Hello guys, new to Manjaro and love everything about except that I can’t get Korean to work!
I tried everything the guides say, using IBUS, SCIM, fcitx.
At one point, I randomly got it to work once. I rebooted and back to the same problem. Anyone else have the same issue or know how to fix it?
Thanks.
Seems Nabi is a good option for Korean input.
it is in the AUR so you need to build it with
pamac build nabi-git
Some info about how to set it.
https://wiki.archlinux.org/index.php/Localization/Korean#Nabi
Hope it helps
Thank you! I had that installed and it didn’t work at first, but after a few reboots it started working.
