I am on Linux Manjaro with xfce desktop environment. I cannot connect to my Epson ET 2700 printer for printing, although I can use it to scan. Troubleshooting log is below. Is there a clue from it to figure out the connectivity problem? Thanks,
Page 2 (<troubleshoot.SchedulerNotRunning.SchedulerNotRunning object at 0x7f94cfb54150>):
{'cups_connection_failure': False}
Page 2 (<troubleshoot.CheckLocalServerPublishing.CheckLocalServerPublishing object at 0x7f94cea857d0>):
{'local_server_exporting_printers': False}
Page 3 (<troubleshoot.ChoosePrinter.ChoosePrinter object at 0x7f94cd788e10>):
{'cups_dest': <cups.Dest EPSON-ET-2700-Series (default)>,
'cups_instance': None,
'cups_queue': 'EPSON-ET-2700-Series',
'cups_queue_listed': True}
Page 4 (<troubleshoot.CheckPrinterSanity.CheckPrinterSanity object at 0x7f94cea25b10>):
{'cups_device_uri_scheme': 'dnssd',
'cups_printer_dict': {'device-uri': 'dnssd://EPSON%20ET-2700%20Series._pdl-datastream._tcp.local/',
'printer-info': 'EPSON ET-2700 Series',
'printer-is-shared': True,
'printer-location': 'Operations Room',
'printer-make-and-model': 'Epson Expression ET-2700 '
'EcoTank - CUPS+Gutenprint '
'v5.3.4',
'printer-state': 3,
'printer-state-message': '',
'printer-state-reasons': ['none'],
'printer-type': 8556556,
'printer-uri-supported': 'ipp://localhost/printers/EPSON-ET-2700-Series'},
'cups_printer_remote': False,
'is_cups_class': False,
'local_cups_queue_attributes': {'charset-configured': 'utf-8',
'charset-supported': ['us-ascii', 'utf-8'],
'color-supported': True,
'compression-supported': ['none', 'gzip'],
'copies-default': 1,
'copies-supported': (1, 9999),
'cups-version': '2.4.2',
'document-format-default': 'application/octet-stream',
'document-format-preferred': 'application/pdf',
'document-format-supported': ['application/octet-stream',
'application/pdf',
'application/postscript',
'application/vnd.adobe-reader-postscript',
'application/vnd.cups-command',
'application/vnd.cups-pdf',
'application/vnd.cups-pdf-banner',
'application/vnd.cups-postscript',
'application/vnd.cups-raster',
'application/vnd.cups-raw',
'application/x-cshell',
'application/x-csource',
'application/x-perl',
'application/x-shell',
'image/gif',
'image/jpeg',
'image/png',
'image/pwg-raster',
'image/tiff',
'image/urf',
'image/x-bitmap',
'image/x-photocd',
'image/x-portable-anymap',
'image/x-portable-bitmap',
'image/x-portable-graymap',
'image/x-portable-pixmap',
'image/x-sgi-rgb',
'image/x-sun-raster',
'image/x-xbitmap',
'image/x-xpixmap',
'image/x-xwindowdump',
'text/css',
'text/html',
'text/plain'],
'finishings-default': 3,
'finishings-supported': [3],
'generated-natural-language-supported': ['en-us'],
'ipp-features-supported': ['subscription-object'],
'ipp-versions-supported': ['1.0',
'1.1',
'2.0',
'2.1'],
'ippget-event-life': 15,
'job-cancel-after-default': 10800,
'job-cancel-after-supported': (0, 2147483647),
'job-creation-attributes-supported': ['copies',
'finishings',
'finishings-col',
'ipp-attribute-fidelity',
'job-hold-until',
'job-name',
'job-priority',
'job-sheets',
'media',
'media-col',
'multiple-document-handling',
'number-up',
'number-up-layout',
'orientation-requested',
'output-bin',
'page-delivery',
'page-ranges',
'print-color-mode',
'print-quality',
'print-scaling',
'printer-resolution',
'sides'],
'job-hold-until-default': 'no-hold',
'job-hold-until-supported': ['no-hold',
'indefinite',
'day-time',
'evening',
'night',
'second-shift',
'third-shift',
'weekend'],
'job-ids-supported': True,
'job-k-limit': 0,
'job-k-octets-supported': (0, 479291616),
'job-page-limit': 0,
'job-priority-default': 50,
'job-priority-supported': [100],
'job-quota-period': 0,
'job-settable-attributes-supported': ['copies',
'finishings',
'job-hold-until',
'job-name',
'job-priority',
'media',
'media-col',
'number-up',
'output-bin',
'page-ranges',
'print-color-mode',
'print-quality',
'sides'],
'job-sheets-default': ('none', 'none'),
'job-sheets-supported': ['none',
'classified',
'confidential',
'form',
'secret',
'standard',
'topsecret',
'unclassified'],
'jpeg-k-octets-supported': (0, 479291616),
'jpeg-x-dimension-supported': (0, 65535),
'jpeg-y-dimension-supported': (1, 65535),
'marker-change-time': 0,
'media-bottom-margin-supported': [0,
1588,
1517],
'media-col-default': '(unknown IPP value tag '
'0x34)',
'media-col-ready': ['(unknown IPP value tag '
'0x34)',
'0x34)'],
'media-col-supported': ['media-bottom-margin',
'media-left-margin',
'media-right-margin',
'media-size',
'media-source',
'media-top-margin',
'media-type'],
'media-default': 'na_letter_8.5x11in',
'media-left-margin-supported': [0, 635, 776],
'media-ready': ['na_letter_8.5x11in',
'na_legal_8.5x14in'],
'media-right-margin-supported': [0, 635, 776],
'media-size-supported': ['(unknown IPP value '
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)'],
'media-supported': ['na_letter_8.5x11in',
'na_legal_8.5x14in',
'na_executive_7.25x10.5in',
'custom_99.84x146.76mm_99.84x146.76mm',
'custom_116.06x116.06mm_116.06x116.06mm',
'custom_64.91x64.91mm_64.91x64.91mm',
'custom_119.94x119.94mm_119.94x119.94mm',
'na_index-3x5_3x5in',
'oe_photo-l_3.5x5in',
'custom_2x6in_2x6in',
'na_index-4x6_4x6in',
'custom_114.3x174.63mm_114.3x174.63mm',
'custom_104.78x148.52mm_104.78x148.52mm',
'custom_4x8in_4x8in',
'na_5x7_5x7in',
'na_index-5x8_5x8in',
'na_index-4x6-ext_6x8in',
'na_6x9_6x9in',
'na_govt-letter_8x10in',
'na_invoice_5.5x8.5in',
'custom_5x5in_5x5in',
'custom_8x12in_8x12in',
'iso_a4_210x297mm',
'iso_a5_148x210mm',
'iso_a6_105x148mm',
'iso_a7_74x105mm',
'iso_a8_52x74mm',
'iso_ra4_215x305mm',
'iso_b5_176x250mm',
'iso_b6_125x176mm',
'iso_b7_88x125mm',
'iso_b8_62x88mm',
'custom_182.74x256.47mm_182.74x256.47mm',
'custom_127.71x182.74mm_127.71x182.74mm',
'jis_b7_91x128mm',
'jis_b8_64x91mm',
'iso_c5_162x229mm',
'iso_b6c4_125x324mm',
'iso_c6_114x162mm',
'iso_dl_110x220mm',
'iso_c7c6_81x162mm',
'iso_c7_81x114mm',
'iso_c8_57x81mm',
'custom_155.93x228.95mm_155.93x228.95mm',
'na_foolscap_8.5x13in',
'custom_188.74x245.89mm_188.74x245.89mm',
'custom_200.73x257.88mm_200.73x257.88mm',
'custom_122.77x185.91mm_122.77x185.91mm',
'custom_128.76x197.91mm_128.76x197.91mm',
'custom_137.94x215.9mm_137.94x215.9mm',
'custom_155.93x233.89mm_155.93x233.89mm',
'custom_110.77x177.8mm_110.77x177.8mm',
'custom_110.77x180.98mm_110.77x180.98mm',
'om_small-photo_100x150mm',
'jpn_hagaki_100x148mm',
'jpn_oufuku_148x200mm',
'jpn_chou3_120x235mm',
'jpn_chou4_90x205mm',
'jpn_you4_105x235mm',
'jpn_you6_98x190mm',
'na_number-10_4.125x9.5in',
'na_a2_4.375x5.75in',
'na_monarch_3.875x7.5in',
'custom_101.6x136.53mm_101.6x136.53mm',
'custom_4x7in_4x7in',
'custom_101.6x180.62mm_101.6x180.62mm',
'custom_89.25x118.89mm_89.25x118.89mm',
'custom_54.68x86.08mm_54.68x86.08mm',
'custom_54.68x90.66mm_54.68x90.66mm',
'om_small-photo_100x200mm',
'om_w612h935_215.9x329.85mm',
'custom_214.84x345.02mm_214.84x345.02mm',
'custom_8.5x12.5in_8.5x12.5in',
'custom_215.9x354.89mm_215.9x354.89mm',
'na_oficio_8.5x13.4in',
'custom_min_2x2in',
'custom_max_8.5x-490.-931in'],
'media-top-margin-supported': [0, 635, 600],
'media-type-supported': ['stationery',
'stationery',
'postcard',
'photographic-glossy',
'transparency',
'envelope',
'back-film',
'photographic-matte',
'matte-heavy',
'stationery-inkjet',
'stationery-coated',
'photo',
'semigloss',
'luster',
'ilford',
'color-life',
'other'],
'mopria-certified': '1.3',
'multiple-document-handling-supported': ['separate-documents-uncollated-copies',
'separate-documents-collated-copies'],
'multiple-document-jobs-supported': True,
'multiple-operation-time-out': 900,
'multiple-operation-time-out-action': 'process-job',
'natural-language-configured': 'en-us',
'notify-attributes-supported': ['printer-state-change-time',
'notify-lease-expiration-time',
'notify-subscriber-user-name'],
'notify-events-default': ['job-completed'],
'notify-events-supported': ['job-completed',
'job-config-changed',
'job-created',
'job-progress',
'job-state-changed',
'job-stopped',
'printer-added',
'printer-changed',
'printer-config-changed',
'printer-deleted',
'printer-finishings-changed',
'printer-media-changed',
'printer-modified',
'printer-restarted',
'printer-shutdown',
'printer-state-changed',
'printer-stopped',
'server-audit',
'server-restarted',
'server-started',
'server-stopped'],
'notify-lease-duration-default': 86400,
'notify-lease-duration-supported': (0,
2147483647),
'notify-max-events-supported': [100],
'notify-pull-method-supported': ['ippget'],
'notify-schemes-supported': ['dbus',
'mailto',
'rss'],
'number-up-default': 1,
'number-up-layout-supported': ['btlr',
'btrl',
'lrbt',
'lrtb',
'rlbt',
'rltb',
'tblr',
'tbrl'],
'number-up-supported': [1, 2, 4, 6, 9, 16],
'operations-supported': [2,
4,
5,
6,
8,
9,
10,
11,
12,
13,
16,
17,
18,
19,
20,
21,
22,
23,
24,
25,
26,
27,
28,
34,
35,
37,
38,
56,
57,
59,
16385,
16386,
16387,
16388,
16389,
16390,
16391,
16392,
16393,
16394,
16395,
16396,
16397,
16398,
16399,
16423,
14],
'orientation-requested-default': None,
'orientation-requested-supported': [3,
4,
5,
6],
'output-bin-default': 'face-up',
'output-bin-supported': ['face-up'],
'page-delivery-supported': ['reverse-order',
'same-order'],
'page-ranges-supported': True,
'pages-per-minute': 1,
'pages-per-minute-color': 1,
'pdf-k-octets-supported': (0, 479291616),
'pdf-versions-supported': ['adobe-1.2',
'adobe-1.3',
'adobe-1.4',
'adobe-1.5',
'adobe-1.6',
'adobe-1.7',
'iso-19005-1_2005',
'iso-32000-1_2008',
'pwg-5102.3'],
'pdl-override-supported': ['attempted'],
'port-monitor': 'none',
'port-monitor-supported': ['none'],
'print-color-mode-default': 'monochrome',
'print-color-mode-supported': ['monochrome',
'color'],
'print-quality-default': 4,
'print-quality-supported': [4, 5],
'print-scaling-supported': ['auto',
'auto-fit',
'fill',
'fit',
'none'],
'printer-commands': ['AutoConfigure',
'Clean',
'PrintSelfTestPage'],
'printer-config-change-date-time': '(IPP_TAG_DATE)',
'printer-config-change-time': 1688145614,
'printer-current-time': '(IPP_TAG_DATE)',
'printer-dns-sd-name': None,
'printer-error-policy': 'stop-printer',
'printer-error-policy-supported': ['abort-job',
'retry-current-job',
'retry-job',
'stop-printer'],
'printer-geo-location': '(unknown IPP value '
'tag 0x12)',
'printer-get-attributes-supported': ['document-format'],
'printer-icons': 'http://localhost/icons/EPSON-ET-2700-Series.png',
'printer-id': 3,
'printer-is-accepting-jobs': True,
'printer-is-temporary': False,
'printer-make-and-model': 'Epson Expression '
'ET-2700 EcoTank - '
'CUPS+Gutenprint '
'v5.3.4',
'printer-more-info': 'http://localhost/printers/EPSON-ET-2700-Series',
'printer-name': 'EPSON-ET-2700-Series',
'printer-op-policy': 'default',
'printer-op-policy-supported': ['authenticated',
'default',
'kerberos'],
'printer-organization': '',
'printer-organizational-unit': '',
'printer-resolution-default': (361, 360, 3),
'printer-resolution-supported': [(361, 360, 3),
(360, 180, 3),
(360, 360, 3),
(720, 360, 3),
(720, 720, 3),
(1440,
720,
3),
(1441,
720,
3),
(1442,
720,
3),
(1443,
720,
3),
(1444,
720,
3)],
'printer-settable-attributes-supported': ['printer-geo-location',
'printer-info',
'printer-location',
'printer-organization',
'printer-organizational-unit'],
'printer-state': 3,
'printer-state-change-date-time': '(IPP_TAG_DATE)',
'printer-state-change-time': 1688145621,
'printer-strings-uri': 'http://localhost/strings/EPSON-ET-2700-Series.strings',
'printer-up-time': 1688145798,
'printer-uri-supported': ['ipp://localhost/printers/EPSON-ET-2700-Series'],
'printer-uuid': 'urn:uuid:75da3c74-66cc-3fda-4d75-4affe5bcd8e9',
'pwg-raster-document-resolution-supported': [(361,
360,
3)],
'pwg-raster-document-type-supported': ['black_1',
'sgray_8',
'srgb_8'],
'queued-job-count': 0,
'server-is-sharing-printers': False,
'sides-default': 'one-sided',
'sides-supported': ['one-sided'],
'urf-supported': ['V1.4',
'CP1',
'W8',
'PQ4-5',
'OFU0',
'SRGB24',
'RS361',
'FN3'],
'uri-authentication-supported': ['requesting-user-name'],
'uri-security-supported': ['none'],
'which-jobs-supported': ['completed',
'not-completed',
'aborted',
'all',
'canceled',
'pending',
'pending-held',
'processing',
'processing-stopped']}}
Page 5 (<troubleshoot.CheckPPDSanity.CheckPPDSanity object at 0x7f94cea84950>):
{'cups_printer_ppd_defaults': {'C0L0': {'StpFullBleed': 'False',
'StpInkSet': 'None'},
'C0L2': {'StpPrintingDirection': 'Bidirectional',
'StpWeave': 'Staggered'},
'C0L3': {'StpBandEnhancement': 'None',
'StpInkType': 'RGB'},
'C0L4': {'StpFeedSequence': 'None'},
'C1L0': {'StpBrightness': '1100',
'StpColorCorrection': 'None',
'StpContrast': 'None',
'StpFineBrightness': 'None',
'StpFineContrast': 'None',
'StpFineSaturation': 'None',
'StpImageType': 'TextGraphics',
'StpSaturation': 'None'},
'C1L1': {'StpBlackDensity': 'None',
'StpCyanDensity': 'None',
'StpDensity': 'None',
'StpDitherAlgorithm': 'Adaptive',
'StpFineBlackDensity': 'None',
'StpFineCyanDensity': 'None',
'StpFineDensity': 'None',
'StpFineMagentaDensity': 'None',
'StpFineYellowDensity': 'None',
'StpMagentaDensity': 'None',
'StpYellowDensity': 'None'},
'C1L2': {'StpBlackGamma': 'None',
'StpCyanBalance': 'None',
'StpCyanGamma': 'None',
'StpFineBlackGamma': 'None',
'StpFineCyanBalance': 'None',
'StpFineCyanGamma': 'None',
'StpFineGamma': 'None',
'StpFineMagentaBalance': 'None',
'StpFineMagentaGamma': 'None',
'StpFineYellowBalance': 'None',
'StpFineYellowGamma': 'None',
'StpGamma': 'None',
'StpMagentaBalance': 'None',
'StpMagentaGamma': 'None',
'StpYellowBalance': 'None',
'StpYellowGamma': 'None'},
'C1L4': {'StpLinearContrast': 'False'},
'C1L5': {'StpBlackTrans': 'None',
'StpDropSize1': 'None',
'StpDropSize2': 'None',
'StpDropSize3': 'None',
'StpFineBlackTrans': 'None',
'StpFineDropSize1': 'None',
'StpFineDropSize2': 'None',
'StpFineDropSize3': 'None',
'StpFineGCRLower': 'None',
'StpFineGCRUpper': 'None',
'StpFineGray1Value': 'None',
'StpFineGray2Value': 'None',
'StpFineGray3Value': 'None',
'StpFineHGray1Scale': 'None',
'StpFineHGray1Trans': 'None',
'StpFineHGray1Value': 'None',
'StpFineHGray2Scale': 'None',
'StpFineHGray2Trans': 'None',
'StpFineHGray2Value': 'None',
'StpFineHGray3Scale': 'None',
'StpFineHGray3Trans': 'None',
'StpFineHGray3Value': 'None',
'StpFineHGray4Scale': 'None',
'StpFineHGray4Trans': 'None',
'StpFineHGray4Value': 'None',
'StpFineHGray5Scale': 'None',
'StpFineHGray5Trans': 'None',
'StpFineHGray5Value': 'None',
'StpFineInkLimit': 'None',
'StpFineSubchannelCutoff': 'None',
'StpGCRLower': 'None',
'StpGCRUpper': 'None',
'StpGray1Value': 'None',
'StpGray2Value': 'None',
'StpGray3Value': 'None',
'StpHGray1Scale': 'None',
'StpHGray1Trans': 'None',
'StpHGray1Value': 'None',
'StpHGray2Scale': 'None',
'StpHGray2Trans': 'None',
'StpHGray2Value': 'None',
'StpHGray3Scale': 'None',
'StpHGray3Trans': 'None',
'StpHGray3Value': 'None',
'StpHGray4Scale': 'None',
'StpHGray4Trans': 'None',
'StpHGray4Value': 'None',
'StpHGray5Scale': 'None',
'StpHGray5Trans': 'None',
'StpHGray5Value': 'None',
'StpInkLimit': 'None',
'StpSubchannelCutoff': 'None'},
'General': {'ColorModel': 'Gray',
'MediaType': 'Plain',
'OutputOrder': 'Reverse',
'PageRegion': 'Letter',
'PageSize': 'Letter',
'Resolution': '361x360dpi',
'StpColorPrecision': 'Normal',
'StpQuality': 'Standard',
'StpiShrinkOutput': 'Shrink'}},
'cups_printer_ppd_valid': True,
'missing_pkgs_and_exes': ([], [])}
Page 6 (<troubleshoot.LocalOrRemote.LocalOrRemote object at 0x7f94d099d0d0>):
{'printer_is_remote': False}
Page 7 (<troubleshoot.DeviceListed.DeviceListed object at 0x7f94cea65a10>):
{'cups_device_dict': {'device-class': 'network',
'device-id': 'MFG:EPSON;MDL:ET-2700 Series;',
'device-info': 'EPSON ET-2700 Series',
'device-make-and-model': 'EPSON ET-2700 Series'}}
Page 8 (<troubleshoot.ErrorLogCheckpoint.ErrorLogCheckpoint object at 0x7f94cf800610>):
{'cups_server_settings': {'BrowseLocalProtocols': 'dnssd',
'Browsing': 'Yes',
'DefaultAuthType': 'Basic',
'ErrorPolicy': 'stop-printer',
'IdleExitTimeout': '60',
'JobPrivateAccess': 'default',
'JobPrivateValues': 'default',
'Listen': '/run/cups/cups.sock',
'LogLevel': 'warn',
'MaxLogSize': '0',
'SubscriptionPrivateAccess': 'default',
'SubscriptionPrivateValues': 'default',
'WebInterface': 'Yes',
'_debug_logging': '0',
'_remote_admin': '0',
'_remote_any': '0',
'_share_printers': '0',
'_user_cancel_any': '0'},
'error_log_checkpoint': 796100,
'error_log_cursor': 's=157d3f933f7048d7ac005f202bc2a1a2;i=61de0e20;b=8b9298e511a0472b98990e131b47a722;m=3b9b47435e;t=5ff5c13602dac;x=212800712cd506c3',
'error_log_debug_logging_set': True,
'error_log_timestamp': '2023-06-30 13:23:31'}
Page 9 (<troubleshoot.PrintTestPage.PrintTestPage object at 0x7f94cfbd6f10>):
{'test_page_attempted': '30/Jun/2023:13:23:38 -0400',
'test_page_job_id': [76],
'test_page_job_status': [(True,
76,
'Test Page',
'Processing',
{'attributes-charset': 'utf-8',
'attributes-natural-language': 'en-us',
'date-time-at-completed': None,
'date-time-at-creation': '(IPP_TAG_DATE)',
'date-time-at-processing': '(IPP_TAG_DATE)',
'document-format': 'application/vnd.cups-pdf-banner',
'document-format-detected': 'application/vnd.cups-pdf-banner',
'job-hold-until': 'no-hold',
'job-id': 76,
'job-impressions-completed': 1,
'job-k-octets': 1,
'job-media-progress': 22,
'job-media-sheets-completed': 1,
'job-more-info': 'http://localhost/jobs/76',
'job-printer-state-message': 'Gutenprint: Warning: '
'Inkset RGB not '
'available in BW',
'job-printer-state-reasons': ['connecting-to-device'],
'job-printer-up-time': 1688145907,
'job-printer-uri': 'ipp://localhost/printers/EPSON-ET-2700-Series',
'job-priority': 50,
'job-sheets': ['none', 'none'],
'job-state': 5,
'job-state-reasons': 'job-printing',
'job-uri': 'ipp://localhost/jobs/76',
'job-uuid': 'urn:uuid:75842053-ab25-3724-4937-6cce51eac821',
'number-of-documents': 1,
'print-color-mode': 'monochrome',
'printer-uri': 'ipp://localhost/printers/EPSON-ET-2700-Series',
'time-at-completed': None,
'time-at-creation': 1688145818,
'time-at-processing': 1688145818})],
'test_page_successful': False}
Page 10 (<troubleshoot.ErrorLogFetch.ErrorLogFetch object at 0x7f94cf90ca10>):
{'error_log_debug_logging_unset': True, 'journal': []}
Page 11 (<troubleshoot.PrinterStateReasons.PrinterStateReasons object at 0x7f94d0981f50>):
{'printer-state-message': 'Printing page 1, 22%',
'printer-state-reasons': ['connecting-to-device']}
Page 12 (<troubleshoot.Locale.Locale object at 0x7f94ceaa7ed0>):
{'printer_page_size': 'Letter',
'system_locale_lang': 'en_US',
'user_locale_ctype': 'en_US',
'user_locale_messages': 'en_US'}
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
