Hello!
Could you please give an advice how to configure VPN connection by user interface of OS.
I can do it from console by command like this:
sudo openconnect MyVPNAddress
or
echo "MyPassword" | openconnect MyVPNAddress --servercert pin-sha256:MyServerCert --authgroup MyServerGroup -u MyUsername --passwd-on-stdin
I can also connect from Windows 10 using Cisco AnyConnect Secure Mobility Client.
But I can’t connect by ui of Manjaro. I’ve tried several options. For example when I use vpnc without GroupPassword, it doesn’t connect and returns message:
sending new secrets to the plugin failed: GDBus.Error:org.freedesktop.NetworkManager.VPN.Error.InvalidConnection: The request could not be processed because the requested “IPSec secret” information was not provided.
(I watch logs with command journalctl -f _COMM=NetworkManager)
When I put there a GroupPassword it says that it is connected, but websites are not available and after 30 seconds it disconnects with message “dbus: failure: connect-failed”
I’ve also tried different types of connection but no success. I have this options in VPN settings menu:
- Array Networks Compatible VPN (openconnect)
- Cisco AnyConnect Compatible VPN (openconnect)
- F5 BIG_IP Compatible VPN (openconnect)
- Fortinet Compatible VPN (openconnect)
- Pulse Connect Secure (openconnect)
Should I use one of this connections, or install something else?
I’ve also tried to install cisco-anyconnect from AUR, but it’s interface does not show anything.
My OS details:
- Manjaro 22.0.5 Sikaris
- KDE Plasma 5.26.5
- KDE Frameworks 5.103.0
- Qt Version 5.15.8
- Kernel Version 5.15.102-1-MANJARO (64-bit)
- Graphics Platform X11
