I can’t connect to my 5 GHz wifi. It does not even show up in the list of available networks.
If I change it to 2.4 GHz there is no problem, but I prefer 5 GHz.
My other devices have no trouble connecting to the 5 GHz wifi, only this Linux laptop.
Technical details:
Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f17360b7-fad0-4feb-b024-0adbd2dfa3bd rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 82F7 v: 40.38 serial: <filter> UEFI: Insyde v: F.21
date: 10/27/2016
ID-1: BAT1 charge: 7.9 Wh (29.6%) condition: 26.7/32.1 Wh (83.2%)
volts: 13.9 min: 14.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Discharging
RAM: total: 6.75 GiB used: 1.39 GiB (20.5%)
Info: Quad Core model: AMD A8-7410 APU with AMD Radeon R5 Graphics bits: 64
type: MCP arch: Puma family: 16 (22) model-id: 30 (48) stepping: 1
microcode: 7030105 cache: L2: 2 MiB bogomips: 17575
Speed: 998 MHz min/max: 1000/2200 MHz boost: enabled Core speeds (MHz):
1: 998 2: 998 3: 998 4: 998
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1 bpext
clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de
decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht
hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe
msr mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme vmmcall wdt xsave
xsaveopt
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu bus-ID: 00:01.0
chip-ID: 1002:9851 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon
520 Mobile]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu
bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380
Device-3: Chicony HP Webcam type: USB driver: uvcvideo bus-ID: 2-1.1:3
chip-ID: 04f2:b52d class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
loaded: ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.10.53-1-MANJARO LLVM 12.0.1)
v: 4.5 Mesa 21.1.5 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840
class-ID: 0403
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel port: 3000
bus-ID: 02:00.0 chip-ID: 10ec:b723 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8136
class-ID: 0200
Device-3: ASIX AX88772B type: USB driver: asix bus-ID: 3-2:5
chip-ID: 0b95:772b class-ID: ff00 serial: <filter>
IF: enp0s16u2 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:3 chip-ID: 0bda:b008 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 8.88 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
type: HDD rpm: 5400 serial: <filter> rev: 4C scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW GUD1N rev: MD00 dev-links: cdrom
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 8.88 GiB (1.0%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: f17360b7-fad0-4feb-b024-0adbd2dfa3bd
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 6E55-C823
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0438:7900 class-ID: 0900
Device-1: 1-1.4:3 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s power: 500mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
Device-1: 2-1.1:3 info: Chicony HP Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b52d
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 3-1:2
info: SHARKOON 2.4GHz Wireless rechargeable vertical mouse [More&Better]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-2: 3-2:5 info: ASIX AX88772B type: Network driver: asix interfaces: 1
rev: 2.0 speed: 480 Mb/s power: 200mA chip-ID: 0b95:772b class-ID: ff00
serial: <filter>
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 41.0 C mobo: 20.0 C
GPU: device: radeon temp: 40.0 C device: radeon temp: 39.0 C
Processes: 179 Uptime: 31m wakeups: 39 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1075 lib: 303 flatpak: 0
Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
How can I try to fix this?
