My pc has two hard drives, an HDD and an SSD. I am booting from my SSD. Whenever I try to find the HDD partition through the file manager or the terminal I cannot find it. However I can find it and manipulate it through the partition manager. The HDD is mounted.
This is my inxi output
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=532c825f-d980-451a-8e4c-d49f03f610b3 ro quiet apparmor=1
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: A320M-HDV R4.0 serial: <filter>
UEFI: American Megatrends v: P3.70 date: 11/13/2019
Device-1: sony_controller_battery_34:c7:31:d8:f1:aa model: N/A serial: N/A
charge: N/A status: Full
RAM: total: 13.59 GiB used: 5.7 GiB (41.9%)
Info: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108109 L2 cache: 2 MiB bogomips: 59217
Speed: 1400 MHz min/max: 1400/3700 MHz boost: enabled Core speeds (MHz):
1: 1400 2: 1400 3: 1384 4: 1399 5: 1357 6: 1400 7: 1400 8: 1400
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: AMD Picasso driver: amdgpu v: kernel bus ID: 06:00.0
chip ID: 1002:15d8 class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 98
size: 497x292mm (19.6x11.5") diag: 576mm (22.7")
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.39.0
5.9.16-1-MANJARO LLVM 11.0.1)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus ID: 06:00.1 chip ID: 1002:15de class ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus ID: 06:00.6 chip ID: 1022:15e3 class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
vendor: ASRock driver: r8169 v: kernel port: f000 bus ID: 05:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Ralink RT2870/RT3070 Wireless Adapter type: USB driver: rt2800usb
bus ID: 3-4:3 chip ID: 148f:3070 class ID: 0000 serial: <filter>
IF: wlp6s0f3u4 state: up mac: <filter>
Message: No Bluetooth data was found.
Local Storage: total: 577.55 GiB used: 21.7 GiB (3.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500630NS
size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
serial: <filter> rev: AQMZ scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Patriot model: Burst size: 111.79 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 61.3 scheme: GPT
ID-1: / raw size: 111.49 GiB size: 109.24 GiB (97.98%)
used: 21.7 GiB (19.9%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 532c825f-d980-451a-8e4c-d49f03f610b3
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 57BA-6110
ID-1: /dev/sda1 maj-min: 8:1 size: 465.76 GiB fs: ext4 label: idk
uuid: ee640c96-efcb-4d40-81d3-acea54d7e075
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-7:3 info: Sony Batoh Device / PlayStation 3 Controller type: HID
driver: sony,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 054c:0268
class ID: 0300
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003 class ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-2:2 info: Trust GXT 870 Keyboard type: Keyboard,Mouse
chip ID: 145f:01f2 class ID: 0301
Device-2: 3-4:3 info: Ralink RT2870/RT3070 Wireless Adapter type: Network
driver: rt2800usb interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 148f:3070
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Device-1: 5-1:2 info: Holtek USB Gaming Mouse type: Keyboard,Mouse,HID
driver: holtek_mouse,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
chip ID: 04d9:a070 class ID: 0300
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 43.1 C mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 290 Uptime: 2h 43m wakeups: 1 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1275 lib: 391 flatpak: 0 Shell: Bash v: 5.1.0
running in: konsole inxi: 3.3.01
