Hi everyone,
I am currently struggling with an issue with Manjaro Gnome since the last two updates.
Since then, when I start my computer, I can login all fine.
But anytime it turns to lockscreen, when I use it back, the login screen appears but I cannot access my session: It appears as working for a second then it freezes and turns back to lockscreen.
The problem I am issuing is similar to:
https://forum.manjaro.org/t/cant-login-after-update/16231/10
except that I am not using KDE plasma that seems to cause the bug.
I’ve also seen some fixes based on taking care of some .pacnew files in /etc/pam.d but I don’t see any.
Can you help me with that? And what additional piece of information do you need?
Sincerely,
Paul
