I saved a theme I made where did it put it? I looked in usr/shared/themes didn’t find it?
You made it?
You, of course, also saved it somewhere - and now you can’t find it?
… how could we do that?
The file(s) have got a name - search for it.
I thought there was another place mate saved it, no choice was given when I saved it just saves. No picking a folder, I searched, typed what I called it & no results.
That makes no sense.
If you made it, as you said
you know where it is - you could not have made it if you didn’t know.
So you used “Appearance” to edit a theme?
It should be in ~/.themes
Thanks, got it.
