~ inxi -Fnz ✔
Kernel: 5.19.7-1-MANJARO arch: x86_64 bits: 64 Desktop: KDE Plasma
v: 5.25.5 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20NF0012US v: ThinkPad E595
serial: <superuser required>
Mobo: LENOVO model: 20NF0012US serial: <superuser required> UEFI: LENOVO
v: R11ET31W (1.11 ) date: 11/20/2019
ID-1: BAT0 charge: 44.1 Wh (100.0%) condition: 44.1/45.3 Wh (97.4%)
Info: quad core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP cache: L2: 2 MiB
Speed (MHz): avg: 1350 min/max: 1400/2100 cores: 1: 1400 2: 1779 3: 1230
4: 1231 5: 1227 6: 1400 7: 1231 8: 1302
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel
Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 driver: X:
loaded: amdgpu unloaded: modesetting gpu: amdgpu resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.47
5.19.7-1-MANJARO) v: 4.6 Mesa 22.1.7
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.19.7-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.57 running: yes
driver: r8168
Device-2: Intel Wireless-AC 9260 driver: iwlwifi
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
Local Storage: total: 2.73 TiB used: 133.1 GiB (4.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 1TB size: 931.51 GiB
ID-2: /dev/sda vendor: Crucial model: CT2000MX500SSD1 size: 1.82 TiB
ID-1: / size: 883.84 GiB used: 52.39 GiB (5.9%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 32.19 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 64.0 C mobo: N/A gpu: amdgpu temp: 63.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 278 Uptime: 22m Memory: 29.26 GiB used: 3.33 GiB (11.4%)
Shell: Zsh inxi: 3.3.21
When I connect to my wifi, it works great. When I add my BT headphones it works ok for a very short time then the NetworkManager seems to restart then loses only my wifi SSID. As soon as I disco the bluetooth headphones the wifi starts working again. It works fine with the headphones by themselves but won’t connect to any wifi.
5.10.141-1 LTS and 5.15.65-1 LTS also fail in the same way.
This does not happen in windows, but I never like using it. Other BT devices don’t seem to cause the same issue, nor do the headphones cause issues when connected to my phone right next to the laptop. It seems like it’s only these headphones with the wifi connected and only on linux.
I’m not seeing any relevant stuff in dmesg other then it not associating, but I already knew that:
[ 1604.167413] wlp4s0: authenticate with 28:87:ba:87:57:76
[ 1604.167439] wlp4s0: bad VHT capabilities, disabling VHT
[ 1604.167441] wlp4s0: 80 MHz not supported, disabling VHT
[ 1604.174022] wlp4s0: send auth to 28:87:ba:87:57:76 (try 1/3)
[ 1604.213914] wlp4s0: authenticated
[ 1604.216557] wlp4s0: associate with 28:87:ba:87:57:76 (try 1/3)
[ 1604.489847] wlp4s0: associate with 28:87:ba:87:57:76 (try 2/3)
[ 1604.613230] wlp4s0: associate with 28:87:ba:87:57:76 (try 3/3)
[ 1604.773230] wlp4s0: association with 28:87:ba:87:57:76 timed out
Anybody have any ideas? Let me know if you need more info
