I have a 1tb ssd.
Cut 200gb from it and its now unallocated.
Booted with USB.
I try to install manjaro on that 200gb but manjaro installation menu says i have no space (8gb is required) and that there are no partitions to install it on.
What can it be ?
Some info:
Controller mode: RST.
Boot mode: UEFI
Turning off fast boot didnt help
lagacy boot mode turned off
I can only format to NTFS or exFAT, no other option. I tried both and didnt work.
Heres a pic of how it looked with NTFS (add “https” before it, i cant post links here = ithttps://pasteboard.co/JMopt9V.png
You don’t want to use either of these to install Manjaro on.
No option where? In the Calamares installer? You should be able to do it in the installer, if it doesn’t show up, try redoing the partition table in the installer, and select GPT
Warning: this will wipe everything from the drive.
Ok, the problem is that in the installer, it wont let me go further than the Welcome screen, it shows the 2 errors and disables the continue button. I cant do anything in it
