Whenever I try to install any packages using pacman or pamac it throws weird errors at me and don’t install them . Here are some examples:
when I tried to install “kaku”:
could not satisfy dependencies:
unable to satisfy dependency ‘gconf’ required by kaku-bin
(I know this might mean I need to install a package called “gconf”, but that doesn’t work either)
invalid or corrupted database
remove_authorization: Timeout was reached
This one I typed out the terminal: sudo pacman -S aspell-en libmythes mythes-en languagetool
Error: failed retrieving file ‘languagetool-5.0-1-any.pkg.tar.xz’ from [can’t-include-link-so-this-the-replacment] : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
warning: failed to retrieve some files
error: failed to commit transaction (download library error)
another one I tried to install from pamac: ttf-ms-fonts
get_authorization: Timeout was reached
I think this might be due to some problems with my internet connection, cause it started happening ever since my internet was being a bit bad, but right now my internet is working well enough for me to watch YouTube without much problems, so I don’t know why this issue is still persisting? would like some help from you guys, thank you <3
I updated my mirror and tried installing that “spelling stuff” (with -Syu of course), same exact set of error messages! maybe it IS my internet? but YouTube is working so well and I’m able to use this site fine, don’t know what’s going on
Syyu because of background timer pamac-mirrorlist that sorts mirrors.
And … especially after running your command … it must be -Syyu (2 ys) to force db refresh.
pacman works now, I can install packages using it, but pamac still keeps giving me remove_authorization: Timeout was reached and get_authorization: Timeout was reached
actually pamac works now too, all I had to do was refresh the database, by the way I did try doing that yesterday, MANY times did not work, but today it works, so pacman and pamac are both working and it’s probably WAS just a Internet connection issue, very so for the inconvenience guys.
