Thank you for the warm welcome and the quick help!
I’m not a professional Linux user — I just recently started, so please consider me a beginner.
Unfortunately I don’t understand everything because of language differences, but I will do my best to overcome this difficulty so we can understand each other clearly without problems.
Kernel: 6.19.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.19-x86_64
root=UUID=746b172e-41b7-4dce-a845-b5565ac56cd5 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.23.0
Type: Laptop System: LENOVO product: 20NMS12S00 v: ThinkPad X395
Mobo: LENOVO model: 20NMS12S00 v: SDK0J40697 WIN
serial: <superuser required>
part-nu: LENOVO_MT_20NM_BU_Think_FM_ThinkPad X395
uuid: <superuser required> Firmware: UEFI vendor: LENOVO
v: R13ET56W(1.30 ) date: 03/01/2024
ID-1: BAT0 charge: 18.1 Wh (45.2%) condition: 40/48 Wh (83.2%) power: 8.7 W
volts: 11.22 min: 11.46 model: Sunwoda 5B10W139 type: Li-poly
serial: <filter> charging: status: discharging control: start: 95%
end: 100% cycles: 280
System RAM: total: 16 GiB available: 13.56 GiB used: 2.74 GiB (20.2%)
(unregistered) size: 8 GiB speed: 2400 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Micron Technology part-no: 4ATS1G64HZ-2G6E1 serial: N/A
Info: model: AMD Ryzen 5 PRO 3500U w/ Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108109
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1368 min/max: 1400/2100 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1368 2: 1368 3: 1368
4: 1368 5: 1368 6: 1368 7: 1368 8: 1368 bogomips: 33537
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb lahf_lm lbrv
lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm
svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif
vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 06:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 44.0 C
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-2.1:4
chip-ID: 13d3:5415 class-ID: 0e02
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Lenovo 0x4094 built: 2018 res: mode: 1920x1080
hz: 60 scale: 100% (1) dpi: 166 gamma: 1.2 chroma: red: x: 0.647 y: 0.325
green: x: 0.306 y: 0.608 blue: x: 0.153 y: 0.047 white: x: 0.314 y: 0.329
size: 294x165mm (11.57x6.5") diag: 337mm (13.3") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
1024x768, 800x600, 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
(radeonsi raven ACO DRM 3.64 6.19.2-1-MANJARO) device-ID: 1002:15d8
memory: 1.95 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.341 layers: 2 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 25.3.5-arch1.1
device-ID: 1002:15d8 surfaces: N/A
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.19.2-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0
chip-ID: 8086:2526 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2400 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0f0 state: down mac: <filter>
IF-ID-1: wwan0 state: down mac: N/A
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1:2
chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 238.47 GiB used: 10.79 GiB (4.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 5108AGLA temp: 32.9 C
scheme: GPT
ID-1: / raw-size: 55.86 GiB size: 55.86 GiB (100.00%)
used: 10.76 GiB (19.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 746b172e-41b7-4dce-a845-b5565ac56cd5
used: 26.9 MiB (28.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 564B-D658
ID-3: /home raw-size: 55.86 GiB size: 55.86 GiB (100.00%)
ID-4: /var/cache raw-size: 55.86 GiB size: 55.86 GiB (100.00%)
ID-5: /var/log raw-size: 55.86 GiB size: 55.86 GiB (100.00%)
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 181.75 GiB fs: ntfs label: N/A
uuid: AECE56B4CE567495
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 769 MiB fs: ntfs label: N/A
uuid: 6A88034588030EEF
Hub-2: 2-0:1 info: full speed or root hub ports: 1 rev: 2.0
Hub-3: 3-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 4-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 4-1:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-5: 4-2:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 4-2.1:4 info: IMC Networks Integrated Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:5415 class-ID: 0e02
Device-2: 4-2.4:5 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Hub-6: 5-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 45.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Packages: pm: pacman pkgs: 1277 libs: 371 tools: pamac pm: flatpak pkgs: 0
1: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
2: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
3: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
4: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
5: https://mirror.dc.uz/manjaro/stable/$repo/$arch
6: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
7: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
9: https://manjaro.grena.ge/stable/$repo/$arch
10: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
11: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
12: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
13: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
14: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
15: https://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
16: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
17: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
18: https://mirror.easyname.at/manjaro/stable/$repo/$arch
19: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
20: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
21: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
22: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
23: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
24: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
25: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
26: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
27: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
28: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
29: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
30: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
31: https://mirror.fcix.net/manjaro/stable/$repo/$arch
32: https://mirror.koddos.net/manjaro/stable/$repo/$arch
33: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
34: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
35: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
36: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
37: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
38: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
39: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
40: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
41: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
42: https://mirrors2.manjaro.org/stable/$repo/$arch
43: https://mirrors.manjaro.org/repo/stable/$repo/$arch
44: https://manjaro.ynh.ovh/stable/$repo/$arch
45: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
46: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
47: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
48: https://mirror.zetup.net/manjaro/stable/$repo/$arch
49: https://manjaro.mirror.ac.za/stable/$repo/$arch
50: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
51: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
52: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
53: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
54: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
55: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
56: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
57: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
58: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
59: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
60: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
61: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
62: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
63: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
64: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
65: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
66: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
67: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
68: https://mirror.23m.com/manjaro/stable/$repo/$arch
69: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
70: https://mirror.init7.net/manjaro/stable/$repo/$arch
71: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
72: https://manjaro.nic.cz/stable/$repo/$arch
73: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
74: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
75: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
76: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
77: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
78: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
79: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
80: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
81: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
82: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
83: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
84: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
85: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
86: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
87: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
88: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
89: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
90: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
91: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
92: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
93: https://linorg.usp.br/manjaro/stable/$repo/$arch
94: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
95: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
96: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
97: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
98: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
99: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
100: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
101: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
102: https://mirror.mobinhost.com/manjaro/stable/$repo/$arch
103: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
104: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
105: https://muug.ca/mirror/manjaro/stable/$repo/$arch
106: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
107: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
108: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
109: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
110: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
111: https://manjaro.kurdy.org/stable/$repo/$arch
112: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
113: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
114: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
115: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
116: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
117: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
118: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
119: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
120: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
121: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
122: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
123: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
124: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
125: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 377
1: cpu: 11.8% command: konsole pid: 9087 mem: 242.1 MiB (1.7%)
2: cpu: 9.2% command: firefox pid: 2091 mem: 787.3 MiB (5.6%)
3: cpu: 6.2% command: firefox pid: 2792 mem: 369.2 MiB (2.6%)
4: cpu: 5.2% command: zsh pid: 9109 mem: 12.2 MiB (0.0%)
5: cpu: 4.4% command: kwin_wayland pid: 837 mem: 195.6 MiB (1.4%)
Memory top: 5 of 377
1: mem: 787.3 MiB (5.6%) command: firefox pid: 2091 cpu: 9.2%
2: mem: 424.6 MiB (3.0%) command: firefox pid: 3532 cpu: 2.7%
3: mem: 406.0 MiB (2.9%) command: firefox pid: 2491 cpu: 0.8%
4: mem: 385.6 MiB (2.7%) command: plasmashell pid: 1047 cpu: 0.4%
5: mem: 369.2 MiB (2.6%) command: firefox pid: 2792 cpu: 6.2%
Processes: 377 Power: uptime: 1h 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.4 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
tool: systemctl
Compilers: N/A Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
