Every time I boot I always enter memtest86. If I exit, it will return to memtest again. How do I get over this?
Maybe something is wrong with grub or you don’t have any kernels installed. Fire up a live usb and run these commands and try again:
manjaro-chroot -a
pacman-mirrors -f 5 && pacman -Syyu
pacman -S grub
exit
If doesn’t work then again chroot and give the output of these:
mhwd-kernel -li
inxi -Fazy
Currently running: 5.11.12-300.fc34.x86_64 (linux511)
- linux510
- linux54
Its doenst work
Instead pacman -S grub
run update-grub
When booting type ESC which will show you the grub boot menu. Then choose Manjaro.
