I was trying to install some packages and also deleted all the orphans that I had and then, after reboot, I can’t log into my system and something went wrong with the theme. I type my password, but when I press enter -nothing happens.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
