Hello,
in the documentation, they say you can choose multiple protocols and show this with an example using both https and http. In the pacman-mirrors v4.23.x this does not work, as you have to choose between one specific or all protocols:
$ sudo pacman-mirrors --api --protocols https,http
pacman-mirrors: error: argument -P/--proto/--protocols: invalid choice: 'https,http' (choose from 'all', 'http', 'https', 'ftp', 'ftps')
I also tried using [] and () or renaming the flag to --protocol/--proto/-P. Did this feature get removed and if yes, why are the docs not up-to-date?
Thanks for your time!
Leonardo
