Hello, Linux noob here.
I just recently installed a fresh version of the latest Manjaro (I’m dual booting Windows 10 and Manjaro on separate ssd’s). I’m unable to login using the GUI. When I type in the password, the screen just blanks out for a few seconds and it puts me back on the login screen again. However, using tty2 I’m able to login. This is not my first time installing Manjaro, so I’m pretty certain I didn’t break anything during install.
I already reinstalled Manjaro once (first time I did manual partitioning with open source drivers but I thought I broke something so I reinstalled with proprietary drivers and I let Manjaro do the partitioning). I also tried doing the full system update and switched back to 5.10 LTS kernel, but this didn’t help.
One thing i noticed, while booting up, I don’t get any logs where it says [OK] in the beginning. I just get this (I also get this output when the screen blanks out when trying to login):
/dev/sda2: clean, 303582/13516800 files, 4248838/54041048 blocks
(it did not let me post a picture)
And, when restarting I just get:
watchdog: watchdog0: watchdog did not stop!
My logs:
journalctl -b -1 -p4 ✔
Apr 18 22:37:22 miloye-manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Apr 18 22:37:23 miloye-manjaro kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Apr 18 22:37:23 miloye-manjaro kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Apr 18 22:37:23 miloye-manjaro kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Apr 18 22:37:23 miloye-manjaro kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Apr 18 22:37:23 miloye-manjaro kernel: nvidia: loading out-of-tree module taints kernel.
Apr 18 22:37:23 miloye-manjaro kernel: nvidia: module license 'NVIDIA' taints kernel.
Apr 18 22:37:23 miloye-manjaro kernel: Disabling lock debugging due to kernel taint
Apr 18 22:37:23 miloye-manjaro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 510.60.02 Wed Mar 16 11:24:05 UTC 2022
Apr 18 22:37:23 miloye-manjaro kernel: kvm: disabled by bios
Apr 18 22:37:23 miloye-manjaro kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Apr 18 22:37:23 miloye-manjaro avahi-daemon[552]: Failed to parse address 'fe80::2bb:1cff:fe39:7fb3%enp6s0', ignoring.
Apr 18 22:37:23 miloye-manjaro kernel: usb 1-6: config 1 has an invalid interface number: 2 but max is 1
Apr 18 22:37:23 miloye-manjaro kernel: usb 1-6: config 1 has no interface number 1
Apr 18 22:37:24 miloye-manjaro kernel: kvm: disabled by bios
Apr 18 22:37:24 miloye-manjaro kernel: kauditd_printk_skb: 37 callbacks suppressed
Apr 18 22:37:24 miloye-manjaro kernel: usb 1-2: Warning! Unlikely big volume range (=1008), cval->res is probably wrong.
Apr 18 22:37:24 miloye-manjaro kernel: usb 1-2: [49] FU [PCM Playback Volume] ch = 2, val = -16129/-1/16
Apr 18 22:37:24 miloye-manjaro kernel: usb 1-2: Warning! Unlikely big volume range (=496), cval->res is probably wrong.
Apr 18 22:37:24 miloye-manjaro kernel: usb 1-2: [50] FU [Mic Capture Volume] ch = 1, val = 0/7936/16
Apr 18 22:37:24 miloye-manjaro kernel: resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000c0000-0x000dffff windo>
Apr 18 22:37:24 miloye-manjaro kernel: caller _nv000651rm+0x1ad/0x200 [nvidia] mapping multiple BARs
Apr 18 22:37:27 miloye-manjaro systemd[684]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Apr 18 22:37:27 miloye-manjaro systemd[684]: Failed to start Update XDG user dir configuration.
Apr 18 22:37:27 miloye-manjaro sddm-greeter[693]: QFont::fromString: Invalid description '(empty)'
Apr 18 22:37:27 miloye-manjaro sddm-greeter[693]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffea6b539b0), parent's thread is QThread(0x55c89793dfc0), current thread is QThread(0x55c897>
Apr 18 22:37:27 miloye-manjaro sddm-greeter[693]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Apr 18 22:37:27 miloye-manjaro sddm-greeter[693]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Apr 18 22:37:27 miloye-manjaro sddm-greeter[693]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Apr 18 22:37:27 miloye-manjaro sddm-greeter[693]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not install>
Apr 18 22:37:28 miloye-manjaro sddm-greeter[693]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Apr 18 22:37:28 miloye-manjaro sddm-greeter[693]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.22'
Apr 18 22:37:29 miloye-manjaro kernel: kauditd_printk_skb: 12 callbacks suppressed
Apr 18 22:37:56 miloye-manjaro backlighthelper[977]: org.kde.powerdevil: no kernel backlight interface found
Apr 18 22:37:56 miloye-manjaro org.a11y.Bus[1021]: dbus-daemon[1021]: Activating service name='org.a11y.atspi.Registry' requested by ':1.1' (uid=1000 pid=877 comm="/usr/bin>
Apr 18 22:37:56 miloye-manjaro org.a11y.Bus[1021]: dbus-daemon[1021]: Successfully activated service 'org.a11y.atspi.Registry'
Apr 18 22:37:57 miloye-manjaro pulseaudio[920]: stat('/etc/pulse/default.pa.d'): No such file or directory
Apr 18 22:37:57 miloye-manjaro kernel: kauditd_printk_skb: 19 callbacks suppressed
Apr 18 22:38:21 miloye-manjaro pulseaudio[920]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_>
Apr 18 23:03:30 miloye-manjaro sddm[615]: Error from greeter session: "Process crashed"
Apr 18 23:03:30 miloye-manjaro sddm[615]: Auth: sddm-helper crashed (exit code 15)
Apr 18 23:03:30 miloye-manjaro sddm[615]: Auth: sddm-helper exited with 15
Apr 18 23:03:30 miloye-manjaro sddm[615]: Signal received: SIGTERM
Apr 18 23:03:32 miloye-manjaro kernel: watchdog: watchdog0: watchdog did not stop!
inxi --full INT ✘ 10m 41s
Host: miloye-manjaro Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.24.4 Distro: Manjaro Linux
Mobo: ASUSTeK model: TUF GAMING B550-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2407
date: 07/13/2021
Info: 6-core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP cache: L2: 3 MiB
Speed (MHz): avg: 2384 min/max: 2200/3600 cores: 1: 2594 2: 2054 3: 2055
4: 2057 5: 3599 6: 2056 7: 3598 8: 2056 9: 2058 10: 2057 11: 2561 12: 1866
Device-1: NVIDIA GA106 [Geforce RTX 3050] driver: nvidia v: 510.60.02
Display: server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1 driver: X:
loaded: nvidia gpu: nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce RTX 3050/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02
Device-1: NVIDIA driver: snd_hda_intel
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Device-3: JMTek LLC. FANTECH CAPTAIN 7.1 type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.49 running: yes
Device-1: Realtek RTL8125 2.5GbE driver: r8169
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: 04:42:1a:28:c0:0f
Device-2: Qualcomm Atheros AR9271 802.11n type: USB driver: ath9k_htc
IF: wlp9s0f3u2 state: down mac: 3a:66:d5:db:8e:4c
Local Storage: total: 2.49 TiB used: 11.99 GiB (0.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 500GB
ID-2: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB
ID-3: /dev/sdb vendor: Western Digital model: WD20PURZ-85AKKY0
ID-1: / size: 201.85 GiB used: 11.99 GiB (5.9%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-1: swap-1 type: partition size: 17.12 GiB used: 0 KiB (0.0%)
dev: /dev/sda3
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 35 C
Processes: 291 Uptime: 19m Memory: 15.57 GiB used: 2.22 GiB (14.3%)
Shell: Zsh inxi: 3.3.15
Thanks
