Hi, I can’t log in anymore and I don’t know how.
Up until recently, I had auto login enable. As I wanted to disable it, I noticed, that the checkbox was not ticked, but auto login still worked.
I’ve tried to use a different user for the auto login as was going on a short trip, so assigning a new user with no rights was my go to solution, only, that neither the new profile logs in automatically, nor can I log in my account manually.
Every time I’m getting an error message (sadly in German, even though I switched to English after I finished the installation last time):
Leider ist ein Problem aufgetreten
Ein Problem ist aufgetreten, welches vom System nicht behoben werden kann. Bitte melden Sie sich ab uns versuchen Sie es erneut"
Rough translation would be: "
An error has occurred
An error has occurred, which can’t be solved by the system. Please log off and try again".
Of course that doesn’t work. I can still log in in through TTY5, but I have no idea where to start looking for clues.
Worst case I could use a snapshot from the day before I made the change, hopefully reverting the ■■■■ up I made and not loosing to much.
But I would prefer not to do that right away.
So I’d appreciate all help and I’ll supply any information I can and is requested.
Best Edward
