I have a fresh Manjaro install and decided for a swap file for the first time. I had been using partition for many years and wanted to try file. However, while partition always worked out of the box, file gives me problems. When I try to hibernate, it says “Call to Hibernate failed: Not enough swap space for hibernation.”
Output of free is
total used free shared buff/cache available
Mem: 7982416 4155336 1127204 389204 3398792 3827080
Swap: 524284 0 524284
Maybe that’s not enough space but since the swap file was created by the installer, I suppose that the correct size of the file was chosen. (if this is the problem: how can I enlarge the swap file).
I am a bit lost in how to proceed. I tried some suggestions provided to similar questions but without any luck.
