Hello everyone
When I log out and then try to login again, it hangs for longer than 30s
Even when I try to reboot using another tty, it hangs there too(more than 30s)
Meantime, I opened another tty and ran journalctl
Last 100 lines of journalctl:
Dec 02 20:13:14 MTN-Lap kernel: audit: type=1131 audit(1606927394.155:176): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 02 20:13:14 MTN-Lap systemd[1]: Stopping User Runtime Directory /run/user/967...
Dec 02 20:13:14 MTN-Lap systemd[1]: run-user-967.mount: Succeeded.
Dec 02 20:13:14 MTN-Lap systemd[1373]: run-user-967.mount: Succeeded.
Dec 02 20:13:14 MTN-Lap systemd[1]: user-runtime-dir@967.service: Succeeded.
Dec 02 20:13:14 MTN-Lap systemd[1]: Stopped User Runtime Directory /run/user/967.
Dec 02 20:13:14 MTN-Lap audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 02 20:13:14 MTN-Lap systemd[1]: Removed slice User Slice of UID 967.
Dec 02 20:13:14 MTN-Lap kernel: audit: type=1131 audit(1606927394.172:177): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dec 02 20:13:14 MTN-Lap NetworkManager[667]: <info> [1606927394.2674] policy: auto-activating connection 'MobinNet137E' (5aea24d3-efea-4b7d-b474-2a76dff9acda)
Dec 02 20:13:14 MTN-Lap NetworkManager[667]: <info> [1606927394.2685] device (wlo1): Activation: starting connection 'MobinNet137E' (5aea24d3-efea-4b7d-b474-2a76dff9acda)
Dec 02 20:13:14 MTN-Lap NetworkManager[667]: <info> [1606927394.2689] device (wlo1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Dec 02 20:13:14 MTN-Lap NetworkManager[667]: <info> [1606927394.2699] manager: NetworkManager state is now CONNECTING
Dec 02 20:13:14 MTN-Lap NetworkManager[667]: <info> [1606927394.2721] device (wlo1): set-hw-addr: reset MAC address to 70:66:55:BB:04:B7 (preserve)
Dec 02 20:13:14 MTN-Lap kernel: rtw_8822ce 0000:03:00.0: stop vif 3a:4f:4a:61:b1:06 on port 0
Dec 02 20:13:14 MTN-Lap NetworkManager[667]: <info> [1606927394.5126] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Dec 02 20:13:14 MTN-Lap NetworkManager[667]: <info> [1606927394.5132] device (wlo1): Activation: (wifi) access point 'MobinNet137E' has security, but secrets are required.
Dec 02 20:13:14 MTN-Lap NetworkManager[667]: <info> [1606927394.5133] device (wlo1): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Dec 02 20:13:14 MTN-Lap kernel: rtw_8822ce 0000:03:00.0: start vif 70:66:55:bb:04:b7 on port 0
Dec 02 20:13:14 MTN-Lap NetworkManager[667]: <info> [1606927394.5179] device (wlo1): supplicant interface state: disconnected -> interface_disabled
Dec 02 20:13:14 MTN-Lap NetworkManager[667]: <info> [1606927394.5943] device (wlo1): supplicant interface state: interface_disabled -> disconnected
Dec 02 20:13:16 MTN-Lap audit[3730]: USER_AUTH pid=3730 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="mtn" exe="/usr/bin/login" hostname=MTN-Lap addr=? terminal=tty2 res=success'
Dec 02 20:13:16 MTN-Lap dbus-daemon[666]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.175' (uid=0 pid=3730 comm="/bin/login -p -- " label="unconfined")
Dec 02 20:13:16 MTN-Lap kernel: audit: type=1100 audit(1606927396.703:178): pid=3730 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="mtn" exe="/usr/bin/login" hostname=MTN-Lap addr=? terminal=tty2 res=success'
Dec 02 20:13:16 MTN-Lap dbus-daemon[666]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Dec 02 20:13:16 MTN-Lap login[3730]: pam_systemd_home(login:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Dec 02 20:13:16 MTN-Lap audit[3730]: USER_ACCT pid=3730 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="mtn" exe="/usr/bin/login" hostname=MTN-Lap addr=? terminal=tty2 res=success'
Dec 02 20:13:16 MTN-Lap audit[3730]: CRED_ACQ pid=3730 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="mtn" exe="/usr/bin/login" hostname=MTN-Lap addr=? terminal=tty2 res=success'
Dec 02 20:13:16 MTN-Lap kernel: audit: type=1101 audit(1606927396.706:179): pid=3730 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="mtn" exe="/usr/bin/login" hostname=MTN-Lap addr=? terminal=tty2 res=success'
Dec 02 20:13:16 MTN-Lap kernel: audit: type=1103 audit(1606927396.706:180): pid=3730 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="mtn" exe="/usr/bin/login" hostname=MTN-Lap addr=? terminal=tty2 res=success'
Dec 02 20:13:16 MTN-Lap kernel: audit: type=1006 audit(1606927396.706:181): pid=3730 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=tty2 old-ses=4294967295 ses=7 res=1
Dec 02 20:13:16 MTN-Lap login[3730]: pam_unix(login:session): session opened for user mtn(uid=1000) by LOGIN(uid=0)
Dec 02 20:13:16 MTN-Lap systemd-logind[674]: New session 7 of user mtn.
Dec 02 20:13:16 MTN-Lap systemd[1]: Started Session 7 of user mtn.
Dec 02 20:13:16 MTN-Lap login[3730]: pam_env(login:session): deprecated reading of user environment enabled
Dec 02 20:13:16 MTN-Lap audit[3730]: USER_START pid=3730 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="mtn" exe="/usr/bin/login" hostname=MTN-Lap addr=? terminal=tty2 res=success'
Dec 02 20:13:16 MTN-Lap audit[3730]: CRED_REFR pid=3730 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="mtn" exe="/usr/bin/login" hostname=MTN-Lap addr=? terminal=tty2 res=success'
Dec 02 20:13:16 MTN-Lap kernel: audit: type=1105 audit(1606927396.736:182): pid=3730 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="mtn" exe="/usr/bin/login" hostname=MTN-Lap addr=? terminal=tty2 res=success'
Dec 02 20:13:16 MTN-Lap kernel: audit: type=1110 audit(1606927396.736:183): pid=3730 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="mtn" exe="/usr/bin/login" hostname=MTN-Lap addr=? terminal=tty2 res=success'
Dec 02 20:13:16 MTN-Lap login[3730]: LOGIN ON tty2 BY mtn
Dec 02 20:13:30 MTN-Lap kded5[3682]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.NoReply", "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
Dec 02 20:13:30 MTN-Lap ksmserver[3713]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.NoReply", "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
Dec 02 20:13:30 MTN-Lap kwin_x11[3686]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.NoReply", "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
Dec 02 20:13:30 MTN-Lap kactivitymanagerd[3706]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.NoReply", "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
Dec 02 20:13:55 MTN-Lap kcminit_startup[3674]: Initializing "kcm_kgamma" : "kcminit_kgamma"
Dec 02 20:13:55 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/polkit-kde-authentication-agent-1.desktop" ("/usr/lib/polkit-kde-authentication-agent-1")
Dec 02 20:13:55 MTN-Lap kcminit_startup[3674]: Initializing "kded_touchpad" : "kcminit_touchpad"
Dec 02 20:13:55 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/pam_kwallet_init.desktop" ("/usr/lib/pam_kwallet_init")
Dec 02 20:13:55 MTN-Lap kcminit_startup[3674]: kcm_touchpad: Using X11 backend
Dec 02 20:13:55 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/kaccess.desktop" ("/usr/bin/kaccess")
Dec 02 20:13:55 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/xembedsniproxy.desktop" ("/usr/bin/xembedsniproxy")
Dec 02 20:13:55 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/org.kde.plasmashell.desktop" ("/usr/bin/plasmashell")
Dec 02 20:13:55 MTN-Lap kaccess[3767]: Xlib XKB extension major= 1 minor= 0
Dec 02 20:13:55 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/gmenudbusmenuproxy.desktop" ("/usr/bin/gmenudbusmenuproxy")
Dec 02 20:13:55 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/pulseaudio.desktop" ("/usr/bin/start-pulseaudio-x11")
Dec 02 20:13:55 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/org.kde.kdeconnect.daemon.desktop" ("/usr/lib/kdeconnectd")
Dec 02 20:13:55 MTN-Lap systemd[1373]: Starting Sound Service...
Dec 02 20:13:55 MTN-Lap kaccess[3767]: X server XKB extension major= 1 minor= 0
Dec 02 20:13:55 MTN-Lap rtkit-daemon[1626]: Successfully made thread 3791 of process 3791 owned by '1000' high priority at nice level -11.
Dec 02 20:13:55 MTN-Lap rtkit-daemon[1626]: Supervising 3 threads of 3 processes of 1 users.
Dec 02 20:13:55 MTN-Lap rtkit-daemon[1626]: Successfully made thread 3802 of process 3791 owned by '1000' RT at priority 5.
Dec 02 20:13:55 MTN-Lap rtkit-daemon[1626]: Supervising 4 threads of 3 processes of 1 users.
Dec 02 20:13:55 MTN-Lap rtkit-daemon[1626]: Successfully made thread 3803 of process 3791 owned by '1000' RT at priority 5.
Dec 02 20:13:55 MTN-Lap rtkit-daemon[1626]: Supervising 5 threads of 3 processes of 1 users.
Dec 02 20:13:55 MTN-Lap systemd[1373]: Started Sound Service.
Dec 02 20:13:55 MTN-Lap bluetoothd[963]: Endpoint registered: sender=:1.180 path=/MediaEndpoint/A2DPSink/sbc
Dec 02 20:13:55 MTN-Lap bluetoothd[963]: Endpoint registered: sender=:1.180 path=/MediaEndpoint/A2DPSource/sbc
Dec 02 20:14:02 MTN-Lap plasma_waitforname[3595]: org.kde.knotifications: WaitForName: Service was not registered within timeout
Dec 02 20:14:02 MTN-Lap dbus-daemon[1395]: [session uid=1000 pid=1395] Activated service 'org.freedesktop.Notifications' failed: Process org.freedesktop.Notifications exited with status 1
Dec 02 20:14:20 MTN-Lap plasmashell[3776]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.NoReply", "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
Dec 02 20:14:20 MTN-Lap kaccess[3767]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.NoReply", "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
Dec 02 20:14:20 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/geoclue-demo-agent.desktop" ("/usr/lib/geoclue-2.0/demos/agent")
Dec 02 20:14:20 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/snap-userd-autostart.desktop" ("/bin/snap", "userd", "--autostart")
Dec 02 20:14:20 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/home/mtn/.config/autostart/libinput-gestures.desktop" ("/usr/bin/libinput-gestures")
Dec 02 20:14:20 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/pamac-tray-appindicator.desktop" ("/usr/bin/pamac-tray-appindicator")
Dec 02 20:14:20 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/msm_kde_notifier.desktop" ("/usr/bin/msm_kde_notifier")
Dec 02 20:14:20 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/powerdevil.desktop" ("/usr/lib/org_kde_powerdevil")
Dec 02 20:14:20 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/home/mtn/.config/autostart/guake.desktop" ("/usr/bin/guake")
Dec 02 20:14:20 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/dtd-wayland.desktop" ("/usr/bin/dtd-wayland")
Dec 02 20:14:20 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/home/mtn/.config/autostart/expressvpn-agent.desktop" ("/usr/bin/expressvpn-agent", "--daemon")
Dec 02 20:14:20 MTN-Lap plasma_session[3638]: org.kde.plasma.session: Starting autostart service "/etc/xdg/autostart/xapp-sn-watcher.desktop" ("/usr/lib/xapps/sn-watcher/xapp-sn-watcher")
Dec 02 20:14:20 MTN-Lap org_kde_powerdevil[3836]: org.kde.powerdevil: No outputs have backlight property
Dec 02 20:14:20 MTN-Lap org_kde_powerdevil[3836]: org.kde.powerdevil: Xrandr not supported, trying ddc, helper
Dec 02 20:14:20 MTN-Lap dbus-daemon[666]: [system] Activating service name='org.kde.powerdevil.discretegpuhelper' requested by ':1.182' (uid=1000 pid=3836 comm="/usr/lib/org_kde_powerdevil " label="unconfined") (using servicehelper)
Dec 02 20:14:20 MTN-Lap dbus-daemon[666]: [system] Successfully activated service 'org.kde.powerdevil.discretegpuhelper'
Dec 02 20:14:20 MTN-Lap dbus-daemon[666]: [system] Activating service name='org.kde.powerdevil.chargethresholdhelper' requested by ':1.182' (uid=1000 pid=3836 comm="/usr/lib/org_kde_powerdevil " label="unconfined") (using servicehelper)
Dec 02 20:14:20 MTN-Lap dbus-daemon[666]: [system] Successfully activated service 'org.kde.powerdevil.chargethresholdhelper'
Dec 02 20:14:20 MTN-Lap dbus-daemon[666]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.182' (uid=1000 pid=3836 comm="/usr/lib/org_kde_powerdevil " label="unconfined") (using servicehelper)
Dec 02 20:14:20 MTN-Lap dbus-daemon[666]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
Dec 02 20:14:20 MTN-Lap org_kde_powerdevil[3836]: Warning from helper: Failed to open "/sys/class/power_supply/BAT0/charge_start_threshold" for reading
Dec 02 20:14:20 MTN-Lap org_kde_powerdevil[3836]: Warning from helper: Failed to open "/sys/class/power_supply/BAT0/charge_stop_threshold" for reading
Dec 02 20:14:20 MTN-Lap org_kde_powerdevil[3836]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Dec 02 20:14:45 MTN-Lap org_kde_powerdevil[3836]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.NoReply", "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
Dec 02 20:14:45 MTN-Lap kded5[3682]: bluedevil: Created
Dec 02 20:14:45 MTN-Lap kded5[3682]: kcm_touchpad: Using X11 backend
Dec 02 20:14:45 MTN-Lap kded5[3682]: Delayed initialization.
Dec 02 20:14:45 MTN-Lap kded5[3682]: Reloading the khotkeys configuration
Dec 02 20:14:45 MTN-Lap kded5[3682]: Version 2 File!
I guess something is wrong with kglobalaccel
I have to mention that even after showing the desktop, my battery drains too fast
