Hi,
Since yesterday I’m experiencing troubles with wifi. I am unable to detect any wifi networks and running ip link shows the interface is down.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp3s0f0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN mode DEFAULT group default qlen 1000
link/ether 38:c9:86:28:9f:25 brd ff:ff:ff:ff:ff:ff
3: wlp2s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 76:63:99:5b:78:fe brd ff:ff:ff:ff:ff:ff`
I’m using a Mac mini 2014
uname -a
gives me:
Linux jaeger 5.4.85-1-MANJARO #1 SMP PREEMPT Mon Dec 21 21:38:53 UTC 2020 x86_64 GNU/Linux
inxi -N
gives me:
Network: Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
Device-2: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe driver: tg3
Device-3: Samsung GT-I9070 (network tethering USB debugging enabled) type: USB driver: rndis_host
rfkill list all
gives me:
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
I tried check the logs of NetworkManager and I got the following error:
Jan 03 15:44:11 jaeger NetworkManager[664]: [1609674251.7184] device (wlp2s0): Couldn’t initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError: wpa_supplicant couldn’t grab this interface.
Jan 03 15:44:21 jaeger NetworkManager[664]: [1609674261.7183] device (wlp2s0): re-acquiring supplicant interface (#2).
Jan 03 15:44:21 jaeger NetworkManager[664]: [1609674261.7222] device (wlp2s0): Couldn’t initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError: wpa_supplicant couldn’t grab this interface.
Jan 03 15:44:31 jaeger NetworkManager[664]: [1609674271.7151] device (wlp2s0): re-acquiring supplicant interface (#3).
Jan 03 15:44:31 jaeger NetworkManager[664]: [1609674271.7193] device (wlp2s0): Couldn’t initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError: wpa_supplicant couldn’t grab this interface.
Jan 03 15:44:41 jaeger NetworkManager[664]: [1609674281.7140] device (wlp2s0): re-acquiring supplicant interface (#4).
Jan 03 15:44:41 jaeger NetworkManager[664]: [1609674281.7186] device (wlp2s0): Couldn’t initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError: wpa_supplicant couldn’t grab this interface.
Jan 03 15:44:51 jaeger NetworkManager[664]: [1609674291.7146] device (wlp2s0): re-acquiring supplicant interface (#5).
Jan 03 15:44:51 jaeger NetworkManager[664]: [1609674291.7185] device (wlp2s0): Couldn’t initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError: wpa_supplicant couldn’t grab this interface.
Jan 03 15:44:51 jaeger NetworkManager[664]: [1609674291.7186] device (wlp2s0): supplicant interface keeps failing, giving up
Checking the logs of the wpa_supplicant service gives me the following error logs:
Jan 03 15:44:41 jaeger wpa_supplicant[862]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Jan 03 15:44:41 jaeger wpa_supplicant[862]: Could not set interface wlp2s0 flags (UP): Operation not permitted
Jan 03 15:44:41 jaeger wpa_supplicant[862]: WEXT: Could not set interface ‘wlp2s0’ UP
Jan 03 15:44:41 jaeger wpa_supplicant[862]: wlp2s0: Failed to initialize driver interface
Jan 03 15:44:51 jaeger wpa_supplicant[862]: Could not set interface wlp2s0 flags (UP): Operation not permitted
Jan 03 15:44:51 jaeger wpa_supplicant[862]: nl80211: Could not set interface ‘wlp2s0’ UP
Jan 03 15:44:51 jaeger wpa_supplicant[862]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Jan 03 15:44:51 jaeger wpa_supplicant[862]: WEXT: Could not set interface ‘wlp2s0’ UP
Jan 03 15:44:51 jaeger wpa_supplicant[862]: wlp2s0: Failed to initialize driver interface
Does anyone know how to fix this issue?
