Hi @Mytha, and welcome!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
I am in no way an expert, especially not with virtualbox-related issues, but I do have virtualbox running her, and I also know I never did that modprobe to get it that way.
So I looked a bit deeper, searching pamac for all things virtualbox related:
$ pamac search virtualbox
virtualbox-host-dkms [Installed] 7.0.4-1 community
VirtualBox Host kernel modules sources
virtualbox [Installed] 7.0.4-1 community
Powerful x86 virtualization for enterprise as well as home use
Those are the only two packages virtualbox-related I have installed. And since you’re not talking about virtualbox itself, I decided to look into virtualbox-host-dkms
$ pamac info virtualbox-host-dkms
Version : 7.0.4-1
Description : VirtualBox Host kernel modules sources
URL : https://virtualbox.org/
Licences : GPL custom:CDDL
Repository : community
Installed Size : 11.7 MB
Groups : --
Depends On : dkms gcc make
Optional Dependencies : --
Required By : virtualbox
Optional For : --
Provides : VIRTUALBOX-HOST-MODULES
Replaces : virtualbox-source virtualbox-host-source virtualbox-host-modules-lts
Conflicts With : virtualbox-source virtualbox-host-source
Packager : Christian Hesse <eworm@archlinux.org>
Build Date : Fri 18 Nov 2022 14:54:46
Install Date : Wed 07 Dec 2022 12:19:47
Install Reason : Installed as a dependency for another package
Validated By : Signature
Backup files : --
But I didn’t gain much. I then decided to see if the kernel module (that’s a driver in Linux FAIK) is loaded:
$ lsmod | grep --ignore-case vb
vboxnetflt 32768 0
vboxnetadp 28672 0
vboxdrv 581632 2 vboxnetadp,vboxnetflt
And BINGO!
So it would seem you need to have virtualbox-host-dkms
installed:
pamac install virtualbox-host-dkms
If you don’t have your kernel headers installed, which you need for -dkms
packages, you can install the headers for all you kernels with:
pamac install $(pamac list --quiet --installed | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ')
This will install the headers for all installed kernels.
Also make sure first you have the dkms package installed, from the extra
repository:
pamac install dkms
Hope this helps!
