I have bought a full-sized USB keyboard for a MacBook Pro 15-inch 2009 due to Nouveau driver locking up and the fact that MacBook keyboard doesn’t have a SysRq key. I have enabled SysRq in the GRUB and journalctl -f prints out sysrq HELP and all key combinations when I press Alt + SysRq + H.
So it works, however when I type REISUB when Nouveau and the screen lock up, even with 10-20 seconds in between key presses, I still get fsck doing its thing on reboot. I can confirm that REISUB is still working during a lockup due to Num/Caps/Scroll locks LED-s working after doing the Alt + SysRq + R, otherwise they don’t work.
So, I was wondering if there is a some other way of safely restarting that I could try.
System information:
~ inxi -Fazy ✔
Kernel: 6.6.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet avail: acpi_pm
root=UUID=3f4ecbd3-6f6f-4b12-851e-a33c129547da rw video=LVDS-2:d
sysrq_always_enabled=1
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: Apple product: MacBookPro5,3 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-F22587C8
Mobo: Apple model: Mac-F22587C8 serial: <superuser required>
uuid: <superuser required> UEFI: Apple v: MBP53.88Z.00AC.B03.0906151647
date: 06/15/09
ID-1: BAT0 charge: 69.0 Wh (100.0%) condition: 69.0/74.5 Wh (92.6%)
volts: 12.4 min: 10.8 model: SMP A1321 type: Li-ion serial: N/A status: full
cycles: 7
Info: model: Intel Core2 Duo T9600 bits: 64 type: MCP arch: Penryn level: v1
built: 2008 process: Intel 45nm family: 6 model-id: 0x17 (23)
stepping: 0xA (10) microcode: 0xA0B
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1592 min/max: 1596/2793 scaling: driver: acpi-cpufreq
governor: powersave cores: 1: 1592 2: 1592 bogomips: 11148
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA G96CM [GeForce 9600M GT] vendor: Apple driver: nouveau
v: kernel non-free: series: 340.xx status: legacy (EOL~2019-12-xx) last:
release: 340.108 kernel: 5.4 xorg: 1.20 arch: Tesla process: 40-80nm
built: 2006-2013 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports:
active: LVDS-1 empty: DP-1 bus-ID: 02:00.0 chip-ID: 10de:0647
class-ID: 0300 temp: 71.0 C
Device-2: NVIDIA C79 [GeForce 9400M] vendor: Apple driver: nouveau
built: 2006-2013 ports: active: none empty: LVDS-2 bus-ID: 03:00.0
chip-ID: 10de:0863 class-ID: 0300 temp: 66.0 C
Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.5
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: nouveau gpu: nouveau,nouveau display-ID: 0
Monitor-1: LVDS-1 res: 1440x900 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 egl: 1.4
drv: nouveau device: 1 egl: 1.4 drv: nouveau device: 2 drv: swrast gbm:
egl: 1.4 drv: nouveau surfaceless: egl: 1.4 drv: nouveau wayland: egl: 1.4
drv: nouveau x11: egl: 1.4 drv: nouveau
API: OpenGL v: 4.5 compat-v: 3.3 vendor: mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: NV96 device-ID: 10de:0647
memory: 494.1 MiB unified: no display-ID: :1.0
Device-1: NVIDIA MCP79 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 00:08.0 chip-ID: 10de:0ac0 class-ID: 0403
API: ALSA v: k6.6.25-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: NVIDIA MCP79 Ethernet driver: forcedeth v: kernel port: 31e0
bus-ID: 00:0a.0 chip-ID: 10de:0ab0 class-ID: 0200
IF: enp0s10 state: down mac: <filter>
Device-2: Broadcom BCM4322 802.11a/b/g/n Wireless LAN
vendor: Apple AirPort Extreme driver: wl v: kernel modules: ssb pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14e4:432b class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Apple Bluetooth Host Controller driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.1:3 chip-ID: 05ac:8213
Local Storage: total: 465.76 GiB used: 350.27 GiB (75.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500BX500SSD1
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 061 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 350.27 GiB (76.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 292 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: file size: 3 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 66.0 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: nouveau temp: 66.0 C device: nouveau temp: 70.0 C mV: 900.00
Memory: total: 8 GiB note: est. available: 7.51 GiB used: 3.21 GiB (42.8%)
Processes: 205 Power: uptime: 2h 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.99 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1917 pm: pacman pkgs: 1847 libs: 535 tools: pamac pm: flatpak
pkgs: 70 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
Output of journalctl -rp err -b-1 (it repeats the last couple of lines infinitely)
~ journalctl -rp err -b-1 ✔ 27s
tra 08 11:10:03 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: Renderer[2088]: nv50cal_space: -16
tra 08 11:10:02 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: Renderer[2088]: nv50cal_space: -16
tra 08 11:10:01 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: Renderer[2088]: nv50cal_space: -16
tra 08 11:10:00 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: Renderer[2088]: nv50cal_space: -16
tra 08 11:09:59 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: Renderer[2088]: nv50cal_space: -16
tra 08 11:09:58 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: Renderer[2088]: nv50cal_space: -16
tra 08 11:09:57 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: Renderer[2088]: nv50cal_space: -16
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: Renderer[2088]: nv50cal_space: -16
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: fb: trapped read at 0040000000 on channel 8 [1f16c000 plasmashell[1646]] engine 00 [PGRAPH] client 0a [TEXTUR>
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00200000 [] ch 8 [001f16c000 plasmashell[1646]] subc 3 class 8297 mthd 15e0 data 00000000
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: TRAP_TEXTURE - TP1: 00000003 [ FAULT]
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00409910: 00000000
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 0040990c: 40000430
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00409908: 00400000
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00409904: 20096001
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: magic set 1:
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: TRAP_TEXTURE - TP0: 00000003 [ FAULT]
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00408910: 00000000
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 0040890c: 40000430
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00408908: 00400000
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00408904: 20095e01
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: magic set 0:
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00409904: 20092e01
tra 08 11:09:56 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00408904: 20094901
tra 08 11:09:55 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: fb: trapped read at 0040000000 on channel 8 [1f16c000 plasmashell[1646]] engine 00 [PGRAPH] client 0a [TEXTUR>
tra 08 11:09:55 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00200000 [] ch 8 [001f16c000 plasmashell[1646]] subc 3 class 8297 mthd 15e0 data 00000000
tra 08 11:09:55 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: TRAP_TEXTURE - TP1: 00000003 [ FAULT]
tra 08 11:09:55 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00409910: 00000000
tra 08 11:09:55 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 0040990c: 40000430
tra 08 11:09:55 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00409908: 00400000
tra 08 11:09:55 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00409904: 20093301
tra 08 11:09:55 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: magic set 1:
tra 08 11:09:55 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: TRAP_TEXTURE - TP0: 00000003 [ FAULT]
tra 08 11:09:55 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00408910: 00000000
tra 08 11:09:55 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 0040890c: 40000430
tra 08 11:09:55 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00408908: 00400000
tra 08 11:09:55 hs0220-macbookpro53 kernel: nouveau 0000:02:00.0: gr: 00408904: 20093f01
