Hello ![]()
I am having an issue with my built in audio controller. I can hear the right channel but not the left.
I have an analog connection from my 2.0 speakers to the Line Out jack on my motherboard, a Gigabyte Z370 HD3. Went into Audio System Settings and my Line Out is selected with an Analog Stereo Output profile.
System Information
Kernel: 5.15.28-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=3b68502f-549f-43cb-b0f2-59799b9d6946 rw quiet apparmor=1
Desktop: KDE Plasma 5.24.3 tk: Qt 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: Z370 HD3 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z370 HD3-CF serial: <superuser required>
UEFI: American Megatrends v: F14 date: 11/13/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 15.56 GiB used: 2.61 GiB (16.8%)
RAM Report:
Info: model: Intel Core i5-8600K bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 9 MiB
desc: 1x9 MiB
Speed (MHz): avg: 1573 high: 3237 min/max: 800/4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 3237 2: 2296 3: 1510
4: 800 5: 800 6: 800 bogomips: 43212
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: l1tf
STIBP: disabled, RSB filling
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: eVga.com.
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0
chip-ID: 10de:2504 class-ID: 0300
Device-2: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Micro-Star MSI
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 08:00.0 chip-ID: 10de:2182 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 92 s-size: 707x393mm (27.8x15.5")
s-diag: 809mm (31.8")
Monitor-1: DP-0 res: 2560x1440 hz: 144 dpi: 93
size: 697x392mm (27.4x15.4") diag: 800mm (31.5")
OpenGL: renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2 v: 4.6.0 NVIDIA 510.54
direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA vendor: eVga.com. driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-3: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.1
chip-ID: 10de:1aeb class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 2.27 TiB used: 10.08 GiB (0.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7 temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10EARS-00MVWB0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: AB51
scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 750 EVO 500GB
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 10.08 GiB (1.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: Manjaro uuid: 3b68502f-549f-43cb-b0f2-59799b9d6946
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
label: NO_LABEL uuid: EB62-5C04
ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs label: WDC
uuid: 526A93036A92E351
ID-2: /dev/sdb1 maj-min: 8:17 size: 465.76 GiB fs: ntfs
label: Samsung 750 EVO uuid: 2A1E43DC1E439FA5
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-8:2 info: Razer USA Cynosa Chroma type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:022a class-ID: 0300
Device-2: 1-10:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 27.8 C mobo: 16.8 C gpu: nvidia temp: 51 C
Processes: 239 Uptime: 37m wakeups: 2 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1212 lib: 334
flatpak: 0 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.13
