I looked up at Arch Linux Wiki to disable grub so I opened /etc/default/grub with sudo & nano.
And changed timeout to 0 also style to hidden but when I still boot to Manjaro it show up option to choose Manjaro or Windows. (Yeah I use Windows Bootloader) thats why I wanna disable it.
The timeout was default to 5 like I first time booted but changing it to 0 didnt make any changes does Manjaro use other file for grub?
I already have Windows Bootloader done, I can choose Windows or Manjaro but the thing is when I boot to the Manjaro it show up Grub Loader which Im trying to disable.
But you’ll still need grub to boot linux - you probably only want the menu to be gone or have a zero timeout - but then you’ll lose the ability to boot different kernels.
When I set the timeout to 0 I sent above my grub configuration its countdown from 10 for some reason? And it shouldnt matter I would lose ability if I ever wanted to go back to the grub I could just change the timeout?
True.
But what if you couldn’t boot (after an update for instance …) to a different kernel, even if you had installed two or three.
Be that as it may … it’s your preference …
I don’t have an answer for lack of knowledge and ability to try, since I don’t run Manjaro but Arch.
There are many threads here in the forum which deal with how to configure grub, make the menu hidden, lower the timeout, etc.
Can’t be more specific.
