WIFI is not working at all in my Laptop in manjaro. in hardware configuration I get under the network controler : Unknown device name ( realtek Semiconducote Co.,Ltd)
devices connected via pci by this line : mhwd -lh -d --pci
I think that The WIFI is :
10: PCI 200.0: 0280 Network controller
SysFS ID: /devices/pci0000:00/0000:00:1d.1/0000:02:00.0
SysFS BusID: 0000:02:00.0
Hardware Class: network
Model: "Realtek Network controller"
Vendor: pci 0x10ec "Realtek Semiconductor Co., Ltd."
Device: pci 0xc82f
SubVendor: pci 0x17aa "Lenovo"
SubDevice: pci 0xc02f
I/O Ports: 0x2000-0x20ff (rw,disabled)
Memory Range: 0xb1200000-0xb120ffff (rw,non-prefetchable,disabled)
IRQ: 255 (no events)
Module Alias: "pci:v000010ECd0000C82Fsv000017AAsd0000C02Fbc02sc80i00"
Attached to: #11 (PCI bridge)
My output for $ inxi --full --verbosity=7 --filter --no-host
Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20RW v: Lenovo ThinkBook 15-IML
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: LVA/LVAB v: NO DPK serial: <filter> UEFI: LENOVO
v: CJCN29WW date: 06/19/2020
ID-1: BAT1 charge: 43.9 Wh condition: 44.9/45.0 Wh (100%) volts: 12.9/11.5
model: Celxpert L19C3PF1 type: Li-poly serial: <filter> status: Unknown
cycles: 22
RAM: total: 3.36 GiB used: 1.84 GiB (54.8%)
Topology: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Kaby Lake rev: C L2 cache: 6144 KiB bogomips: 33615
Speed: 705 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 700 2: 700 3: 700
4: 700 5: 700 6: 700 7: 700 8: 700
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel UHD Graphics vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9b41
Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
bus ID: 1-6:4 chip ID: 5986:2113
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa resolution: 1920x1080~60Hz
s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.1.7
direct render: Yes
Device-1: Intel vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:02c8
Sound Server: ALSA v: k5.7.19-2-MANJARO
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 3000 bus ID: 01:00.0 chip ID: 10ec:8168
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Realtek vendor: Lenovo driver: N/A port: 2000 bus ID: 02:00.0
chip ID: 10ec:c82f
Local Storage: total: 931.51 GiB used: 8.59 GiB (0.9%)
ID-1: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0E scheme: GPT
ID-1: / size: 908.32 GiB used: 8.59 GiB (0.9%) fs: ext4 dev: /dev/sda2
label: N/A uuid: f15b26c1-3465-4e0d-b5b7-46a5e5b2c0c4
ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1
label: N/A uuid: 8864-D872
ID-1: swap-1 type: partition size: 7.39 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 label: N/A uuid: c81587ea-2411-4503-b383-c6bd51bd76ff
Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-3:2 info: ASUSTek ROG STRIX IMPACT type: Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
chip ID: 0b05:1847
Device-2: 1-5:3 info: Shenzhen Goodix Goodix FingerPrint Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 27c6:55a4
Device-3: 1-6:4 info: Acer SunplusIT Integrated Camera type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 5986:2113
Device-4: 1-10:5 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s chip ID: 0bda:c02f serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 207 Uptime: 44m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1189 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
is there anyway to install the driver ?
