Hi, there!
I install Manjaro for the first time (and arch-linux-based too).
Now I have Windows 10 and Ubuntu installed.
I want to change Ubuntu to Manjaro.
I wrote Manjaro ISO to flash drive and set it to loading first in boot menu in BIOS.
But when system starts I get error
“error: unknown filesystem
grub rescue>”
Of course I tried to find solution first, but it was unsuccessful.
Output of command “ls”:
“(hd0), (hd1)”
But “ls (hd0)” or “ls (hd1)” outputs this:
“(hdX): unknown filesystem”.
And “ls (hdX)/” outputs this:
“error: unknown filesystem”.
Also, I tried to update grub using “sudo update-grub” command in Ubuntu.
Also I know that my “/boot/efi” locates in /dev/sda2 but not in /dev/sda1. Maybe there is the problem?
I want to add that I tried to reinstall Ubuntu after unsuccessful install Manjaro, and it installed successfully. Only Manjaro can’ tbe installed.
I’m hope for help.
Thanks in advance!
