inxi -Fazy
Kernel: 6.1.34-1-MANJARO-ARM-RPI arch: aarch64 bits: 64 compiler: gcc
v: 12.1.0 parameters: coherent_pool=1M 8250.nr_uarts=0
snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1
snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0
video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:CE:66:45
vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000
root=PARTUUID=aa7fddd0-02 rw rootwait console=ttyS0,115200 console=tty3
selinux=0 quiet splash plymouth.ignore-serial-consoles
smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 usbhid.mousepoll=8 audit=0
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Distro: Manjaro ARM base: Arch Linux
Type: ARM System: Raspberry Pi 4 Model B Rev 1.4 details: BCM2835 rev: d03114
serial: <filter>
Info: model: N/A variant: cortex-a72 bits: 64 type: MCP arch: ARMv8 family: 8
model-id: 0 stepping: 3
Topology: cpus: 1x cores: 4 smt: N/A cache: L1: 320 KiB
desc: d-4x32 KiB; i-4x48 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 600 min/max: 600/1500 scaling: driver: cpufreq-dt
governor: schedutil cores: 1: 600 2: 600 3: 600 4: 600 bogomips: 432
Features: Use -f option to see features
Type: spectre_v1 mitigation: __user pointer sanitization
Type: spectre_v2 status: Vulnerable
Device-1: bcm2711-hdmi0 driver: vc4_hdmi v: N/A bus-ID: N/A
chip-ID: brcm:fef00700 class-ID: hdmi
Device-2: bcm2711-hdmi1 driver: vc4_hdmi v: N/A bus-ID: N/A
chip-ID: brcm:fef05700 class-ID: hdmi
Device-3: bcm2711-vc5 driver: vc4_drm v: N/A bus-ID: N/A chip-ID: brcm:gpu
class-ID: gpu
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev dri: vc4
gpu: vc4-drm,vc4_crtc,vc4_dpi,vc4_dsi,vc4_firmware_kms,vc4_hdmi,vc4_hvs,vc4_txp,vc4_v3d,vc4_vec
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Acer S241HL serial: <filter>
built: 2014 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL v: 2.1 Mesa 23.0.3 renderer: V3D 4.2 direct-render: Yes
Device-1: bcm2711-hdmi0 driver: vc4_hdmi bus-ID: N/A chip-ID: brcm:fef00700
class-ID: hdmi
Device-2: bcm2711-hdmi1 driver: vc4_hdmi bus-ID: N/A chip-ID: brcm:fef05700
class-ID: hdmi
API: ALSA v: k6.1.34-1-MANJARO-ARM-RPI status: kernel-api
Server-2: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
Device-1: bcm2835-mmc driver: mmc_bcm2835 v: N/A port: N/A bus-ID: N/A
chip-ID: brcm:fe300000 class-ID: mmcnr
IF: wlan0 state: dormant mac: <filter>
Device-2: bcm2711-genet-v5 driver: bcmgenet v: N/A port: N/A bus-ID: N/A
chip-ID: brcm:fd580000 class-ID: ethernet
IF: end0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: pl011 driver: uart_pl011 bus-ID: N/A chip-ID: arm:fe201000
class-ID: serial
Device-2: pl011 driver: N/A bus-ID: N/A chip-ID: arm:serial0
class-ID: serial
Local Storage: total: 119.08 GiB used: 5.89 GiB (4.9%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SR128 size: 119.08 GiB block-size:
physical: 512 B logical: 512 B tech: SSD serial: <filter> scheme: MBR
ID-1: / raw-size: 118.61 GiB size: 116.69 GiB (98.39%) used: 5.84 GiB (5.0%)
fs: ext4 dev: /dev/mmcblk0p2 maj-min: 179:2
ID-2: /boot raw-size: 457.8 MiB size: 457.5 MiB (99.94%)
used: 54.6 MiB (11.9%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
Kernel: swappiness: 60 (default) cache-pressure: 80 (default 100)
ID-1: swap-1 type: zram size: 11.44 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/zram0
System Temperatures: cpu: 44.3 C mobo: N/A
Processes: 191 Uptime: 1h 8m Memory: available: 7.63 GiB
used: 1.73 GiB (22.7%) gpu: 76 MiB Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pm: pacman pkgs: 746
libs: 196 tools: pamac Shell: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.27
I just installed Manjaro ARM KDE (Full) on a Raspberry Pi 4 (8gb).
The issue I’m having is it won’t connect to any WiFi with WPA2-PSK AES. I’ve seen something similar in several posts on Raspberry Pi forums, after doing a Google search, but I can’t seem to solve it with those; talking about wpa_supplicant
and /etc/wpa_supplicant/wpa_supplicant.conf
etc.
It sees the SSID for all three networks (2.4GHz, 5GHz and a 2.4GHz Virtual; more on that one in a second) and it tries to connect, but it just keeps asking for the password over and over again. Ethernet works fine.
If I set the 2.4GHz (Virtual) to WPA-PSK AES (so not WPA2), as a test, it connects fine.
Security in Settings > Connections > Wi-Fi > [SSID name of connection] > Wi-Fi Security Tab > Security: is set to WPA/WPA2 Personal for all my networks.
Is there something I need to do extra in order to get WPA2-PSK AES working?
Note: I realize the easy solution is to change all my security settings, but I’d like to keep it as is, since I have some range extenders and other devices already setup and working and it’s my understanding WPA2 is more secure than WPA or WEP.
Happy to provide any command output required to help troubleshoot.
Thanks!
