I did something not right: I update the system and ignored a package with:
sudo pacman -Syu --ignore icu
Now I can’t login.
If I try to update in another tty:
pacman: error while loading shared libraries: libicuuc.so.76: cannot open shared object file: No such file or directory
Maybe my repository was not totally updated when I did the command with ignore icu.
Even timeshift needs libicuuc
omano
20 February 2025 18:11
2
Maybe you could use pacman-static in chroot from a live USB to update the system again without ignoring packages and see if it fixes it?
BG405
20 February 2025 19:00
4
I’ll just drop this here for consideration:
pacman -Qii icu
Version : 75.1-2
Description : International Components for Unicode library
Architecture : x86_64
URL : https://icu.unicode.org
Licenses : LicenseRef-Unicode-3.0 BSD-2-Clause BSD-3-Clause
Groups : None
Provides : libicudata.so=75-64 libicui18n.so=75-64 libicuio.so=75-64 libicutest.so=75-64
libicutu.so=75-64 libicuuc.so=75-64
Depends On : gcc-libs glibc sh
Optional Deps : None
Required By : boost-libs calibre gspell harfbuzz-icu haskell-text-icu kdelibs kdeplasma-addons
konsole lib32-icu libcdr libe-book libical libmspub libqalculate libqxp
libreoffice-fresh libvisio libxml2 libzmf manjaro-settings-manager mpd nodejs
plasma-desktop plasma-workspace postgresql qt6-5compat qt6-base qt6-webengine raptor
smbclient thunderbird tinysparql vte3 webkit2gtk webkit2gtk-4.1 xerces-c
Optional For : qt4 tesseract xfsprogs
Conflicts With : None
Replaces : None
Installed Size : 40.64 MiB
Packager : Antonio Rojas <arojas@archlinux.org>
Build Date : Mon 23 Dec 2024 19:49:25 GMT
Install Date : Tue 04 Feb 2025 12:47:45 GMT
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
Backup Files : None
Extended Data : pkgtype=pkg
Of particular interest is the Required By: section.
Any particular reason you wanted to hold that package back?
No reason to hold that package, is that seems others packages are dependent of icu and I have no way of update.
I ignored the package “icu” because it was necessary by another which I don’t remember now,
and then came a lot of others , it was a lack of attention by my side.
I think I have to reinstall Manjaro.
BG405
20 February 2025 22:46
7
I think a fix via chroot and re-running the upgrade (preferably with pacman first, then any AUR stuff with the helper you use).
When I run pacman says it needs icu.
BG405
20 February 2025 22:51
9
I thought that might still run OK from chroot. Unfortunately I think you might be right re. a reinstallation; it’s looking a bit like “depencency hell”.
cscs
10
BG405
20 February 2025 22:55
11
Interesting! I’d not looked into that before. Will need to bookmark this.
I bypassed the login screen, I am on a manjaro terminal tty1, should work too.
I feel blind with only command line.
Will leave to do this tomorrow.
system
Closed
23 February 2025 23:36
14
