021-06-28T13:40:56+0200] [ALPM] removed xapp (2.0.7-1)
[2021-06-28T13:40:56+0200] [ALPM] removed libgnomekbd (3.26.1+2+g8d02ebd-2)
[2021-06-28T13:40:56+0200] [ALPM] removed kdnssd (5.82.0-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-libproxy (0.4.17-1)
[2021-06-28T13:40:56+0200] [ALPM] removed mugshot (0.4.3-1)
[2021-06-28T13:40:56+0200] [ALPM] removed python-distutils-extra (2.39-8)
[2021-06-28T13:40:56+0200] [ALPM] removed python-pexpect (4.8.0-3)
[2021-06-28T13:40:56+0200] [ALPM] removed python-ptyprocess (0.7.0-1)
[2021-06-28T13:40:56+0200] [ALPM] removed xfce4-session-gtk3 (2019.08.15-1)
[2021-06-28T13:40:56+0200] [ALPM] removed udiskie (2.3.3-1)
[2021-06-28T13:40:56+0200] [ALPM] removed python-docopt (0.6.2-9)
[2021-06-28T13:40:56+0200] [ALPM] removed python-keyutils (0.6-6)
[2021-06-28T13:40:56+0200] [ALPM] removed thunar-archive-plugin (0.4.0-3)
[2021-06-28T13:40:56+0200] [ALPM] removed protobuf-c (1.3.3-4)
[2021-06-28T13:40:56+0200] [ALPM] removed python-pyxdg (0.27-1)
[2021-06-28T13:40:56+0200] [ALPM] removed tracker3 (3.1.1-2)
[2021-06-28T13:40:56+0200] [ALPM] removed xfce4-mailwatch-plugin (1.3.0-1)
[2021-06-28T13:40:56+0200] [ALPM] removed dtkwidget (5.5.7-1)
[2021-06-28T13:40:56+0200] [ALPM] removed dtkgui (5.5.2-1)
[2021-06-28T13:40:56+0200] [ALPM] removed deepin-qt-dbus-factory (5.4.5-1)
[2021-06-28T13:40:56+0200] [ALPM] removed dtkcore (1:5.4.15-1)
[2021-06-28T13:40:56+0200] [ALPM] removed deepin-desktop-base (2:2021.5.07-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lshw (B.02.19.2-1)
[2021-06-28T13:40:56+0200] [ALPM] removed gsettings-qt (0.1.20170110-3)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-libxinerama (1.1.4-1)
[2021-06-28T13:40:56+0200] [ALPM] removed libdmapsharing (2.9.39-3)
[2021-06-28T13:40:56+0200] [ALPM] removed gvfs-afc (1.48.1-1)
[2021-06-28T13:40:56+0200] [ALPM] removed xfce4-time-out-plugin (1.1.2-1)
[2021-06-28T13:40:56+0200] [ALPM] removed libxpresent (1.0.0+2+gdd6771c-2)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-atk (2.36.0-2)
[2021-06-28T13:40:56+0200] [ALPM] removed shaderc (2021.0-1)
[2021-06-28T13:40:56+0200] [ALPM] removed glslang (11.4.0-1)
[2021-06-28T13:40:56+0200] [ALPM] removed spirv-tools (2021.1-1)
[2021-06-28T13:40:56+0200] [ALPM] removed bamf (0.5.5-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-pango (1:1.48.5-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-cairo (1.17.4-5)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-pixman (0.40.0-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-fribidi (1.0.10-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-libxft (2.3.3-1)
[2021-06-28T13:40:56+0200] [ALPM] removed clutter-gtk (1.8.4-2)
[2021-06-28T13:40:56+0200] [ALPM] removed clutter (1.26.4-1)
[2021-06-28T13:40:56+0200] [ALPM] removed cogl (1.22.8-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lua52-luajson (1.3.4-3)
[2021-06-28T13:40:56+0200] [ALPM] removed lua52-lpeg (1.0.2-3)
[2021-06-28T13:40:56+0200] [ALPM] removed audacious (4.1-3)
[2021-06-28T13:40:56+0200] [ALPM] removed libguess (1.2-3)
[2021-06-28T13:40:56+0200] [ALPM] removed audacious-plugins (4.1-3)
[2021-06-28T13:40:56+0200] [ALPM] removed libcue (2.2.1-2)
[2021-06-28T13:40:56+0200] [ALPM] removed libosinfo (1.9.0-1)
[2021-06-28T13:40:56+0200] [ALPM] removed osinfo-db (20210531-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-libxtst (1.2.3-2)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-alsa-oss (1.1.8-2)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-alsa-lib (1.2.4-2)
[2021-06-28T13:40:56+0200] [ALPM] removed spotify (1:1.1.56.595-1)
[2021-06-28T13:40:56+0200] [ALPM] removed libcurl-gnutls (7.77.0-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-libthai (0.1.28-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-libdatrie (0.2.13-1)
[2021-06-28T13:40:56+0200] [ALPM] removed gst-plugin-libde265 (0.1.12-1)
[2021-06-28T13:40:56+0200] [ALPM] removed libqtxdg (3.7.1-1)
[2021-06-28T13:40:56+0200] [ALPM] removed manjaro-alsa (20210109-1)
[2021-06-28T13:40:56+0200] [ALPM] removed alsa-oss (1.1.8-3)
[2021-06-28T13:40:56+0200] [ALPM] removed alsa-utils (1.2.5-3)
[2021-06-28T13:40:56+0200] [ALPM] removed python-pycups (2.0.1-3)
[2021-06-28T13:40:56+0200] [ALPM] removed xfce4-cpufreq-plugin (1.2.5-1)
[2021-06-28T13:40:56+0200] [ALPM-SCRIPTLET] Removed /etc/systemd/user/sockets.target.wants/pipewire.socket.
[2021-06-28T13:40:56+0200] [ALPM] removed pipewire (1:0.3.30-1)
[2021-06-28T13:40:56+0200] [ALPM] removed libldac (2.0.2.3-1)
[2021-06-28T13:40:56+0200] [ALPM] removed alsa-card-profiles (1:0.3.30-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-libcups (2.3.3-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-gnutls (3.7.2-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-nettle (3.7.2-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-gmp (6.2.1-1)
[2021-06-28T13:40:56+0200] [ALPM] removed blueman (2.1.4-1)
[2021-06-28T13:40:56+0200] [ALPM] removed python-cairo (1.20.0-3)
[2021-06-28T13:40:56+0200] [ALPM] removed web-installer-url-handler (1.0.2-1)
[2021-06-28T13:40:56+0200] [ALPM] removed pamac-gtk (10.0.6-2)
[2021-06-28T13:40:56+0200] [ALPM] removed qt5-webkit (5.212.0alpha4-10)
[2021-06-28T13:40:56+0200] [ALPM] removed manjaro-application-utility (1.3.3-4.1)
[2021-06-28T13:40:56+0200] [ALPM] removed pamac-cli (10.0.6-2)
[2021-06-28T13:40:56+0200] [ALPM] warning: /etc/pamac.conf saved as /etc/pamac.conf.pacsave
[2021-06-28T13:40:56+0200] [ALPM] removed pamac-common (10.0.6-2)
[2021-06-28T13:40:56+0200] [ALPM] removed archlinux-appstream-data (20210423-1)
[2021-06-28T13:40:56+0200] [ALPM] removed vte3 (0.64.2-2)
[2021-06-28T13:40:56+0200] [ALPM] removed vte-common (0.64.2-2)
[2021-06-28T13:40:56+0200] [ALPM] removed thunar-gtk3 (2019.08.15-1)
[2021-06-28T13:40:56+0200] [ALPM] removed kcalendarcore (5.82.0-1)
[2021-06-28T13:40:56+0200] [ALPM] removed libsidplayfp (2.1.2-1)
[2021-06-28T13:40:56+0200] [ALPM] removed gvfs-mtp (1.48.1-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lua52 (5.2.4-5)
[2021-06-28T13:40:56+0200] [ALPM] removed gvfs (1.48.1-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-colord (1.4.5-3)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-p11-kit (0.23.22-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-libtasn1 (4.16.0-2)
[2021-06-28T13:40:56+0200] [ALPM] removed wine (6.10-1)
[2021-06-28T13:40:56+0200] [ALPM-SCRIPTLET] binfmt binary formats will be updated at reboot
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-libpcap (1.10.0-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-gettext (0.21-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-acl (2.3.1-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-libxrandr (1.5.2-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-lcms2 (2.12-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-libtiff (4.3.0-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-libjpeg-turbo (2.1.0-1)
[2021-06-28T13:40:56+0200] [ALPM] removed lib32-fontconfig (2:2.13.93-4)
[2021-06-28T13:40:56+0200] [ALPM] removed signon-ui (0.17+20171022-2)
[2021-06-28T13:40:56+0200] [ALPM] removed libaccounts-qt (1.16-3)
[2021-06-28T13:40:56+0200] [ALPM] removed libaccounts-glib (1.25-4)
[2021-06-28T13:40:56+0200] [ALPM] removed thunar-volman (4.16.0-1)
[2021-06-28T13:40:57+0200] [ALPM] removed thunar (4.16.8-1)
[2021-06-28T13:40:57+0200] [ALPM] removed mplayer (38157-4)
[2021-06-28T13:40:57+0200] [ALPM] removed enca (1.19-4)
[2021-06-28T13:40:57+0200] [ALPM] removed recode (3.7.9-1)
[2021-06-28T13:40:57+0200] [ALPM] removed libcdio-paranoia (10.2+2.0.1-2)
[2021-06-28T13:40:57+0200] [ALPM] removed libxvmc (1.0.12-3)
[2021-06-28T13:40:57+0200] [ALPM] removed gnome-video-effects (0.5.0+4+g9554041-2)
[2021-06-28T13:40:57+0200] [ALPM] removed frei0r-plugins (1.7.0-1)
[2021-06-28T13:40:57+0200] [ALPM] removed gavl (1.4.0-5)
[2021-06-28T13:40:57+0200] [ALPM] removed libnfs (4.0.0-4)
[2021-06-28T13:40:57+0200] [ALPM] removed xfce4-whiskermenu-plugin-gtk3 (2019.08.15-1)
[2021-06-28T13:40:57+0200] [ALPM] removed xfce4-pulseaudio-plugin (0.4.3-1.1)
[2021-06-28T13:40:57+0200] [ALPM] removed libkeybinder3 (0.3.2-3)
[2021-06-28T13:40:57+0200] [ALPM] removed libportal (0.4-1)
[2021-06-28T13:40:57+0200] [ALPM] removed lib32-faudio (21.06-1)
[2021-06-28T13:40:57+0200] [ALPM] removed faudio (21.06-1)
[2021-06-28T13:40:57+0200] [ALPM] removed gst-libav (1.18.4-1)
[2021-06-28T13:40:57+0200] [ALPM] removed lib32-sdl2 (2.0.14-1)
[2021-06-28T13:40:57+0200] [ALPM] removed lib32-libxcursor (1.2.0-1)
[2021-06-28T13:40:57+0200] [ALPM] removed lib32-libxrender (0.9.10-2)
[2021-06-28T13:40:57+0200] [ALPM] removed lib32-dbus (1.12.20-1)
[2021-06-28T13:40:57+0200] [ALPM] removed lua52-expat (1.3.0-5)
[2021-06-28T13:40:57+0200] [ALPM] removed network-manager-applet (1.22.0-1)
[2021-06-28T13:40:57+0200] [ALPM] removed nm-connection-editor (1.22.0-1)
[2021-06-28T13:40:57+0200] [ALPM] removed libnma (1.8.30-1)
[2021-06-28T13:40:57+0200] [ALPM] removed libappindicator-gtk3 (12.10.0.r296-1)
[2021-06-28T13:40:57+0200] [ALPM] removed libindicator-gtk3 (12.10.1-9)
[2021-06-28T13:40:57+0200] [ALPM] removed lutris (0.5.8.3-2)
[2021-06-28T13:40:57+0200] [ALPM] removed python-yaml (5.4.1.1-2)
[2021-06-28T13:40:57+0200] [ALPM] removed cabextract (1.9.1-2)
[2021-06-28T13:40:57+0200] [ALPM] removed libgxps (0.3.2-1)
[2021-06-28T13:40:57+0200] [ALPM] removed lightdm-gtk-greeter-settings (1.2.2-5)
[2021-06-28T13:40:57+0200] [ALPM] warning: /etc/lightdm/lightdm-gtk-greeter.conf saved as /etc/lightdm/lightdm-gtk-greeter.conf.pacsave
[2021-06-28T13:40:57+0200] [ALPM] removed lightdm-gtk-greeter (1:2.0.8-1)
[2021-06-28T13:40:57+0200] [ALPM] removed signon-plugin-oauth2 (0.25-1)
[2021-06-28T13:40:57+0200] [ALPM] removed signond (8.60-3)
[2021-06-28T13:40:57+0200] [ALPM] removed lib32-libasyncns (0.8+3+g68cd5af-2)
[2021-06-28T13:40:57+0200] [ALPM] removed qt5-webengine (5.15.4-3)
[2021-06-28T13:40:57+0200] [ALPM] removed minizip (1:1.2.11-4)
[2021-06-28T13:40:57+0200] [ALPM] removed qt5-location (5.15.2-3)
[2021-06-28T13:40:57+0200] [ALPM] removed liblphobos (2:1.26.0-3)
[2021-06-28T13:40:57+0200] [ALPM] removed xdg-desktop-portal-gtk (1.8.0-1)
[2021-06-28T13:40:57+0200] [ALPM] removed gnome-keyring (1:40.0-1)
[2021-06-28T13:40:57+0200] [ALPM] warning: /etc/security/limits.d/10-gcr.conf saved as /etc/security/limits.d/10-gcr.conf.pacsave
[2021-06-28T13:40:57+0200] [ALPM] removed gcr (3.40.0-1)
[2021-06-28T13:40:57+0200] [ALPM] removed gnome-desktop (1:40.1-2)
[2021-06-28T13:40:57+0200] [ALPM] removed dtkcommon (5.5.3-1)
[2021-06-28T13:40:57+0200] [ALPM] removed manjaro-pulse (20210109-1)
[2021-06-28T13:40:57+0200] [ALPM] removed pulseaudio-bluetooth (14.2-3)
[2021-06-28T13:40:57+0200] [ALPM] removed bluez (5.58-1)
[2021-06-28T13:40:57+0200] [ALPM] removed libical (3.0.10-1)
[2021-06-28T13:40:57+0200] [ALPM] removed pulseaudio-lirc (14.2-3)
[2021-06-28T13:40:57+0200] [ALPM] removed lirc (1:0.10.1-8)
[2021-06-28T13:40:57+0200] [ALPM] removed libftdi (1.5-2)
[2021-06-28T13:40:57+0200] [ALPM] removed confuse (3.3-3)
[2021-06-28T13:40:57+0200] [ALPM] removed sof-firmware (1.7-2)
[2021-06-28T13:40:57+0200] [ALPM] removed pulseaudio-alsa (1:1.2.5-2)
[2021-06-28T13:40:57+0200] [ALPM] removed alsa-plugins (1:1.2.5-2)
[2021-06-28T13:40:57+0200] [ALPM] removed pulseaudio-jack (14.2-3)
[2021-06-28T13:40:57+0200] [ALPM] removed xfce4-whiskermenu-plugin (2.5.3-1)
[2021-06-28T13:40:57+0200] [ALPM] removed zenity (3.32.0+55+gd7bedff-1)
[2021-06-28T13:40:57+0200] [ALPM] removed webkit2gtk (2.32.1-1)
[2021-06-28T13:40:57+0200] [ALPM] removed xdg-dbus-proxy (0.1.2-3)
[2021-06-28T13:40:57+0200] [ALPM] removed wpebackend-fdo (1.9.92-1)
[2021-06-28T13:40:57+0200] [ALPM] removed enchant (2.2.15-2)
[2021-06-28T13:40:57+0200] [ALPM] removed libmanette (0.2.6-2)
[2021-06-28T13:40:57+0200] [ALPM] removed woff2 (1.0.2-3)
[2021-06-28T13:40:57+0200] [ALPM] removed libwpe (1.10.0-1)
[2021-06-28T13:40:57+0200] [ALPM] removed libmediaart (1.9.5-1)
[2021-06-28T13:40:57+0200] [ALPM] removed appstream-glib (0.7.18-2)
[2021-06-28T13:40:57+0200] [ALPM] removed libstemmer (0+713-2)
[2021-06-28T13:40:57+0200] [ALPM] removed gcab (1.4-1)
[2021-06-28T13:40:57+0200] [ALPM] removed qt5-webchannel (5.15.2-1)
[2021-06-28T13:40:57+0200] [ALPM] removed libopenaptx (0.2.0-1)
[2021-06-28T13:40:57+0200] [ALPM] removed xfce4-taskmanager (1.4.2-1)
[2021-06-28T13:40:57+0200] [ALPM] removed xfce4-timer-plugin (1.7.1-1)
[2021-06-28T13:40:57+0200] [ALPM] removed xfce4-settings (4.16.2-1)
[2021-06-28T13:40:57+0200] [ALPM] removed xfce4-session (4.16.0-2)
[2021-06-28T13:40:57+0200] [ALPM] removed xorg-iceauth (1.0.8-2)
[2021-06-28T13:40:57+0200] [ALPM] removed polkit-gnome (0.105-8)
[2021-06-28T13:40:57+0200] [ALPM] removed libiptcdata (1.0.4-5)
[2021-06-28T13:40:57+0200] [ALPM] removed kwayland (5.82.0-1)
[2021-06-28T13:40:57+0200] [ALPM] removed xfce4-systemload-plugin (1.3.1-1)
[2021-06-28T13:40:57+0200] [ALPM] removed xfce4-panel (4.16.3-2)
[2021-06-28T13:40:57+0200] [ALPM] removed libdbusmenu-gtk3 (16.04.0-4)
[2021-06-28T13:40:57+0200] [ALPM] removed libdbusmenu-glib (16.04.0-4)
[2021-06-28T13:40:57+0200] [ALPM] removed garcon (4.16.1-1)
[2021-06-28T13:40:57+0200] [ALPM] removed libwnck3 (40.0-1)
[2021-06-28T13:40:57+0200] [ALPM] removed libxres (1.2.1-1)
[2021-06-28T13:40:57+0200] [ALPM] removed exo (4.16.2-1)
[2021-06-28T13:40:57+0200] [ALPM] removed libxfce4ui (4.16.0-1)
[2021-06-28T13:40:57+0200] [ALPM] removed libgtop (2.40.0+2+g31db82ef-2)
[2021-06-28T13:40:57+0200] [ALPM] removed pavucontrol (1:4.0-2)
[2021-06-28T13:40:57+0200] [ALPM] removed gtkmm3 (3.24.5-2)
[2021-06-28T13:40:57+0200] [ALPM] removed atkmm (2.28.2-2)
[2021-06-28T13:40:57+0200] [ALPM] removed pangomm (2.46.1-2)
[2021-06-28T13:40:57+0200] [ALPM] removed cairomm (1.14.3-2)
[2021-06-28T13:40:57+0200] [ALPM] removed glibmm (2.66.1-2)
[2021-06-28T13:40:57+0200] [ALPM] removed libsigc++ (2.10.7-2)
[2021-06-28T13:40:57+0200] [ALPM] removed lib32-libnl (3.5.0-1)
[2021-06-28T13:40:57+0200] [ALPM] removed bubblewrap (0.4.1-2)
[2021-06-28T13:40:57+0200] [ALPM] removed podofo (0.9.7-1)
[2021-06-28T13:40:57+0200] [ALPM] removed kompare (21.04.1-1)
[2021-06-28T13:40:57+0200] [ALPM] removed ktexteditor (5.82.0-2)
[2021-06-28T13:40:57+0200] [ALPM] removed libgit2 (1:1.1.0-1)
[2021-06-28T13:40:57+0200] [ALPM] removed http-parser (2.9.4-1)
[2021-06-28T13:40:57+0200] [ALPM] removed editorconfig-core-c (0.12.4-1)
[2021-06-28T13:40:58+0200] [ALPM] removed kparts (5.82.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed syntax-highlighting (5.82.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libkomparediff2 (21.04.1-1)
[2021-06-28T13:40:58+0200] [ALPM] removed kio (5.82.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed ktextwidgets (5.82.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed kcompletion (5.82.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed sonnet (5.82.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed solid (5.82.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed media-player-info (24-2)
[2021-06-28T13:40:58+0200] [ALPM] removed kwallet (5.82.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed knotifications (5.82.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libdbusmenu-qt5 (0.9.3+16.04.20160218-5)
[2021-06-28T13:40:58+0200] [ALPM] removed qt5-speech (5.15.2-1)
[2021-06-28T13:40:58+0200] [ALPM] removed qt5-multimedia (5.15.2-1)
[2021-06-28T13:40:58+0200] [ALPM] removed gst-plugins-base (1.18.4-1)
[2021-06-28T13:40:58+0200] [ALPM] removed graphene (1.10.6-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libvisual (0.4.0-8)
[2021-06-28T13:40:58+0200] [ALPM] removed cdparanoia (10.2-8)
[2021-06-28T13:40:58+0200] [ALPM] removed kjobwidgets (5.82.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed kded (5.82.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed kservice (5.82.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed gst-plugins-bad (1.18.4-7)
[2021-06-28T13:40:58+0200] [ALPM] removed zvbi (0.2.35-4)
[2021-06-28T13:40:58+0200] [ALPM] removed libavtp (0.1.0-2)
[2021-06-28T13:40:58+0200] [ALPM] removed libmpcdec (1:0.1+r475-3)
[2021-06-28T13:40:58+0200] [ALPM] removed gst-plugins-good (1.18.4-2)
[2021-06-28T13:40:58+0200] [ALPM] removed mpg123 (1.28.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libcaca (0.99.beta19-5)
[2021-06-28T13:40:58+0200] [ALPM] removed aalib (1.4rc5-14)
[2021-06-28T13:40:58+0200] [ALPM] removed taglib (1.12-1)
[2021-06-28T13:40:58+0200] [ALPM] removed twolame (0.4.0-2)
[2021-06-28T13:40:58+0200] [ALPM] removed libshout (1:2.4.5-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libmms (0.6.4-3)
[2021-06-28T13:40:58+0200] [ALPM] removed sbc (1.5-2)
[2021-06-28T13:40:58+0200] [ALPM] removed chromaprint (1.5.0-3)
[2021-06-28T13:40:58+0200] [ALPM] removed ffmpeg (2:4.4-3)
[2021-06-28T13:40:58+0200] [ALPM] removed lame (3.100-3)
[2021-06-28T13:40:58+0200] [ALPM] removed libiec61883 (1.2.0-6)
[2021-06-28T13:40:58+0200] [ALPM] removed libavc1394 (0.5.4-4)
[2021-06-28T13:40:58+0200] [ALPM] removed vid.stab (1.1-3)
[2021-06-28T13:40:58+0200] [ALPM] removed libvpx (1.10.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libmfx (21.1.3-2)
[2021-06-28T13:40:58+0200] [ALPM] removed zimg (3.0.1-2)
[2021-06-28T13:40:58+0200] [ALPM] removed libtheora (1.1.1-5)
[2021-06-28T13:40:58+0200] [ALPM] removed libssh (0.9.5-1)
[2021-06-28T13:40:58+0200] [ALPM] removed vmaf (1.5.3-1)
[2021-06-28T13:40:58+0200] [ALPM] removed gsm (1.0.19-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libbluray (1.3.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed xvidcore (1.3.7-2)
[2021-06-28T13:40:58+0200] [ALPM] removed libfdk-aac (2.0.2-1)
[2021-06-28T13:40:58+0200] [ALPM] removed gst-plugins-bad-libs (1.18.4-7)
[2021-06-28T13:40:58+0200] [ALPM] removed srt (1.4.3-1)
[2021-06-28T13:40:58+0200] [ALPM] removed mjpegtools (2.2.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libdv (1.0.0-9)
[2021-06-28T13:40:58+0200] [ALPM] removed lilv (0.24.12-1)
[2021-06-28T13:40:58+0200] [ALPM] removed sratom (0.6.8-1)
[2021-06-28T13:40:58+0200] [ALPM] removed sord (0.16.8-1)
[2021-06-28T13:40:58+0200] [ALPM] removed serd (0.30.10-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libofa (0.9.3-9)
[2021-06-28T13:40:58+0200] [ALPM] removed libdc1394 (2.2.6-2)
[2021-06-28T13:40:58+0200] [ALPM] removed libraw1394 (2.1.2-3)
[2021-06-28T13:40:58+0200] [ALPM] removed faac (1.30-2)
[2021-06-28T13:40:58+0200] [ALPM] removed libmodplug (0.8.9.0-3)
[2021-06-28T13:40:58+0200] [ALPM] removed zxing-cpp (1.2.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed svt-hevc (1.5.1-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libnice (0.1.18-2)
[2021-06-28T13:40:58+0200] [ALPM] removed gupnp-igd (1.2.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed gupnp (1.2.7-1)
[2021-06-28T13:40:58+0200] [ALPM] removed gssdp (1.2.3-1)
[2021-06-28T13:40:58+0200] [ALPM] removed spandsp (0.0.6-3)
[2021-06-28T13:40:58+0200] [ALPM] removed libdca (0.0.7-1)
[2021-06-28T13:40:58+0200] [ALPM] removed soundtouch (2.2-1)
[2021-06-28T13:40:58+0200] [ALPM] removed faad2 (2.10.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed wildmidi (0.4.4-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libgme (0.6.3-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libdvdnav (6.1.1-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libbs2b (3.1.0-7)
[2021-06-28T13:40:58+0200] [ALPM] removed libass (0.15.1-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libsrtp (1:2.3.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed liblrdf (0.6.1-4)
[2021-06-28T13:40:58+0200] [ALPM] removed fluidsynth (2.1.8-1)
[2021-06-28T13:40:58+0200] [ALPM] removed portaudio (1:19.7.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libinstpatch (1.1.6-1)
[2021-06-28T13:40:58+0200] [ALPM] removed sdl2 (2.0.14-1)
[2021-06-28T13:40:58+0200] [ALPM] removed hidapi (0.10.1-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libibus (1.5.24-1)
[2021-06-28T13:40:58+0200] [ALPM] removed jack (0.125.0-9)
[2021-06-28T13:40:58+0200] [ALPM] removed zita-alsa-pcmi (0.3.2-3)
[2021-06-28T13:40:58+0200] [ALPM] removed zita-resampler (1.8.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libsamplerate (0.2.1-1)
[2021-06-28T13:40:58+0200] [ALPM] removed zbar (0.23.1-7)
[2021-06-28T13:40:58+0200] [ALPM] removed v4l-utils (1.20.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed mousepad (0.5.5-3)
[2021-06-28T13:40:58+0200] [ALPM] removed gtksourceview4 (4.8.1-1)
[2021-06-28T13:40:58+0200] [ALPM] removed gtk3 (1:3.24.29-2)
[2021-06-28T13:40:58+0200] [ALPM] removed libcanberra (0.30+2+gc0620e4-4)
[2021-06-28T13:40:58+0200] [ALPM] removed alsa-lib-a52pcm (1.2.4-1)
[2021-06-28T13:40:58+0200] [ALPM] removed alsa-topology-conf (1.2.5-1)
[2021-06-28T13:40:58+0200] [ALPM] removed alsa-ucm-conf (1.2.5-1)
[2021-06-28T13:40:58+0200] [ALPM] removed sound-theme-freedesktop (0.8-4)
[2021-06-28T13:40:58+0200] [ALPM] removed rest (0.8.1-3)
[2021-06-28T13:40:58+0200] [ALPM] removed libsoup (2.72.0+10+gfe1e295d-1)
[2021-06-28T13:40:58+0200] [ALPM] removed wayland-protocols (1.21-1)
[2021-06-28T13:40:58+0200] [ALPM] removed at-spi2-atk (2.38.0-1)
[2021-06-28T13:40:58+0200] [ALPM] removed at-spi2-core (2.40.2-1)
[2021-06-28T13:40:58+0200] [ALPM] removed libcloudproviders (0.3.1-2)
[2021-06-28T13:40:58+0200] [ALPM] removed kbookmarks (5.82.0-1)
[2021-06-28T13:40:59+0200] [ALPM] removed kxmlgui (5.82.0-1)
[2021-06-28T13:40:59+0200] [ALPM] removed attica (5.82.0-1)
[2021-06-28T13:40:59+0200] [ALPM] removed kglobalaccel (5.82.0-1)
[2021-06-28T13:40:59+0200] [ALPM] removed kdbusaddons (5.82.0-1)
[2021-06-28T13:40:59+0200] [ALPM] removed kcrash (5.82.0-1)
[2021-06-28T13:40:59+0200] [ALPM] removed kiconthemes (5.82.0-1)
[2021-06-28T13:40:59+0200] [ALPM] removed karchive (5.82.0-1)
[2021-06-28T13:40:59+0200] [ALPM] removed kitemviews (5.82.0-1)
[2021-06-28T13:40:59+0200] [ALPM] removed kconfigwidgets (5.82.0-1)
[2021-06-28T13:40:59+0200] [ALPM] removed ki18n (5.82.0-1)
[2021-06-28T13:40:59+0200] [ALPM] removed kguiaddons (5.82.0-1)
[2021-06-28T13:40:59+0200] [ALPM] removed kwidgetsaddons (5.82.0-1)
[2021-06-28T13:40:59+0200] [ALPM] removed kcodecs (5.82.0-1)
[2021-06-28T13:40:59+0200] [ALPM] transaction completed
[2021-06-28T13:41:00+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-06-28T13:41:00+0200] [ALPM] running '30-systemd-hwdb.hook'...
[2021-06-28T13:41:00+0200] [ALPM] running '30-systemd-udev-reload.hook'...
[2021-06-28T13:41:00+0200] [ALPM] running '30-systemd-update.hook'...
[2021-06-28T13:41:00+0200] [ALPM] running '40-fontconfig-config.hook'...
[2021-06-28T13:41:00+0200] [ALPM] running 'dbus-reload.hook'...
[2021-06-28T13:41:00+0200] [ALPM] running 'fontconfig.hook'...
[2021-06-28T13:41:00+0200] [ALPM] running 'gio-querymodules.hook'...
[2021-06-28T13:41:00+0200] [ALPM] running 'gio-querymodules-32.hook'...
[2021-06-28T13:41:00+0200] [ALPM] running 'glib-compile-schemas.hook'...
[2021-06-28T13:41:00+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-06-28T13:41:00+0200] [ALPM] running 'manjaro-xfce-settings.hook'...
[2021-06-28T13:41:00+0200] [ALPM-SCRIPTLET] '/usr/share/backgrounds/xfce/illyria-default.jpg' -> '/usr/share/backgrounds/illyria-default.jpg'
[2021-06-28T13:41:00+0200] [ALPM-SCRIPTLET] '/usr/share/backgrounds/xfce/illyria-default-lockscreen.jpg' -> '/usr/share/backgrounds/illyria-default-lockscreen.jpg'
[2021-06-28T13:41:00+0200] [ALPM] running 'update-desktop-database.hook'...
[2021-06-28T13:41:00+0200] [ALPM] running 'update-mime-database.hook'...
[2021-06-28T13:47:00+0200] [PACMAN] Running 'pacman -Syu'
[2021-06-28T13:47:00+0200] [PACMAN] synchronizing package lists
[2021-06-28T13:47:01+0200] [PACMAN] starting full system upgrade
[2021-06-28T13:50:27+0200] [PACMAN] Running 'pacman -S lightdm-gtk-geeker'
[2021-06-28T13:50:40+0200] [PACMAN] Running 'pacman -S lightdm-gtk-greeker'
[2021-06-28T13:50:44+0200] [PACMAN] Running 'pacman -S lightdm-gtk-greeter'
[2021-06-28T13:51:07+0200] [PACMAN] Running 'pacman -S alsa-lib'
[2021-06-28T13:51:13+0200] [ALPM] transaction started
[2021-06-28T13:51:13+0200] [ALPM] installed alsa-topology-conf (1.2.5-1)
[2021-06-28T13:51:13+0200] [ALPM] installed alsa-ucm-conf (1.2.5-1)
[2021-06-28T13:51:13+0200] [ALPM] installed alsa-lib (1.2.5-2)
[2021-06-28T13:51:13+0200] [ALPM] transaction completed
[2021-06-28T13:51:13+0200] [ALPM] running '30-systemd-update.hook'...
[2021-06-28T13:51:23+0200] [PACMAN] Running 'pacman -S lightdm-gtk-greeter'
[2021-06-28T13:51:33+0200] [ALPM] transaction started
[2021-06-28T13:51:33+0200] [ALPM] installed at-spi2-core (2.40.2-1)
[2021-06-28T13:51:33+0200] [ALPM] installed at-spi2-atk (2.38.0-1)
[2021-06-28T13:51:33+0200] [ALPM] installed wayland-protocols (1.21-1)
[2021-06-28T13:51:33+0200] [ALPM] installed libsoup (2.72.0+10+gfe1e295d-1)
[2021-06-28T13:51:33+0200] [ALPM] installed rest (0.8.1-3)
[2021-06-28T13:51:33+0200] [ALPM] installed sound-theme-freedesktop (0.8-4)
[2021-06-28T13:51:33+0200] [ALPM] installed libcanberra (0.30+2+gc0620e4-4)
[2021-06-28T13:51:33+0200] [ALPM] installed libcloudproviders (0.3.1-2)
[2021-06-28T13:51:33+0200] [ALPM] installed gtk3 (1:3.24.29-2)
[2021-06-28T13:51:33+0200] [ALPM] installed lightdm-gtk-greeter (1:2.0.8-1)
[2021-06-28T13:51:33+0200] [ALPM] transaction completed
[2021-06-28T13:51:33+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-06-28T13:51:33+0200] [ALPM] running '30-systemd-update.hook'...
[2021-06-28T13:51:33+0200] [ALPM] running 'glib-compile-schemas.hook'...
[2021-06-28T13:51:33+0200] [ALPM] running 'gtk-query-immodules-3.0.hook'...
[2021-06-28T13:51:33+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-06-28T13:51:38+0200] [PACMAN] Running 'pacman -S lightdm-gtk-greeter'
[2021-06-28T13:51:41+0200] [ALPM] transaction started
[2021-06-28T13:51:42+0200] [ALPM] reinstalled lightdm-gtk-greeter (1:2.0.8-1)
[2021-06-28T13:51:42+0200] [ALPM] transaction completed
[2021-06-28T13:51:42+0200] [ALPM] running '30-systemd-update.hook'...
[2021-06-28T13:51:42+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-06-28T13:51:44+0200] [PACMAN] Running 'pacman -S lightdm-gtk-greeter'
[2021-06-28T13:51:46+0200] [ALPM] transaction started
[2021-06-28T13:51:46+0200] [ALPM] reinstalled lightdm-gtk-greeter (1:2.0.8-1)
[2021-06-28T13:51:46+0200] [ALPM] transaction completed
[2021-06-28T13:51:46+0200] [ALPM] running '30-systemd-update.hook'...
[2021-06-28T13:51:46+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-06-28T13:51:54+0200] [PACMAN] Running 'pacman -Syu'
[2021-06-28T13:51:54+0200] [PACMAN] synchronizing package lists
[2021-06-28T13:51:55+0200] [PACMAN] starting full system upgrade
XTC0r
5 July 2021 21:33
7
I managed to resolve this issue after extracting all the removed packages from the log and reinstalling them with pacman. I don’t know what caused this mass removing of packages.
Did you use pamac for the removal?
There have been reports in the past about it removing “a surprising lot” of packages and users being not fully aware of the implications.
system
Closed
24 July 2021 18:21
10
