Hello everyone, decided to take a dive in Linux and im facing some connectivity issues. Im on Manjaro KDE Plasma 5.21 (Kernel 5.4, have also tried 5.10) and dual booting with Windows 10. Fast boot is disabled on windows. On installation I chose proprietary drivers.
Ethernet works just fine, WiFi scans and finds all networks correctly but when I try to connect and enter my password, it fails to connect and asks for the password again. Then it keeps trying to connect on its own and always fails.
This is my inxi output:
Kernel: 5.10.26-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=a09e1dbc-3108-4428-a94e-f0b5802bc939 rw quiet apparmor=1
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Laptop 15-db1xxx v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 85EA v: 51.13 serial: <filter> UEFI: Insyde v: F.05
date: 02/01/2019
ID-1: BAT1 charge: 19.0 Wh (47.9%) condition: 39.7/42.1 Wh (94.3%)
volts: 11.2 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Discharging
RAM: total: 5.81 GiB used: 818.7 MiB (13.8%)
Info: Quad Core model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen/Zen+ note: check family: 17 (23)
model-id: 18 (24) stepping: 1 microcode: 8108102 cache: L2: 2 MiB
bogomips: 36751
Speed: 1223 MHz min/max: 1400/2300 MHz boost: disabled Core speeds (MHz):
1: 1223 2: 1261 3: 1221 4: 1221 5: 1222 6: 1223 7: 1223 8: 1221
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: USB driver: uvcvideo bus-ID: 3-2.1:4 chip-ID: 05c8:03d2 class-ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.40.0
5.10.26-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.1 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.10.26-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.24 running: no
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8821ce v: N/A
modules: rtw88_8821ce,8821ce port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:c821
class-ID: 0280
IF: wlo1 state: dormant mac: <filter>
Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 3-2.3:5 chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
Message: No LVM data was found.
Local Storage: total: 1.03 TiB used: 7.78 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-60Z10T0
rotation: 5400 rpm serial: <filter> rev: 1A04 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SD9SN8W-128G-1006
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 4006 scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW DA8AESH rev: XH6M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 59.32 GiB size: 58.09 GiB (97.92%) used: 7.75 GiB (13.3%)
fs: ext4 dev: /dev/sdb5 maj-min: 8:21 label: N/A
uuid: a09e1dbc-3108-4428-a94e-f0b5802bc939
used: 25.2 MiB (26.3%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 96E5-AC7A
ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda2 maj-min: 8:2 size: 931.5 GiB fs: ntfs label: N/A
uuid: D4A87BA4A87B8430
ID-3: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
ID-4: /dev/sdb3 maj-min: 8:19 size: 59.32 GiB fs: ntfs label: N/A
uuid: 5EB87DBFB87D95ED
ID-5: /dev/sdb4 maj-min: 8:20 size: 499 MiB fs: ntfs label: N/A
uuid: 6A8AB6F28AB6B9C1
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-1:2 info: Maxxter Telink Wireless Receiver type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 50mA
chip-ID: 248a:8367 class-ID: 0301
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 3-1:2 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E SATA 6Gb/s
bridge ASM1153 SATA 3Gb/s bridge ASM1153E SATA 6Gb/s bridge
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s chip-ID: 174c:55aa class-ID: 0806 serial: <filter>
Hub-4: 3-2:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-2.1:4
info: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:03d2 class-ID: 0e02
Device-2: 3-2.3:5 info: Realtek Realtek Bluetooth 4.2 Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 46.1 C mobo: 20.0 C gpu: amdgpu temp: 46.0 C
Processes: 214 Uptime: 5m wakeups: 1 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 1201 lib: 326 flatpak: 0
Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.03
This is my rfkill list all output:
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
This is my dmesg -l emerg,alert,crit,err,warn output:
[ 0.244407] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP2.BCM5], AE_NOT_FOUND (20200925/dswload2-162)
[ 0.244412] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20200925/psobject-220)
[ 0.244476] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP1.DEV0], AE_NOT_FOUND (20200925/dswload2-162)
[ 0.244478] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20200925/psobject-220)
[ 0.256541] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.WLBU._STA.WLVD], AE_NOT_FOUND (20200925/psargs-330)
[ 0.256546] ACPI Error: Aborting method \_SB.WLBU._STA due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
[ 0.323901] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.WLBU._STA.WLVD], AE_NOT_FOUND (20200925/psargs-330)
[ 0.323908] ACPI Error: Aborting method \_SB.WLBU._STA due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
[ 0.398836] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.WLBU._STA.WLVD], AE_NOT_FOUND (20200925/psargs-330)
[ 0.398851] ACPI Error: Aborting method \_SB.WLBU._STA due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
[ 0.647542] pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
[ 0.647738] pci 0000:00:00.2: can't derive routing for PCI INT A
[ 0.647741] pci 0000:00:00.2: PCI INT A: not connected
[ 0.650409] PPR NX GT IA GA PC GA_vAPIC
[ 2.721621] systemd-journald[247]: File /var/log/journal/7e5b55247e4247cd9e941f28426cc2df/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 2.900684] wmi_bus wmi_bus-PNP0C14:00: WQBJ data block query control method not found
[ 3.109050] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 3.390755] 8821ce: loading out-of-tree module taints kernel.
[ 3.763415] snd_pci_acp3x 0000:04:00.5: Invalid ACP audio mode : 1
[ 4.487409] hp_wmi: query 0x4c returned error 0x6
[ 5.727548] kauditd_printk_skb: 40 callbacks suppressed
[ 14.012281] kauditd_printk_skb: 9 callbacks suppressed
[ 16.838707] systemd-journald[247]: File /var/log/journal/7e5b55247e4247cd9e941f28426cc2df/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 26.800360] kauditd_printk_skb: 7 callbacks suppressed
[ 918.194287] atkbd serio0: Unknown key pressed (translated set 2, code 0xd8 on isa0060/serio0).
[ 918.194294] atkbd serio0: Use 'setkeycodes e058 <keycode>' to make it known.
[ 918.202302] atkbd serio0: Unknown key released (translated set 2, code 0xd8 on isa0060/serio0).
[ 918.202308] atkbd serio0: Use 'setkeycodes e058 <keycode>' to make it known.
[ 1160.518210] ACPI: button: The lid device is not compliant to SW_LID.
I have tried multiple things like installing the appropriate dkms headers and doing pamac build rtl8821ce-dkms-git from the git repository. I have also searched on this forum and tried everything to no avail.
Also sudo systemctl restart NetworkManager did nothing.
(Dont know if it helps but i’ve had the same issue with Ubuntu but it was fixed when I installed dkms and built the github driver)
Let me know if you need any further advice from me and thanks in advance.
