Hello everyone, I have a little problem with LibreOffice that I hope someone can help me with:
When I try to open files with LibreOffice by double clicking on them (docx, pptx, etc) I get an “error code 100 unknown” (not an exact translation as my system is on Spanish), however if I first launch for example, Writer, and then open the file, I get no errors and can open it normally.
I noticed the libreoffice icons on /usr/share/applications are flagged by a orange exclamation mark, but I don’t know how to fix it
Kernel: 5.4.64-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=831e6f1f-ee62-4cec-b0e7-e358b88f556d rw quiet apparmor=1
security=apparmor resume=UUID=d743d72f-d222-4389-93a5-a2a0755f72be
udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 81FB v: 330S-15ARR serial: <filter>
Chassis: type: 10 v: 330S-15ARR serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: 31900002 WIN serial: <filter>
UEFI: LENOVO v: 7WCN37WW date: 05/22/2019
ID-1: BAT1 charge: 26.6 Wh condition: 26.8/30.0 Wh (89%) volts: 8.2/7.4
model: LENOVO BASE-BAT type: Li-poly serial: <filter> status: Unknown
cycles: 214
Topology: Dual Core model: AMD Ryzen 3 2200U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17)
stepping: N/A microcode: 810100B L2 cache: 1024 KiB
bogomips: 19969
Speed: 2222 MHz min/max: 1600/2500 MHz boost: enabled Core speeds (MHz):
1: 2033 2: 2150 3: 1880 4: 1898
disabled, RSB filling
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel bus ID: 03:00.0 chip ID: 1002:15dd
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus ID: 3-1:2
chip ID: 174f:2426 serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RAVEN (DRM 3.35.0 5.4.64-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.7 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 03:00.1 chip ID: 1002:15de
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x bus ID: 03:00.5 chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.4.64-1-MANJARO
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtl8821ce v: N/A modules: 8821ce port: 2000
bus ID: 01:00.0 chip ID: 10ec:c821
Local Storage: total: 1.82 TiB used: 16.09 GiB (0.9%)
ID-1: /dev/sda vendor: Seagate model: ST2000LM007-1R8174 size: 1.82 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: LDM2 scheme: GPT
ID-1: / raw size: 195.31 GiB size: 191.25 GiB (97.92%)
used: 11.35 GiB (5.9%) fs: ext4 dev: /dev/sda7
ID-2: /home raw size: 1.33 TiB size: 1.31 TiB (98.36%) used: 4.75 GiB (0.4%)
fs: ext4 dev: /dev/sda8
ID-1: swap-1 type: partition size: 8.01 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda6
System Temperatures: cpu: 67.6 C mobo: N/A gpu: amdgpu temp: 67 C
Processes: 224 Uptime: 1h 36m Memory: 6.76 GiB used: 2.60 GiB (38.4%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1276 lib: 354
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
