Can't connect using ethernet, "IP configuration was unavailable"
I just did a clean install of Manjaro. I could connect without issues using the live USB drive.
Now I’m getting the pop-up saying “Wired Interface(enp3s0), IP configuration was unavailable”.
I stumbled upon a Reddit post telling me to do this:
Go to your { System Settings → Connections → ‘Network you try to connect to’ → [ IPv4 tab → tick 'IPv4 is required for this connection." ] → [ IPv6 tab → choose “Method: Ignored” ] → connect to your Network again.
But that didn’t work unfortunately.
here is my system:
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
               parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=3088f24a-2ccd-41db-998e-4fd93ec23584 rw quiet apparmor=1
               Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
    Machine:   Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
               Mobo: ASUSTeK model: Z97-K v: Rev X.0x serial: <filter> UEFI-[Legacy]: American Megatrends v: 2902 date: 03/31/2016
    Battery:   Message: No system battery data found. Is one present?
    Memory:    RAM: total: 23.43 GiB used: 970.2 MiB (4.0%)
    CPU:       Info: Quad Core model: Intel Core i5-4690K bits: 64 type: MCP arch: Haswell family: 6 model-id: 3C (60) stepping: 3
               microcode: 28 cache: L2: 6 MiB bogomips: 28569
               Speed: 1023 MHz min/max: 800/4400 MHz Core speeds (MHz): 1: 1023 2: 1075 3: 960 4: 1067
               Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid
               cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
               fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
               nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
               rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
               tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
               Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
               Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
    Graphics:  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ZOTAC driver: nouveau v: kernel bus-ID: 01:00.0
               chip-ID: 10de:1c03 class-ID: 0300
               Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nouveau unloaded: modesetting
               alternate: fbdev,nv,vesa display-ID: :0 screens: 1
               Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2") s-diag: 1055mm (41.5")
               Monitor-1: DVI-D-1 res: 1920x1080 hz: 60 dpi: 102 size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
               Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
               OpenGL: renderer: NV136 v: 4.3 Mesa 21.1.2 direct render: Yes
    Audio:     Device-1: Intel 9 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
               chip-ID: 8086:8ca0 class-ID: 0403
               Device-2: NVIDIA GP106 High Definition Audio vendor: ZOTAC driver: snd_hda_intel v: kernel bus-ID: 01:00.1
               chip-ID: 10de:10f1 class-ID: 0403
               Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
               Sound Server-4: PipeWire v: 0.3.30 running: no
    Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000
               bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
               WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
    Bluetooth: Message: No bluetooth data found.
    Logical:   Permissions: Unable to run lvs. Root privileges required.
    RAID:      Message: No RAID data found.
    Drives:    Local Storage: total: 1.37 TiB used: 7.98 GiB (0.6%)
               ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB block-size: physical: 512 B
               logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 1B6Q scheme: MBR
               ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-00WN4A0 size: 931.51 GiB block-size:
               physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: MBR
               ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Generic model: STORAGE DEVICE size: 7.42 GiB block-size:
               physical: 512 B logical: 512 B serial: <filter> rev: 9451 scheme: MBR
    Partition: ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%) used: 7.98 GiB (1.7%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
               label: N/A uuid: 3088f24a-2ccd-41db-998e-4fd93ec23584
    Swap:      Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
               ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
    Unmounted: ID-1: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: <superuser required> label: Speicher uuid: 287406D57406A5A2
               ID-2: /dev/sdc1 maj-min: 8:33 size: 2.74 GiB fs: <superuser required> label: MANJARO_KDE_2107
               uuid: 2021-06-14-15-33-09-00
               ID-3: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: <superuser required> label: MISO_EFI uuid: 0ACC-C46C
    USB:       Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
               Hub-2: 1-1:2 info: Intel ports: 6 rev: 2.0 speed: 480 Mb/s chip-ID: 8087:8009 class-ID: 0900
               Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
               Hub-4: 2-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s chip-ID: 8087:8001 class-ID: 0900
               Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
               Device-1: 3-1:2 info: Genesys Logic GL827L SD/MMC/MS Flash Card Reader type: Mass Storage driver: usb-storage
               interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 05e3:0723 class-ID: 0806 serial: <filter>
               Device-2: 3-4:3 info: HP LaserJet P2015 series type: Printer driver: usblp interfaces: 2 rev: 2.0 speed: 480 Mb/s
               power: 2mA chip-ID: 03f0:3817 class-ID: 0701 serial: <filter>
               Device-3: 3-9:4 info: Holtek Keyboard type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
               speed: 1.5 Mb/s power: 100mA chip-ID: 04d9:1203 class-ID: 0300
               Device-4: 3-13:5 info: Cherry MX-Board 3.0 Keyboard type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2
               rev: 2.0 speed: 1.5 Mb/s power: 100mA chip-ID: 046a:010d class-ID: 0300
               Device-5: 3-14:6 info: SteelSeries ApS SteelSeries Rival 300 Gaming Mouse type: HID,Mouse
               driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 200mA chip-ID: 1038:1710 class-ID: 0300
               Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
    Sensors:   System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 37.0 C
               Fan Speeds (RPM): N/A gpu: nouveau fan: 1721
    Info:      Processes: 163 Uptime: 14m wakeups: 0 Init: systemd v: 248 tool: systemctl Compilers: gcc: N/A Packages:
               pacman: 1182 lib: 322 flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
When looking at journalctl for the networkmanager i get:
$ journalctl -b -u NetworkManager
-- Journal begins at Sun 2021-07-25 21:04:21 CEST, ends at Mon 2021-07-26 12:35:50 CEST. --
Jul 26 12:13:04 crosscode systemd[1]: Starting Network Manager...
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.0450] NetworkManager (version 1.30.4-3) is starting... (for the first time)
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.0462] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Jul 26 12:13:05 crosscode systemd[1]: Started Network Manager.
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.0720] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.0839] manager[0x561981674030]: monitoring kernel firmware directory '/lib/firmware'.
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1150] hostname: hostname: using hostnamed
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1150] hostname: hostname changed from (none) to "crosscode"
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1152] dns-mgr[0x561981669110]: init: dns=default,systemd-resolved rc-manager=symlink
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1527] manager[0x561981674030]: rfkill: Wi-Fi hardware radio set enabled
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1527] manager[0x561981674030]: rfkill: WWAN hardware radio set enabled
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1670] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.30.4-3/libnm-device-plugin-adsl.so)
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1686] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.30.4-3/libnm-device-plugin-wifi.so)
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1751] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.30.4-3/libnm-device-plugin-team.so)
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1776] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.30.4-3/libnm-device-plugin-wwan.so)
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1786] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.30.4-3/libnm-device-plugin-ovs.so)
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1804] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.30.4-3/libnm-device-plugin-bluetooth.so)
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1806] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1807] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1807] manager: Networking is enabled by state file
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1813] dhcp-init: Using DHCP client 'internal'
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1816] settings: Loaded settings plugin: keyfile (internal)
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1864] device (lo): carrier: link connected
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1865] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1872] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1894] ovsdb: Could not connect: No such file or directory
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1894] ovsdb: disconnected from ovsdb
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.1897] device (eth0): interface index 2 renamed iface from 'eth0' to 'enp3s0'
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.2217] manager: startup complete
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.2218] device (enp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.4505] modem-manager: ModemManager not available
Jul 26 12:13:05 crosscode NetworkManager[341]: <info>  [1627294385.4520] modem-manager: ModemManager now available
Jul 26 12:13:07 crosscode NetworkManager[341]: <info>  [1627294387.9763] device (enp3s0): carrier: link connected
Jul 26 12:13:07 crosscode NetworkManager[341]: <info>  [1627294387.9765] device (enp3s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Jul 26 12:13:07 crosscode NetworkManager[341]: <info>  [1627294387.9769] policy: auto-activating connection 'Wired connection 1' (aef88f53-47b6-33bc-a1a0-e2bc4d2a6315)
Jul 26 12:13:07 crosscode NetworkManager[341]: <info>  [1627294387.9772] device (enp3s0): Activation: starting connection 'Wired connection 1' (aef88f53-47b6-33bc-a1a0-e2bc4d2a6315)
Jul 26 12:13:07 crosscode NetworkManager[341]: <info>  [1627294387.9773] device (enp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 26 12:13:07 crosscode NetworkManager[341]: <info>  [1627294387.9774] manager: NetworkManager state is now CONNECTING
Jul 26 12:13:07 crosscode NetworkManager[341]: <info>  [1627294387.9776] device (enp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 26 12:13:07 crosscode NetworkManager[341]: <info>  [1627294387.9778] device (enp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jul 26 12:13:07 crosscode NetworkManager[341]: <info>  [1627294387.9780] dhcp4 (enp3s0): activation: beginning transaction (timeout in 45 seconds)
Jul 26 12:13:17 crosscode NetworkManager[341]: <info>  [1627294397.9055] agent-manager: agent[3af49acbdbf7bd30,:1.38/org.kde.plasma.networkmanagement/1000]: agent registered
Jul 26 12:13:53 crosscode NetworkManager[341]: <warn>  [1627294433.0361] dhcp4 (enp3s0): request timed out
Jul 26 12:13:53 crosscode NetworkManager[341]: <info>  [1627294433.0362] dhcp4 (enp3s0): state changed unknown -> timeout
Jul 26 12:13:53 crosscode NetworkManager[341]: <info>  [1627294433.0363] device (enp3s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Jul 26 12:13:53 crosscode NetworkManager[341]: <info>  [1627294433.0371] manager: NetworkManager state is now DISCONNECTED
Jul 26 12:13:53 crosscode NetworkManager[341]: <warn>  [1627294433.0388] device (enp3s0): Activation: failed for connection 'Wired connection 1'
Jul 26 12:13:53 crosscode NetworkManager[341]: <info>  [1627294433.0393] device (enp3s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Jul 26 12:13:53 crosscode NetworkManager[341]: <info>  [1627294433.0528] dhcp4 (enp3s0): canceled DHCP transaction
Jul 26 12:13:53 crosscode NetworkManager[341]: <info>  [1627294433.0528] dhcp4 (enp3s0): state changed timeout -> terminated
Jul 26 12:13:53 crosscode NetworkManager[341]: <info>  [1627294433.0622] policy: auto-activating connection 'Wired connection 1' (aef88f53-47b6-33bc-a1a0-e2bc4d2a6315)
Jul 26 12:13:53 crosscode NetworkManager[341]: <info>  [1627294433.0663] device (enp3s0): state change: disconnected -> unavailable (reason 'carrier-changed', sys-iface-state: 'managed')
Just now I booted from the live USB again. For some reason I can’t connect to the internet with it anymore. It seems to be the same problem. I tried restarting my router and getting rid of all the IP entries that aren’t used anymore but no luck.
Shutdown router and PC for a couple minutes and try again.
